http://www.carspace.com/atfdmike/.59a1ec94
first i want to say thank very much for help atfdmike, now everything work fine.
power windows switch ------ OK.
power lock/unlock switch --- OK.
my problem was isuzu trooper 94 have a relay for lock and unlock at right kick panel so i had to unplug the relay because the 98 windows swith have a relay inside.
so 2 relay do not work.
now my door lock good and working good
thank again.
Thanks! :sick:
I had a throttle body wear out under the carburator on my 1984 Trooper, changed out the throttle body part and cleaned up the linkages and everything worked great, also eliminated a vacuum leak so it idled much better too. You 1995 does not have a carburator, but it must have a throtle body and probably there is a shaft through it that must pivot freely.
Have fun, I like that kind of puzzle as long as I'm not in a hurry to go..
1995 Isuzu Truck Trooper (4 Door) V6-3165cc 3.2L DOHC (6VD1)
Vehicle Level Powertrain Management Fuel Delivery and Air Induction Throttle Cable/Linkage Technical Service Bulletins Recalls Recall 04V199000: Accelerator Cable Sticking
DEFECT: On certain sport utility vehicles, the accelerator cable can stick so that the engine speed will not immediately decrease upon release of the accelerator pedal. This can cause the accelerator throttle cable to delay rpm and vehicle speed reduction for several seconds after the accelerator pedal is released, which in turn, can lead to a crash.
REMEDY: Dealers will replace the throttle cable rubber boot. The manufacturer has reported that owner notification is expected to begin during May 2004. Owners may contact Isuzu at 1-800-255-6727.
TSB SBO4-02-S003
1992-1995 Isuzu Trooper Accelerator Cable Safety Campaign
04V-199
ISSUE DATE: MAY 2004
Campaign Identification Number
Number 04V-199 has been assigned to this campaign by the National Highway Traffic Safety Administration (NHTSA). This number will appear on all communications and documentation of any nature dealing with the campaign.
Affected Vehicles
1992-1995 Isuzu Trooper (UX) vehicles equipped with V6 engines with the following VIN range JACDH58V7N7900012 - JACDJ58V5S7906162.
Service Information
Condition:
On some vehicles, the accelerator cable dust cover may deteriorate, causing the cable dust cover to adhere to the inner throttle cable. This can cause the accelerator throttle cable to delay RPM and vehicle speed reduction for several seconds after the accelerator pedal is released, which in turn, can lead to a crash without warning.
Correction:
Follow the service procedure in this bulletin to replace the accelerator cable dust cover.
Dealer Responsibility
Isuzu dealers are required to service all eligible vehicles at no charge to the owner, regardless of mileage, age of vehicle or ownership.
Whenever a vehicle subject to this campaign is in a dealer's vehicle inventory or arrives at the dealership for service, the dealer must take the necessary steps to ensure that this campaign correction has been made before selling or releasing the vehicle.
Each Isuzu dealer will be supplied a copy of the AIMI Campaign Report (AWS-123-1A) listing affected vehicles assigned to that dealership. The report contains VIN and detailed owner information obtained from state motor vehicle registration records. The use of such motor vehicle registration data for any other purpose is a violation of the law in several states. Accordingly, dealers are urged to limit the use of this listing to the follow-up necessary to complete this campaign. If none of the affected vehicles are assigned to a dealership, no campaign report will be sent.
Owner Notification
Isuzu Motors America, Inc. will send a notification letter to owners of affected vehicles already retailed (see enclosed copy). Dealers should follow up with vehicle owners by sending a Campaign Reminder Notice (AIMI SVCF-1052) to all vehicle owners listed in the AIMI Campaign Report (AWS-123-1A). Dealers may obtain these postcards from their Regional Office.
Applying the Campaign Label
Affix the campaign label P/N 2-90028-700-0 adjacent to the manufacturer's identification label located inside the driver's door. Using a ballpoint pen, fill in the label with campaign number 04V-199, Isuzu dealer code and repair date.
Parts Information
Warranty Claim Information
Use the labor operation shown.
NOTE :
1. Labor Time includes administrative time allowance.
2. Information released on paper and electronic format prior to bulletin release cannot be updated.
3. Always refer to the Isuzu Service Policy Procedure Manual for specific details on warranty coverage and policies.
Robin...
Since the VIN range for the recall is
JACDH58V7N7900012 - JACDJ58V5S7906162, and my VIN is:
JACDJ58V4S7921576,
Then it stands to reason that my vehicle should be covered by this recall and the Isuzu guy I spoke to was wrong. Thanks for your help, I'll give them another call. If they still don't budge, I'll follow your suggestions.
Thanks again,
http://www.carspace.com/atfdmike/.59a21059
http://www.carspace.com/atfdmike/.59a2105e
Thanks again for your help!
http://www.carspace.com/atfdmike/.59a212fe
To adjust to factory specs, do the following after you complete repairs, refer to diagram showing cable adjusting nuts and:
Loosen adjusting nut.
Lock throttle valve fully closed and pull outer cable.
Adjust nut "B" so that clearance is as shown.
Push nut "B" against bracket and tighten nut "A" to lock cable.
I hope this information helps you. You may well need to spend quite some time to determine which part is binding and then fix it. It is too dangerous, as you know, not to do it right. Best of Luck!
Thanks for any advise
This is a lot of info, but basically you have to be sure exactly what the 97 is doing. Can you tell by driving it if the transfer case is in 4High, ie: at a slow speed does the trupr kind of hop and struggle around tight corners on dry pavement which would indicate the transfer case and hubs are both in 4High and engaged? Also, you might try putting the 97 in to 4Low and driving it a little and then shifting to 2High to see if that solves the problem. While there are some differences between automatic trans and manual trans, the transfer case shifter appears to work the same. Also, manual and automatic hubs were available on the 97, and you do not indicate what you have. Be patient and methodical in analysing what you have and if you still cannot figure out what is going on, then maybe someone else here has experienced your problem and will have time to write. Good luck with it!
I make a point of using my Trooper's 4x4 modes once a month just as a regulat preventative maintenance.
What other maintenance or repair or symptoms have occured recently or in the last mements the engine actually was running? I nice summary will make it easier to get the collective brains reading this discussion engaged.
http://www.carspace.com/atfdmike/.59a2a7cd and which is under the hood on your trupr.
Turn key ON. Fuel pressure should be 245 kPa (35 psi).
Assuming there is fuel pressure, then ignition is next to check. You can simply disconnect a spark plug wire to see if you are getting a spark jumping if you put a spark plug in the boot and ground the plug to the engine temporarily. If you get a strong spark, then it would then appear to be a timing problem. There is a sensor in the distributor that could fail that tells the ecm when to fire at the right time for each cylinder. No spark could also be a bad coil pack. There are specific ways to check on these if you get this far. From a mechanical perspective, the timing belt could have slipped,or broken; if it slipped, you might still see a spark, but it would be timed wrong. If it is broken, then the valves are not working and the distributor on your engine will not rotate either, which would also mean no spark. Timing belts and their adjuster are a common problem and the timing marks are on the belt and engine to check but you have to remove the belt covers which can be a pain, but necessary. These are some basic things to check and you can get back to us with your conclusions and we may be able to explore other areas. Please be careful, as spilled fuel from the pressure check can be ignited by the spark check, and rotating pulleys and fans can also be hazardous.
You are going to learn a lot while doing this, but approach it methodically and carefully, and assume you will have to spend some time with it and you should be able to figure it out. What I have outlined is the basic stuff that will give you more information than you have now. Any good mechanic will probably do these things as well before they can get a good sense of what is happening with your trupr. Let us know how things go!!
Sorry about being so wordy, all!
Idaho Gopher
Electronic Control Module (ECM)
Manual Trans 8161950790
Auto Trans 8161950690
To access trouble codes, a jumper lead must be fitted to ALDL connector. With the ignition "OFF" connect these two leads together. Turn ignition "ON" but do not start engine. "Check Engine" light will begin to flash code 12. Code 12 consists of one flash, a short pause, then two flashes. After a longer pause, code 12 will repeat two more times. This check indicates that the on-board diagnostic system is functioning. If no other codes are present, the cycle will repeat until the ignition is switched "OFF."
If trouble codes are stored in memory, the lowest number code will flash three times followed by the next higher code number until all stored codes have been displayed. The codes will then repeat in the same order until the test lead is disconnected.
If check engine is not blinking, and depending on how badly it failed the emissions test, a simple tuneup may do it, or O2 sensor and a cleanup on the EGR valve.
Pictures of ECMat http://www.carspace.com/atfdmike/.59a2d6a9!v=
http://www.carspace.com/atfdmike/.59a2d6ae!v=
REMOVAL
Negative battery cable
Lower trim panel at console (4 fasteners)
Air Conditioning Heater transfer tube
ABS controller electrical connector (1) (if equipt)
ABS controller (4 fasteners) (if equipt)
Four (4) fasteners for ECM bracket
ECM electrical connectors (2)
ECM from 'inder dash, bracket still attached
NOTE: To prevent possible Electronic Discharge damage to the ECM, Do not touch the connector pins or soldered components on the circuit board.
good luck hope this helps.
http://www.carspace.com/atfdmike/.59a2d6ef!v=
If I were approaching this, I would check for codes first, before trying to ID the ECM. If no codes,you could then do the basics like tuneup, EGR cleanup, O2 sensor.
After I did a little more checking, The part numbers in the previous post are for the DOHC engine. The SOHC cam original ecm part nos. are: Part OEM
Engine Control Module
Manual Trans
Federal 8161956960
California 8161951690
Auto Trans 8161951090
Hope this amateur advice helps. Let us know what you do.
When this was happening, I would occasionally get a CEL, but not all the time. It would give me a lean reading on both banks.
Tom
1.) replacing the shocks
2.) replacing the sway bar bushings
3.) adjusting the steering box play
4.) using tires that provide handling
All of these are inexpensive and make a safer vehicle to drive.
if it is a change this looks like a major job. ive done all the breaks and shocks, pretty mechanicaly inclined, but it looks like i have to get into removing rusted exsaust at the manifold. do i have to split the transfer case, or can transmission and case come out together??
As far as changing it out, you don't have to split the cases, but you will have to remove crossmembers, drive shafts from tcase,Exhaust, slave cyl., shifter knob,trans harness, etc; to effect removal and repair. If you end up going with changing it yourself, there are a couple of things you should do before completely disassembling the clutch. Let us know and the info should follow. One guys opinion, good luck.
my 95 trooper sunroof stopped working. it worked on and off for a while now it will not work with the button only manually. i checked the fuses and the windows and mirrors work. any ideas?
Also, my tranny slips sometimes just as I start up. If I back out on a hill then shift into drive to go up the hill the slip happens, not much but enough to notice. The fluid and filter was changed as required. I really do not want to have a tech dig around in it or on it until I get to Colorado. The dealership in Boulder has a really good tech. Any thoughts?
Trooper spark plug Denso
NGK PFR5G-11
Manual:
K16PR-P11
PK16PR11
RC10PYP4
Also, beware the rubber boot that fits between the coil and plug...many of these are somewhat stuck and you can tear that if you pull too hard..something over $100 I hear since you have to buy the boot and coil as a unit. I had one that just would not come off..then I thought of something...using a small air compressor and an pointed adapter that came with it (for use to blow up air mattresses, etc.) I put the adapter down the center hole and turned on the air...the boot just popped right off with no problem. (They stick to the top of the plug.)
Also, I think it was the number 6 plug...to get to the two screws that hold the coil on I had to use a little 90* screwdriver...not much room..a flex adapter might be helpful.
Good luck,
Bill
BTW, the Champions were between $4 & $5 each at Walmart, Autozone, Napa, etc.
http://www.carspace.com/atfdmike/.59a34a31!v=
for you. Aside from the main switch, there are a couple of limit switches mounted by the track the glass moves in that must work correctly or they can stop the motor from engaging. They are there for safety. If I was checking this, I would see that they are not jammed and are free to move or function. If they check all right, there is a solid state module that conrols the sunroof from the commands from the switch. I don't think you can do much with this, but I would insure that everything else works as designed before changing it. It is probably expensive and hard to find used. Hope this helps, maybe someone else has actually worked on one and will post.
Grey Eagle
Thanks for you help.
Grey Eagle
1) Is the engine an interference design? Timing belt intervals are 100K on a 1999 if I recall.
2) I often get a lumpy and uneven idle but the engine smooths right out once it's above idle speed. I seem to remember that these were prone to a gasket failure (but I can't recall which one). O2 sensor? Other thoughts?
Sean Reid
My 2001 Trooper has had a lumpy idle as you describe, it was a faulty EGR valve, the port where the valve mounts must be scraped clean for a replacement to be most effective. EGR valve is a couple inches in diameter and hieght on the top of the engine at the fire wall end on the passenger side in the USA. Labor was about as much as the new EGR valve by my Isuzu specialist mechanic. I was told that if I let the EGR valve get worse eventually it would no idle at all.
I also had to replace the intake manifold gaskets since in the 2001 model year they tend to go bad after 80K miles, that was another few hundred dollars. While leaking air into the engine at the manifold gasket leak idle smoothness can be effected and dirt can be pulled into the engine.
I drive my Troopers the greater of 200K miles or 10 years, and I keep up with the maintenance so they keep running like new the whole way. 1984 Trooper new $11K, 1995 Trooper new $22K, 2001 Trooper 30K miles $13K, so $46K total for three Troopers with a combined 425K miles so far (the 1995 was rear ended and totalled at only 140K).
I remember you. Thanks very much for the response. I'll have the EGR valve checked. Thanks very much.
Cheers,
Sean
However, consider the cause of the problem also. Ask when was the last time the power steering fluid was changed? If it never has been changed, you might only have to adjust the slop out and change the power steering fluid for a long service life. There is a chance that the steering box has to be replaced, from a junk yard part probably for a few hundred dollars installed I am guessing. Power steering fluid change required to take apart a hose fitting, the labor involved will make the bill from your mechanic $50 to $80 I am guessing.
Ask also has the steering wheel been removed and replaced? If so, why? That can cause the steering wheel not to be straight with the wheels.
If you change out the steering gear, you will probably need to have it aligned again, but it is cheaper to do the alignment now and see if it helps than to just change the gear. I had an alignment and new tires done on mine and the difference was enough to make the steering much more satisfactory. Good luck.
