Visitor Agreement.
None of the warning lights went off, it was not raining, the roads were dry and I have a FWD.
Has anybody heard this before? Any comments will be appreciated.
Cheers!
Steve
FYI, black RXs (I have one) are the only ones that have no clear coat among RXs.
So this lack of a top cost could make it easier to scratch the paint, especially near the door handles that get more wear and tear than other areas.
Get a bottle of auto polish that says "scratch remover" on the label from any number of outlets such as Pep Boys, AutoZone, etc. Works fine just go lightly on the rubbing and follow directions.
Steve
As a wonderful bonus, every study conducted has proven that carpool or HOV lanes do nothing to actually encourage carpooling. The billions of dollars wasted converting the far right lanes on freeways into "HOV" status could have been far better spent....maybe on our $5 billion subway system that doesn't actually run anywhere people need to go.
1. lack of dual zone climate control
2. lack of digital compass (option added to later models)
3. chintzy front license plate bracket
4. front fold down center arm rests too small
5. should be prewired for trailer towing harness (now standard)
6. painted steel spare wheel (now has alloy wheel)
7. no garment hooks in rear seats (since corrected)
8. routine dealer service is v-e-r-y expensive, I call it the $100 oil change
Would I buy another? In a heartbeat!
Pete
The RX300 AWD system is that in name only.
If you happen to need true AWD performance then have a good look at the Chrysler T&C minivan.
No, Really!
The T&C isn't in the same CLASS as the RX, not nearly, unless you do need AWD, then it's head and shoulders, as are a lot of others.
I recently drove a 99 RX300 CPO and it seemed to have quite a bit of front end dive/roll when turning (e.g. turning from one city street onto another).
Having not owned an SUV for a while (driving BMW sedans) I wasn't sure if I was just spoiled by the sedans or something was up.
I drove another (at another dealership) and it didn't seem as bad/noticable.
A while back I saw reference to a technical service bulleting regarding strut replacement.
Is it likely that this vehicle may need replacements (vehicle has 44K miles) or is it just my imagination?
On one of my RXs (both '99 AWD, BTW) it has Goodyear Integritys and feels more softly sprung.
On the other, it's shod with Bridgestone Dueler H/Ls and feels much more crisp.
Struts and shocks are designed to "give way" on compression.
Can this be fixed by applying belt dressing?
And before I dive into the egine bay, where is it located?
Gets me in trouble every time!
Mold and mildew odor is caused by bacterial growth due to the thin film of mositure remaining on evaporator core long after A/C use. Early morning instances of windshield fogging is from the same source. Japanese vehicles, climate control supplied by NipponDenso or Denso USA, cannot properly defog/demist the windshield.
Many modern day vehicles, including Lexus and Porsche, run the A/C compressor all the way down to the absolute minimum outside temperatures. Below about 55F the only possible LOGICAL need for the A/C compressor is to dehumidify the incoming airflow and thus to help in keeping the windshield defogged, and maybe add some minor level of human comfort.
The problem is, Lexus, or any vehicle with an automatic climate control designed by Denso, relies solely on the A/C system to defog/demist the windshield. Below 32F OAT this is a practical impossibility! Even above 32F, and upwards to about 45F, the humidity of the incoming airstream must be extraordinarily high for this practice to be effective.
To date I have recieved only two explanations for this practice, running the A/C system below 45F.
1. Running the A/C keeps the A/C evaporator coated with a thin film of moisture and that suppresses the horrid mold and mildew odor. Porsche factory represenative told me that.
2. Using the A/C system to defog/demist the windshield by dehumidifying the incoming airflow, however inefficient, and even non-functional, that might be at lower temperatures, circumvents the requirement, otherwise, to use a high level of heating to accomplish this and thereby discomforting the passengers.
Does that sound like a SANE design decision? Sacrifice the safety of the passengers in your automobile rather than discomfort them by heating the windshield when it becomes necessary.
Does anyone have another explanation to offer?
But, back to work.
How about a dash mounted switch that disables the A/C compressor clutch and at the same time enables a circuit which if the defog/demist climate control function is activated causes the airflow heating level to rise substantially along with the blower speed, virtually instantly.
If you notice even the slightest indication of windshield condensation the dewpoint spread will be instantly increased with heat and airflow once you activate the defog/demist function.
Presumiably most operators would activate the switch once the predominant ambiant temperature declines below 50F. No more thin film of mositure on the evaporator vanes,
NO MORE BACTERIAL GROWTH!
NO MORE COLD MORNING DRIVE WINDSHIELD FOGGING!
SUBSTANTIAL INCREASE IN MPG.
Oh, by the way, while Porsche does run the A/C all the way down to just above the point of freezing, on the HOTTEST day of summer if you activate defog/demist, YOU INSTANTLY GET HIGH HEAT AND AIRFLOW TO THE INTERIOR WINDSHIELD SURFACE!
Not stupid, those German engineers.
I think the information you posted above is what, the 8th or 20th time you've done so within the last year? Without it being in response to anyone else mentioning the same supposed defrosting and/or mildew-mold problem.
My take is that it gets a little redundant after the 3rd or 4th iteration. Hey, but if that's your prime issue, might as well flog it to death. How about creating a "Lexus Defrosters Kill People" topic?
And as for "The Art of German Engineering" as one car company (Audi, I think) used to call it...from today's news, guess BMW can't stop their airbags from firing off when their sedans go over bumps in the road.
Even after 41 reported injuries and two full recalls of 1999-2001 Series 3 models.
Bet their phantom Bi-Xenons and defrost systems work great!
Good one Jeff ;-)
I do also think that drivers can take a course in advanced driving schools rather than depend on the government to spend millions on driving simulators.
In fact, I think that drivers' licenses shouldn't be handed out like "candy." A stricter system definitely needs to be implemented. The Germans have the right idea for instance.
There's even a claim by someone saying that the sticker has, at least at one time, incorrectly claimed bi-xenons. Atomic80, can you confirm?
Meanwhile, the M-class has bi-xenons, as well as the new Volvo XC90.
Steve
The insurance companies are currently counter-motivated, the higher the accident/injury rate, the more money they make in absolute dollars.
Let's get the state governments' regulatory agencies to turn that around so the automobile insurance industry is positively motivated to reduce accidents and injuries. For every dollar they invest in driver education that reduces the accident injury rate measureably let them get a heftier return on their investment than the return they get under the current counter-motivational scheme.
And I was at BMW of Bellevue about two weeks ago but ended up telling the salesman to call me in october when the 03s were in.
Jim d.
But I have a question. Is there an update for the Nav yet?
I saw a message (#5607 by silly1040) that his dealer wanted to charge him $500 for the update (but he was raving about how great his Lexus experience was). I was assured the first 3 updates (published yearly) are freebies, and updates from there would be "about $100".
We've had our '01 RX300 for about a year and a half and have yet to be notified of an update.
Is there one? If so, is it worth the hassle of getting it done?
-Craig
Have not heard of freebes.
Maybe it was a dealership specific perk.
-Craig
-Craig
Cloth interior that is a bit soiled (188k miles!) but otherwise in great shape.
When I have the RX in for its monthly service at Uncle Miltie's No Mo' Mold or Mildew Emporium, the Legend is my local runaround.
Amazing these puppies used to cost $26-28k a dozen years ago - what would that be today, $40-45k?
Why are you selling it - major repairs coming up or just tired of it?
Jeff
At least one buyer in Town Hall has already expressed a preference for cloth and cloth is less expensive. I think it follows that some looking at a used vehicle may also prefer cloth and appreciate the lower price.
tidester
SUVs; Aftermarket & Accessories
As used cars age, the difference in price with high priced options dwindle. For example, the difference between a used '96 Accord with auto and 5 speed is about $248. The auto was about $1000 when new.
An RX300 (or any Lexus) with cloth is a highly specialized vehicle. And specialized in a "low-rent" sort of way. There will be very little market for a used Lexus ANYTHING without leather.
-Craig
It'll sell, I think. For less, yes, but the original buyer would have paid a lot less up front.
Sell convertibles in the spring. Buy them in the dead of winter.
Sell light-colored exterior vehicles in the southwest during summer months. Buy dark-colored exterior vehicles in the southwest during the summer months.
'Course, it might be a bit wacko to travel a few thousand miles RT from where you live just to sell or buy a used car...
My 89 Acura has been a great car and I'm just getting tired of it.
In my ideal world I would own 4 vehicles. A minivan (we have an Odyssey), a nice sedan (the Acura), an SUV (gas guzzling people killer!
What other choices might you all suggest besides an RX? Or why the RX?
Jim d.
The Chrysler Town & country!
Think about what the RX has that the T&C doesn't have!
Lexus name... The Lexus marque is currently coming apart at the seams, Lexus cannot control the actions and activities of their American dealer network and those dealers are currently quite intent and focussed on screwing their customers, the American way!
I have absolutely no doubt that the T&C has a much better AWD system than the RX, head and shoulders. And you can put chains on the rear of the T&C AND the front if need be.
Driving height? Not sure but the T&C AWD has gotta be close.
Turning radius? Any reasonable alternative vehicle out there is going to be better than the RX in this class.
The T&C's only shortcoming are HID (available aftermarket) VSC and Trac. But with a decent AWD system there is less need for VSC and Trac.
And after having driven an 01 AWD RX with VSC and Trac I'm not really sure the Trac really has any really beneficial use. The VSC has stepped in a few times, I'll give it A+ for that.
But I have to admit, the Lexus climate control is much more sophisticated that the T&C, if only that could get the base design right.
Oh, and whatever you do, don't get a "captive" GPS/nav system. The Lexus Nav system's firmware is so BUGGY it makes the system useless, you dare not rely on it.
Me to Dodge Service Writer: "Gosh, my $28,000 Dodge Grand Caravan's V-belt is sure making a lot of noise for a brand new vehicle I bought new here a month ago - whatta think?"
Dodge Service Writer: "They all do that. Get yourself a spray can of belt lube and then you won't have to bother to come over here every time you or the little lady hears a little squeal."
Bottom line: It took six months and another 4 trips, but Dodge finally replaced an out-of-round, defective drive pully.
Me to Lexus Service Writer on a '98 LS400 (in warranty at the time) that I purchased from a private party (bet it cost me less than a new AWD T&C); first visit to Lexus dealer for servicing: "Neither remote seems to work even after I replaced their batteries. There's a light scratch in the top coat lacquer on the wood console under the shifter; can it be buffed out somehow? - I know that's not warranty. Also, it's a little slow cranking from cold in the morning; could the battery need a charge? Finally, I hear a noise in the front suspension; no idea what that could be."
Lexus Service Writer: "No problem. Here's the key for a loaner LS while we work on yours. It might be 2-3 days if we need parts."
Bottom line: Two days in their shop. Master Tech traced non-functional remote problem to a wiring defect in harness INSIDE right front passenger door - small short to ground caused in-op remotes and battery drain down. Replaced bad wiring and main battery. Replaced wood console under shifter and all other interior wood to match console pattern. Replaced struts and other front suspension parts too numerous to list to cure noise. All done under warranty.
Time for one more, and this is my favorite:
Me to Dodge Service Writer: "Thanks for replacing the rear hatch gas struts, mounts, and fastening bolts on a 1-year old vehicle; when the right gas strut mounting bolt gave way last week and the hatch came crashing down and nearly killed my wife standing next to it, it's really gonna take some convincing to have her drive this van again...oh well...one question...that huge, foot-long rip in the headliner above the spot your tech worked on the mounting hardware...you know, the rip with all the grease around it...any chance your guy just might have caused that?"
Dodge Service Writer: "No - but you got kids, don't-cha?"
Bottom line: Dodge replaced the entire headliner about a month later.
Finally...
Me to Lexus Service Writer (today!): "Please have your guys take a look at the RX's brakes; we've got 28k now and I think the front end needs some pads from the noises we've been hearing."
Lexus Service Writer: "No problem sir; here's the key to a new ES300 loaner. I'll call you within 2 hours."
Bottom line: Lexus replaced the front pads (with 70% wear left on 'em), rotors, and shim kit under a TSB to correct brake noises. No charge.
Any questions?
Number of vists, unscheduled or not, to Chrysler for 97, 98, or 00 (98 & 00 still in "Family") Chrysler T&C. Big FAT ZERO.
When I bought my first Lexus in late 91 I think I was sort of looking forward to leaving my DIY years behind me. Bellevue Lexus soon proved me wrong.
So today I still service my own vehicles, and for both marques that primarily consists of regular oil and filter (oil, air, and now A/C) changes.
I have easily put more miles and time in lexus vehicles than T&C's, but I would stand up anywhere and state that Lexus builds the most reliable vehicles in the world, and the LS series is without a doubt the very best in its class, even if you widen the class substantially.
But I still stand by my case, if you NEED AWD then the RX nor the HL will fit the bill.
I can live with a defective nav (turn it OFF!), and I can manually over-ride the climate control system's design flaws. But absent spending a LOT of money duplicating the Chrysler AWD system in the RX, I haven't figured out how to get through a hard winter with only the RX around for AWD.
Jim d.
'Course, anybody that drives wintertime in upstate NY or Montana or N. Dakota would laugh at your definition of WA having a hard winter...
Yup, you bought the Wrong Vehicle and all your whining about HVAC, AWD, interior gases killing the occupants, Nav won't do this or do that, need to rewire DRLs & fog lamps, Lexus dealers are failing in their attemps to gouge all their customers (with sales at an alltime high), and all the other "factory defects" your mind is making up won't get you past that single, overriding fact:
You made the Wrong Choice.
So be a Man.
Let it go.
Quit whining.
Sell the RX and buy something that can handle "hard winters" LOL LOL LOL.
Now, if its that time in your life that finances are a bit tight, call your offspring in So.CA, get the T&C back in your garage next to that Art of German Engineering Porsche, and swap her the RX.
Unless you think the RX can't handle the Hard Winters in So. CA.
The Nav system has been amazing. I do not use maps any more and rely solely on the Nav System. I'm will never own another vehicle without a Nav System. They do have limitations but they really aid in finding your destinations.
I have 22,000 miles on the vehicle and it has never been back to the Lexus dealer for any warranty work.
The vehicle is extremely comfortable and is very quiet with no squeaks and rattles.
Gas mileage has been 22 to 24 on the highway and about 20 with a 50 - 50 mix of city and highway.
Willard - last year you were promoting the Santa Fe this year the TC. What will it be next year.? Oh by the way I have recently rented a Chrysler Van and there is no comparison to the RX 300.
JS
What took you so long to jump into the fray? :-)
tidester
