Lexus RX 300
15455575960183
  • raddboy41raddboy41 Member Posts: 249
    As many of you might remember, I self-installed the round tube Hidden Hitch with the Toyotaguys.com "hitch plug kit" that plugs right into the OEM harness. Everything went great except I had NO power to the plug. I traced it back to the OEM harness which also had NO power and I simply decided to wait until the 5000 mi. service to let Lexus have a look. Well.....it's fixed! FREE! It seems that they found a loose connector in the vehicle wiring and according to the receipt also replaced an assembly. I tried to find the technician to get more detail but he was at lunch and I was late getting back to work. So there you have it. I believe I'm the only one to have this problem, so it's not something you're likely to run into. If you'd like to save yourself $300 and get a better looking hitch than OEM, don't shy away from this simple project.
  • clee4clee4 Member Posts: 103
    When I picked up my RX 7 months ago, I looked at the hitch cover and knew that somebody would steel it, if I did not do something about the way it was secured. At $19 each, one stolen is enough to make you mad. I took the cover out, punched two small holes in the side of the part that inserts into the hitch. Being from the aviation world, I then took some .032" safety wire, threaded it through the two punched holes and then fed the loose ends into the receiver, out the big holes in the side, and then twisted the ends together. Cut off the pigtail to a quarter inch and bent it over. You can not see it unless you get up close, down on your knees. If someone wants to steel it now, they need to bring their wire cutters. Try irontoad.com for a replacement. This will only work if you only use the hitch every so often.
  • dsa420dsa420 Member Posts: 3
    I bought 2000 RX in TX where ALL services were covered up to 30k miles. After moving to CA, the local dealers would not honor this offer and charge an exorbinant (sp) amount of money for general service. With this in mind, I opted out of the recomended 15k service and simply had an oil change and general inspection at a local service station. Are all of the items of done at 15k really neccessary? It seemed a little extreme to change all of the fluids and such at 15k. Please advise!!
  • tonychrystonychrys Member Posts: 1,310
    The only services required are what's in your owner's manual. What the dealer says doesn't matter.
    Everybody repeat after me: read the owner's manual.
  • mooretorquemooretorque Member Posts: 241
    surely you mean RX300.......never heard of anybody towing anything with an RX7
    quick identification hint:
    2 doors = RX7 4 doors = RX300
    time for my medicine
    I guess my insurance will not cover that mistake. Try looking at the user profiles.
  • ravlravl Member Posts: 129
    I recently purchased an RX300 and have seen people asking about the advertising fee and whether it's invoiced. There is indeed an adv. fee on the invoice which does not appear on any of the websites I researched that list invoice prices. So, when you go in to the dealer and tell them you have an invoice price of 'X' and they tell you their invoice price is approx. $400. more than your figure, it's due to invoiced advertising fees.
    Has anyone seen a 2002 model on a lot yet? Just curious. If so, any changes other than the two mentioned earlier--one being no Nakamichi. Forgot the other one...
    TIA.
  • lxsfanlxsfan Member Posts: 1
    Hope this info serves some do-it-yourself folks out there.
    The RX uses Toyota part number 90915-YZZB9 (made in Japan). An equivalent is the Denso 90915-20003. Some dealers recommend the Toyota 08922-02011 (US made). If you look at the internals of the US made filter, it looks exactly like the Fram and AC filters!
    Also, note that the Toyota Highlander V6 uses the same filter part numbers mentioned above.
    Be careful when buying from Toyota. When you ask for a Highlander oil filter, the 4-cylinder model uses a different part number, which is 90915-YZZB1. Specify the V6!
    If you want more savings, Toyota dealers advertise oil filters on their website. I got a couple last week for $3.27 a piece.
  • fantomfantom Member Posts: 211
    Down here in South Florida there are no 2002s but the lots are full of 2001s.
    Another change for MY 02 is the demise of the Silversport, but I don't know why. It seemed impressive and was the only model we could find without wood on the steering wheel. My wife was very concerned that the wood & plastic wheel would heat up in the hot sun.
    Anyone have a view on the pros & cons of the Silversport? Thanks.
    We bought the black Silversport and love the trim package. It was the deciding factor to move as quickly as we did to buy an RX. My husband and my taste tends towards modern/black/chrome, so when the Silversport was introduced, it was perfect for us. We've wanted an RX since they were introduced, but have never been fond of the woodwork in the interior. So the Silversport is a perfect match for us.
    Valencia Lexus in CA still had 2 silver and one black as of a week ago. Keep looking around for one. You won't be sorry as it's an awesome looking vehicle. If you get black, be sure to invest in a California Car Duster. It extends the time between car washes immeasurably.
    The SS was introduced in April of the '01 model year, so perhaps they will do the same thing come April 2002?
  • mikey00mikey00 Member Posts: 462
    The Silversport is worth it just for the better handling alone. IMO, nothing looks better than a black Silversport. However, I chickened out and went for the silver one so I wouldn't have the additional hassles of keeping a black car clean.
    Double check your numbers. Th HL 4 uses 90915-YZZA1 and the V6 uses 90915-YZZB1 and as you stated the RX uses 90915-YZZB9.
  • rmorin2rmorin2 Member Posts: 110
    Dealer returned our RX this evening. Everything fixed, car cleaned inside and out. Fixed the noise in the steering column, some kind of coupler. Redyed the driver's seat to fix probleme with leather, replaced glove box door, and installed a new hitch cover. I'm sure it will be stolen too so I am looking for a nice one that can be locked in place with a locking pin. Anyone with a good source, please post it.
    BTW my dealer is Bobby Rahal Lexus in Mechanicsburg, PA. I highly recommend them.
    ..as in the race car driver?
    Thanks for the advise....the Silversport sounds like some kind of SUV.
    I'll find out tomorrow because we located a silver one about 50 miles away. Worth the drive, if for nothing else, to see if the dealer is really serious about $4300 off MSRP.
    Anyone can read the profiles. I'd rather come up with witty banter with which to bring a smile to poster's faces......I know, some would say I have yet to come up with some. (Absolutely no offense meant, in other words.)
    Tony, that would be the very same Rahal, altho at this point he heads up the Formula One efforts of Jaguar. Ford, at this point, has not ponied up the sort of budget that F1 requires for a team to make it to the top tier (Ferrari, Williams, almost-BMW). Toyota is preparing to enter F1 and is fully commited and properly budgeted, by all accounts.
  • tronsr1tronsr1 Member Posts: 149
    He resigned last week from the Jag F1 Ford program.
    Tron
  • tariktarik Member Posts: 344
    He resigned? They (him and the Jag team) separated because he had tried to sell Irvine to Jordan behind Lauda's back... ...bad move!
    Read here: http://www.speedvision.com/pub/articles/racing/01formula1/010829b.html
    Tarik
    well, crap.......i hate disseminating out of date info, but i don't get to watch speedvision much, and this week's Autoweek won't show up till later today....mea culpa; mea dumbass culpa
    ...this is why there are wisecrackers like me ...
    Let's just hope for an enjoyable race in Belgium this Sunday (Speedvision, 7.30 am)!
    Tarik
    not much to race for, since michael is world champeen and ferrari won construtor (again).....guess we'll see if michael breaks win record, and if coulthard's jaw can get any more square....
    but i'll be watching regardless! may be a parade but i still love to see and hear those cars....
    Tom
  • rcramden777rcramden777 Member Posts: 1
    Someone I know has a problem with her RX300. Her ex car was a SAAB so now she's complaining of the "soft" ride and body roll that RX300 exibits. Unfortunately she didn't notice it before the purchase.
    The car is 1 year old so trading it in for another car that is more stiffer is going to be about $10-15K.
    I think changing the struts and coils all around, adding stiffer anti-roll bars, and replacing front seats for something much more firmer should do the trick for about $3-4k.
    Does anyone know of places that specialize in making RX300 stiffer? Who makes high-performance seats that fit RX300 perfectly?
    Please post here or email rcramdenus777@yahoo.com
    Thx very much in advance
    Have your friend test drive a RX300 silversport which has firmer suspension than the standard RX. With one year old RX trade final cost should be about 7K.
  • knight11knight11 Member Posts: 2
    Have not seen any on the ground yet but only 3 changes for 2002. No NAK, black pearl badging avail. as option, Canada now included on DVD for nav. models.
    Chet
  • gambiamangambiaman Member Posts: 131
    I have an 01 RX 300 and have had the oil changed twice, once at Lexus and once at Toyota. They used the same filter (08922-02011) at both places the Toyota dealer sells only Toyota. Had the oil changed Thursday in my wife's ES 300 at Toyota and they also used the same filter. The Toyota 3.0, V6 engine is used in many Toyota cars such as the Camary, Avolon, and I'm sure others.
  • bcjacob1bcjacob1 Member Posts: 39
    Has anyone figured out how to wire the nav/ DVD player to play video DVD's...or how to tap into the nav screen and add a movie DVD player?
    We drove base RX300 and Silversport at dealership this evening and the Sport is a more controlled, tighter ride, by far.
    Too bad it only comes with perforated black interior which my better half detests.....back to the drawing board. It is one beautiful auto, and at $4300 off MSRP, one heck of a deal also.
    http://www.Clublexus.com
    Look under the RX300 and Lexus Electronics forums.
  • drummerboydrummerboy Member Posts: 30
    Hi Tony,
    Can u give a short description of how it works (or if it works)? I couldn't find it on clublexus.com. Thanks!
    If she likes the Silversport ride and the "black leather seating is the problem, why not just have the seats redone in Whatever she wants? I do not know the cost of same.
    I am not sure what your better half didn't like about the perforated leather seats in th SS. IMO it's a great feature. I owned both a standard RX ans a SS. If I still had the standard one I would be checking to see what a shop would charge to install the perforated seat section. I wouldn't be susprised if it shows up as a standard feature in the future (MDX and others have it}. I bet a shop could also take you back the other direction and install a solid leather seating surface if desired.
    Now, if it's color black your better half didn't like it gets a little more difficult and more expensive to change that.
    Our Bravada has a "black interior" which is really charcoal, and it still looks new after 55,000 miles.
    Since the Rex will be her primary mode of transportation, she gets final veto rights. What she didn't like was the dark black shade and, in her opinion, cheap looking interior. Plus she prefers the two tone colors. She didn't notice the difference in the Silversport handling, but I sure did. The perforated seats would be cooler and the wood steering wheel will be hotter. I would opt for the Silversport, but with....
    Discretion being the better part of valor, looks like we'll pick up a green and ivory Rex this evening. And I guess I shouldn't be surprised that the quoted $4300 of MSRP gets adjusted for the "standard $399 dealer prep" routine.
    Readily absorbs solar radiation, gets extremely HOT, and then the interior takes forever to cool down once the A/C is started. Anyone who has lived in the mid-south would know to tell you to avoid dark interiors for this reason.
    Perforated leather seats will not be any cooler or cool quicker unless there is no "backing" material under the leather or backing material which itself is perforated.
    Perforated leather seats are for looks only, except those in the LS430 UL version.
    In no small measure because of this discussion group, we picked up our new '01 RX300 this evening, opal(green) with ivory interior. Dealer split the "standard $399 prep fee" with us.
    If the first 50 miles is any indication we will really enjoy this automobile. Break-in includes no hard braking, changing speeds, and keeping it under 55 MPH for the first 1000 miles....if that's possible!
    Of course a new car needs to be personalized so I am considering the following:
    1. Aftermarket rear deck spoiler.
    2. Factory match-added wood trim kit.
    3. Swapping Goodyear Integrity tires for
    Michelin Cross Terrain or Michelin LTX.
    Anyone have experience with any or all of these? Thanks again for your most valuable comments. Now pardon me while I drop off the Edmonds Bravada list :-)
  • scsrcsscsrcs Member Posts: 2
    Am about to buy a 2001 RX300. I am concerned about the acceleration (ie getting on the highway). Has anyone experienced the car to be sluggish in this kind of acceleration. Does anyone know the 0-30 time for the car. Does the RX have adequate "off the line" acceleration since the axle ratio is only 3.29:1. Most other cars have 3.4 or better.
    Steve
    Andy, it bascially involves "muxing in" the DVD source signal into the composite video stream that feeds the screen. No, you can't use the DVD Nav unit to play the discs, besides, it's not easy to get at anyway.
    Do you live near NJ? I think I've seen one place mentioned at ClubLexus that does complex (and good) RX300 aftermarket systems.
    Thanks for the info on 2002, Chet. I see the above option as being one that could get quite popular. My black SS looks quite awesome with the black pearl badging. I'd guess in addition to silver, white would look kinda kewl with it too.
    Has anyone located black pearl badges for the chrome wheels? I could ask my dealer, but I've found the internet to be a better source of cutting edge information....
    The black perforated seats in my SS are definetly cooler than the non-perforated light tan seats in my previous RX. But then again I am in NJ, not as hot as mid west.
    Thanx for the info Tony...
    I'm pretty surprised that this can be done! I live in Los Angeles. I'll ask around and see how much it'll cost. If it's under 1 grand then it's probably a good investment, although I really don't need to watch DVD in my car... I hardly ever watch it at home!!
  • alangotchialangotchi Member Posts: 5
    I purchased a 2001 RX300 couple months ago,and I'm very happy with it. I have a question about the air intake control button,every time after I parked under the sun even for a short period when I start the engine the air intake control turns on automatically, put it in recirculated air mode, it doesn't matter the climate control is set to automatic or manual mode. In the owner's manual it says if the engine coolant temperature becomes extremely high, the RECIRCULATED AIR mode is automatically selected. This is not a malfunction. But my car was parked and the coolant was not hot. Can someone tell me is this a malfunction? Thanks!
    First, let me be sure you and I are talking the same language. The way I read your post is that when you get in the RX the system switches to recirc mode automatically.
    If that is the gist of your complaint then my answer applies.
    Your Climate control system is designed by a company called NipponDenso, in the US known as Denso USA. When you first start up the car and the interior has been heated by the sun then the system will automatically switch to recirc on the theory that the cabin will cool down more quickly that way.
    That "theory" holds up as long as the cabin interior is not hotter than the OAT (outside air temperature) which is oftentimes the case.
    If the interior feels hotter to you than the OAT then the best thing to do is over-ride the automatic setting by immediately activating the flow-through mode, to bring in fresh, cooler, airflow, until you feel the interior temperature is at or below the OAT.
    Then simply depress the "auto" button and let the system take it from there. It will likely return to re-circ automatically but now that will be more constructive.
    THANKS! WWEST, that was my complaint, when the interior has been heated up the recirc mode comes on by itself and I have to switch to outside air, so this is not a mulfunction but design flaw. Thanks again.
  • kelso4kelso4 Member Posts: 2
    Hi everyone,
    Just logged onto this site for the first time yesterday, and found a lot of useful info. We're looking at the RX300, BMW X5 and Acura MDX, and would appreciate hearing from anyone who compared any/all of those vehicles. What were the deciding factors, and have you been happy with your decision? Our priorities are safety, handling, comfort/convenience, and reliability. We don't need off-road or towing capabilities, but do have winding back roads and snow, and we vacation with 2 kids and a 50 lb dog. Thanks in advance for your input!
  • kmhkmh Member Posts: 143
    My RX recently was a victim of a mindless, inconsiderate individual that slammed their car door into my unblemished passenger door recently.
    Now, I'm considering have Paintless Dent Repair done since I don't want deal paint mismatch, etc.
    I'm wondering if any other owners here have had PDR done on their vehicles and if they're satisfied with the results. And what should I expect in terms of cost for a "half-dollar" sized door ding?
    I'd appreciate any recommendations, especially if they're in the San Antonio, Texas area.
    BMW was significantly more expensive than others with no justification for addition costs other than BMW badge, as far as I could see. BMW does have the BEST AWD setup by far.
    MDX has a much better AWD setup, mechanically, than does the RX. Does not have (2001) HID, VSC, nor Trac.
    RX is basically a FWD vehicle, mechanically, which can/will automatically bias as much as 49% of the torque to the rear wheels once the front wheels lose traction and start turning faster than the rears. Note that when the FRONT wheels lose traction you have very possibly lost steering control also.
    In theory, Trac should alleviate this problem, actually applying the brakes to the front wheels the instant they tend to turn faster than the rears. But then that action would prevent the viscous clutch from "stiffening up" the machanically connection to the rears, so just what kind of vehicle are we left with?
    So, for me, being over 60 and losing my color night vision rapidly, the HID headlamps were the deciding factor. The VSC and Trac, if they work as advertised, will overcome the mechanical advantage of the MDX and X5's AWD setup.
    I have never believed that it is a good idea to have the majority of the engine's torque delivered to the front wheels. If more than half of the available torque is delivered to the rear in normal Mode then it will be the rear that will lose traction first and the recovery from that can be very quick and instinctive. With FWD once traction is lost there is often no recovery method available.
  • jeffmust2jeffmust2 Member Posts: 811
    I assume you and spouse in the front and two kids go in the back seat and the 50 lbs of canine goes in the way back. Take a good look at the internal space to one side of the canine that's left for the kid's stuff and you and your spouse's stuff. If your family is like mine, (just a spouse plus a single 90 lb canine with the Male Heir sucking up his parents money in college but I'm not bitter) it better be a short trip.
    Or...plan on putting all luggage up on the roof? I think it has a 75-100 lb limit and there ain't no rub strips between the crossbars so count on adding a luggage carrier of some kind and that will limit your actual luggage weight even more. Not to mention the decrease in MPG because of wind resistance and decrease in handling re being top heavy.
    Forget the current BMW; it makes the RX look large. Rumor has it that an extended BMW will soon appear but make sure your wallet has at least $50K available.
    The MDX, if that's your remaining alternative, is the best bet to handle and carry stuff in a mid-size SUV. First-year complaints have been relatively minor but the MPG isn't great and it does like 91 octane (sister-in-law has one and couldn't fit hubby and baby and all her baby hardware into RX).
    We have the RX and love it, but after two trips, it serves us best as an intra-city commuter. The new version coming out as a 2003 model will have more cargo room ala Toyota Highlander - you might check on one of those; it's currently built in the same Japanese factory as the RX.
  • sathomasgasathomasga Member Posts: 10
    Just got through a month of comparing MDX, X5, and RX300. My opinion in a (very small) nutshell: BMW handles better; MDX seats seven; RX300 can be had for a lot less money. The last one was the deciding factor for me, as all seemed otherwise to be very competent vehicles. (Technically the list prices of MDX and RX300 are about the same, but, here in Atlanta, MDXs are still pre-order only, and the Lexus dealers have scores of RX300s sitting idle on their lots.)
    Thanks, wweest, jeffmust2 & sathomasga ~ Appreciate your thoughtful replies. As for the 50-lb canine, she's prone to sleeping on the floor at the kids' feet. Only problem is, in our Audi A-6 wagon (which we love), she can't sit in the middle because of the hump. So we either have to keep the kids from growing, or find a way to give the dog her own floor space. An SUV seems to solve the problem, we just have to figure out which one. We love the BMW's handling, and the safety ratings are fantastic, (as is the price, in a different sense), but we're also impressed by the ride on the Lexus, and having driven Camrys for years, we've been very pleased with their comfort & reliability ~ expecting likewise from Lexus. MDX is the most versatile, but we're a bit put off by its chunky size, noise and poor CU ratings for emergency handling. Wish it had Stability Control. So, we're still pondering. Perhaps we'll check out the Highlander, if nothing else, just to see what a future RX might offer space-wise. Thanks.
  • pagedbpagedb Member Posts: 4
    My husband and I have been pondering these three vehicles as well.
    The BMW was quickly dismissed primarily because of cargo room. The price was also exorbitant in comparison to the other two cars which offered more space and luxury.
    The MDX was drove well, definitely had the most cargo room. The interior looked chintzy for a car of its price though. Faux wood dash and console - yikes! Dealers visited were very unwilling to negotiate on price, even on the late Sept and Oct deliveries of 2001 vehicles, very forceful in trying to sell dealer installed options.
    After much research and debate, we wound up with the Lexus. We have had 3 of their other cars (an ES, 2 GS(s)). The RX has a fair amount of cargo room, rear seat can more forward 6 inches to expand it further, seats split 60/40 as well. The interior is far more luxurious than either of the other two and the sound system is better as well. I do not plan to do any major off road work, car is fine for my husband, daughter, Labrador Retretiver and I to travel around town or go away for a long weekend. As the car is not in as high demand as the MDX (it is still the best selling SUV in the USA), the dealership was very willing to negotiate price and gave me a reasonable trade in on my 99 GS300.
    While my husband liked the looks of the MDX slightly better (a little more truck like than the RX), getting the RX AWD with all options except NAV for over $1000 less than the MDX w/ touring package, we are both confident we made the right choice for us.
