Visitor Agreement.
I have a 2002 RX300 also and am experiencing the same sound as you guys have described. Does it only happen to you all when turning the wheel fully when pulling out of a parking lot or such?
I wonder what it could be. I guess I am going to go see the dealer about that.
Any recommendations on what brake fluid to use? Should I just get the recommended oil from Toyota dealership or change to Mobil 1? I couldnt find anything over at CL either. I am also switching to K&N
I didn't have the tires rotated because I have Cross Terrains from Costco and they rotate them for free.
Just wondering- I got a deep cut in my tire sometime back. Will the Lexus dealer repair it on warranty or should I get it repaired on my own?
Pete
From what I read, I can fit the following on the orignal rims
225/70/16 (OEM)
235/70/16 Seems like a popular upgrade
245/70/16 A few have done this w/o spacers
255/65/16 Pirellis A few have done this- supposed to work w/o any problems
I also read some negative comments from someone who quoted a C&D Article abt Pirelli compared to Michellin
I will probably stick with Michellin CT (instead of LTX as CT is a newer/better design)
I just need to replace my blown out spare but would replace the remaining 4 after 20k more miles (odo reads 30k currently)
Thanks for your help/time
Any info would be appreciated!
http://thecarconnection.com/index.asp?article=5596
For more looks at the RX330, you may want to check out clublexus.com under the RX300/330 discussion there, too.
There's only one debate still. The article you linked mentioned optional third row seats. Most of the information I've seen point to NO optional 3rd row. But we'll see, I guess.
I highly recommend it especially if one plans to keep scratches off the paint.
Pete
For all those having already re-torqued the driveline bolts, did they turn any farther before reaching the torque specification or did you have to back them off first in order to re-torque.
Mine didn't seem to turn even an iota.
2. If I decide to check the torque myself, do I just go to Sears and buy a mid-price Craftsman torque wrench? Are there any do's and don'ts in the retorque process? Anybody have the specs?
Pete
"Anyone else notice nicks in the side pillar from the driver side seat buckle? My wife has a habit of unbuckling and just letting the belt fly back, rather than easing it back with her hand."
After reading your posting, I check our RX and found the same nicks. Thanks for the info. We had no idea this was happening. This is my wife's car and she has the same habit like yours. I complained to my dealer that the seat belt tension was too strong and that was the cause of the problem. We were not warned about this problem. This is a design problem. I was told that the seat belt tension is fine and it was not under warranty but they will replaced it one time only as a courtesy to me. They just replaced it and now we gently let release and glide the seat belt back to the pillar. I suggest everybody check their RX and gently release their seat belt.
If you happened to notice that Aqua Ice Prius in the showroom at Kirkland that's the one I just bought.
Lexus should just close their service shop and send everyone to Toyota.
FWD models have no driveshaft and, hence, no bolts to torque.
by using spacers of varying sizes, you can use a larger selection of wheels. If you don't use spacers, then find a 17x8" wheel with an offset derived by subtracting 30mm (1.2") from the factory offset. Spacers aren't cheap, almost $300, but they give you a much broader range of rims to pick from. Tire Rack can do a search for whatever offset you desire in 17 x 8's , it's another matter if they find any, or if you like the one's they offer.
It would be interesting to note the difference in weight from 16 x 6.5 to 17 x 8, assuming the same construction. Usually the result is more weight, resulting in more unsprung weight, sometimes to the detrement of acceleration. Ideally, you should spring for a nice set of custom three piece rims, with whatever offset provides suspension clearance.
Try to maintain the same tire circumference, and pay close attention to accelerated suspension wear when using spacers or wheels that have an offset that varies from the stock spec. When changing the offset from spec, your affecting the suspension settings as well, both of which are not desirable.
Not sure what the factory offset is but perhaps someone with a manual can find the info.
Heard of some owners using 255/60's on these rims, anyone?
Knowing the offset of the rims that the owners are using with the 30mm spacer is critical, perhaps they can post this info and the tire sizes they used.
The odds of getting the seat belt mechanism replaced are much higher than the odds of successfully "re training" my wife.
Comfort---- Lack of queasiness in the pit of your stomach due to soft suspension and "body" roll when cornering.
I had the 30k Service done for my 2001 RX SS last Sat at Lexus of Bellevue (WA). I usually get my reg oil changes done at Toyota of Kirkland (where they charge $10 each labor for oil change/tire rotation) but depending on whom I talked to, I was quoted anywhere from $180 to $360 for the 30k service (only the items on the mfr manual and Mobil 1/Oil Filter/Air Filter provided by me). I was quoted $240 for the same at Lexus of Bellevue so I went there – this was my first paid service at any Lexus dealer.
Here is a rundown:
Minor Service [Notes: Its actually Major service for 30k but in the Major service they change transmission fluids etc which I didn’t want and hence the Minor service; I provided 5qts of Mobil 1 oil and Filter and gasket ($9 from Toyota Dealer)]
Change Engine Oil Oil Filter and drain plug gasket
Inspect Enginer Air Filter
Rotate Tires
Inspect Brake System: Front Brakes 6mm Rear Brakes 8mm remaining
Inspect Steering Linkage and Rack * Pinion Assembly
Inspect Ball Joints and Covers
Inspect Drive Shaft Boots
Set 4 Tires to 32PSI Spare=40
Front Tire Depth 4/32 7/32
Rear Tire Depth 6/32
Inspect and Top off all engine compartment fluids
Load test battery, clean terminals and fill
Battery Condition- PASS
Check Int & Ext lights for operation
Check windshield wiper operation, blades and washer fluid
Inspect drivetrain fluids and top off as needed
Cooling system inspection- coolant level good to 34F
Retorque flange bolts
Road Test
Hand wash & Vaccum
$108.53 incl taxes
Flushed Brake Fluid and filled system [No diff in prices for brake fluid (2 qts @ $5 each) from Toyota/Lexus, so let them use their own]
$108.53 incl taxes
Replaced Air Filter [Couldn’t find K&N 32-2045-1 so went with 32-2052; they didn’t complain about it;]
$31.55 incl taxes [Pretty high- I should have done this myself!]
CBEST options were changed at no cost.
Total = $248.61
Was provided with a ES300 (2003) loaner. The Bridgestones on it made a big difference in handling compared to my Integritys. Automatic wipers are great. Must have feature for any future purchase for Seattle weather
The pros and cons of using spacers, along with any another modification must be addressed by each owner and his needs. I've gone the Michelin CT's 225/70/16, factory rims, and springs route...to each his own.
Using spacers or any combo that changes the offset from factory specs, can effect the path of tire/suspension travel throughout it's full range of motion. The wider track and increased tire contact patch will certainly raise the bar for handling limits, perhaps at the expense of high speed stability/handling @9/10th driving. Since most don't drive this aggressive or go off-road, they may never notice the difference. Remember to get a alignment after the new tires/rims. Can they be aligned to factory specs with the new wheels? Some suspension systems don't allow changes to toe, cast and camber, what about the RX?
If you still have the stock wheels, I'd be curious to see what the weight difference is between them and the new 17x8's. (?)
If you can get away with finding a rim with an offset that works, gets you the 3" wider track, and doesn't require a spacer, your ahead money wise and you benefit from the weight savings. If you've got your heart set on some wheels with a different offset, spacers may be the only way to allow them to fit.
Be sure and drive carefully, very carefully, the next 50-100k miles.
Other than the needless change of brake fluid I see about $25 worth of work (gofer rates) in your list.
It appears that Nissan has been listening to your advice. My wife and I looked at a new Nissan Murano this weekend, and 18" wheels and tires are standard. They claim in the AWD version that 50% of the traction is directed towards the rear wheels in some situations. The V6 has 245 horsepower and highway mileage is 24 Vs 22 for the RX300. The car is still built in Kyushu, Japan, the same city where the RX300 is built. The 2004 RX330 is supposed to be built in Canada, so I feel the paint quality will be diminished as the environmental laws are stricter in Canada.
I am pretty satisfied with their service so far and I think you should give them a fair chance too and not base your judgement based on your experience in 92. We all make mistakes.
I am pretty sure I have paid for the dealers kids education, but not as much as others or elsewhere and hence my satisfation.
Did some google search and some people seem to advice changing brake fluids every 2 yrs just like 5k oil changes. I havent formed an opinion on this yet.
Added the Mobil 1 I supplied without first draining the old oil.
Service manager told me, argued with me, that the 00 GS300 I was complaining about the tip-in throttle surge had an e-throttle. This after I had just explained that I had already removed most of the backlash from the throttle cable from the footfeed to the intake.
Bought a new 00 AWD RX from them in early 00 and took it in for first oil change, service writer lefy me standing saying "wait here just a moment, I'll be right back". He wasn't really very long but when he came back he was carrying a rear bumper rubber step guard which he wanted to sell me. If I turn down this sale will I still get good service?
I opted "out".
