Pat.
1. The Hidden Hitch seems to be a favorite. Is there a good place to pick one up on-line? How difficult are they to install? For reference, I can tear a AC up inside and out but generally am lacking the Mr. Goodwrench gene.
2. I have a factory Yakima roof rack installed that, according to the "towers", is for skis and snow boards only. Since I live in Las Vegas and there's not much snow in the desert, this does me no good. Any idea how I can remove these towers and install a fully-functioning rack? Anyone want to buy a ski/snowboard rack?
3. When I hit aboout 70 MPH on the freeway, I get a lot of wind noise that sounds like it is coming from the rear of the driver's door frame. Normal?
4. I miss not having a center armrest - this is the only thing I don't like about the S trim. Is there any way to add one aftermarket?
5. What happens if I engage TOD but then exceed 60 MPH with TOD on? What happens if I hit the TOD button while going above 60 MPH (as I almost did this weekend out of habit when I meant to hit the cruise control)?
Thanks for any help. I never thought I wanted an evil SUV, but my Trooper has convinced me otherwise.
video clip
Steve
-mike
http://isuzu-suvs.com
I'll have to check for the wind noise, but I regularly travel at 75mph no noticeable noise, except for my front bug shield that used to slap against the fenders. I'm working on replacing it with a lund unit.
-mike
As to the wind noise, I have none in a 1999.
As to the Yakima rack - two words Mount Charleston. But then again if you don't ski you don't ski.
An add-on armrest that works seems to be a mirage. Lots of people want one, including me, but no one reports back that they have installed one that they are happy with. I suspect the problem is that the seat has to be designed with a lot of internal support in order to accept an armrest. I doubt that the S model seats have the same internal structure as the Trooper seats with the armrests. Thus, we cannot simply add on an armrest.
Hidden hitch is very easy to install. I did it with my buddy, took about 1/2hr-1hr and I'm not mechnically inclined at all. I think it takes 3 bolts on one side and 2 on the other. A tie-down brack has to be removed(bolt removal) and a tow-hook also needs to be removed. I put the tow hook in the front so I have 2 in the front now.
-mike
-mike
Also, is there anything wrong with the Isuzu hitch? I was going to try to make a deal that includes the hitch.
Charles
Got a couple questions. I saw on a post by paisan about the RPM's at about 70-75 mph. Did I see 2500 rpm?? That seems quite low to me. At these speeds my 97' hits about 2900-3000. Is there that much gearing differences in the year models? What RPM's were you running at 115 mph?
Here's another FYI....I was reading an article about fuel filters and replacement frequency's in a Mechanics Journal. The article, written by a mechanic, stated that he had seen fuel pumps pulling 18 amps, on high milage cars. Said that after a fuel filter change the current draw went down to about 9 amps. This was causing premature failure of fuel pumps in his opinion. Well I decided to change my filter since I've got 55000 miles on the Trooper. Typically I wouldn't do this unless the vehicle hesitated under full acceleration, symptom of lack of fuel delivery. When I finally got the hoses off it, I found it to clean as a whistle! Probably a tribute to better refining plants these days. Anyway, it appears I may have some air entrained in the system now, the Trooper has started having surging spells all of a sudden. Just thought I'd post this for your consideration.
Happy Trooping!!
BSMART - At 75 MPH, it's at 2700 RPM for me. I have 49k on my stock tires and the circumference is smaller than new, I don't know how much of that is a factor.
The 3.5l probably helps (that's the main difference between the 97 and 98->01)
I went for the LS because:
Moonroof
Monotone Paint
Upgraded Seats
In-glass Antenna and Rear In-glass tinting
As for the hitch, if you can get it included go for it, but the Hidden hitch is truely hidden, which the stock OEM one is not hidden. But if you can get it for free go for it, if not the hidden hitch is about $125 from JC Whitney.
-mike
Cdanschwartz- Could you give me a heads up what dealer{s} on the island are selling it for that price.
Charlie
-mike
I've got the 58" round bar Yakima rack with Q-towers. These racks have clips which cinch them onto the underside top of the door frame - one set goes over the front doors and one bar goes over the rear doors. This has the rack mounted towards the front and not the back like the factory rack. With tons of attachments possible, you can load any gear. Takes about 2 mins. to install/remove. I normally drive without the racks to prevent wind noise & better garage clearence, although with mounts and stock ground clearance I can still fit under 6' 5". I highly recommend this although it is extremely expensive.
Bike rack: Thule swing arm space station module. I had the cheaper four post hitch, but after the pin worked loose and it dropped damaging four bikes, I went with the mac-daddy. This rack holds four bikes and has a double hinged "box" which allows the rack to pull away from the vehicle with bikes mounted to provide access to open the rear doors. I keep this permanently mounted since it locks to my hitch. Also expensive but you get what you pay for.
Charles, if you have a trade, I'll send you to one place. If not, I'll send you to another.
Charlie
-mike
-mike
I have a 2WD 2000 Trooper LTD, and live in Nashville. We get 5-10 snow/ice days here per year, and last winter I drove in it several times. I found the Troop handled better than my wife's 98 Nissan Maxima, which is a front wheel drive.
The WINTER setting does a good job getting you started without too much wheel spin. ABS helps you stop on top of packed snow. Coming out of our neighborhood, which is a left turn coming up a moderate hill onto another hill, the back end would kick out slightly, but it was controllable by steering into the skid. I think the TIRES help a lot, the stock bridgstones are knobby and just right for snow pack.
On ICE, all bets are off. I played around in some ice patches, but there is just nothing you can do there.
I think Ohio maintains their roads much better than Tennessee, and you'll find the 2WD does a good job there. You should hang onto it through a winter and see how it does before making a costly change. The value of your car has already dropped, so rather than realize that loss by selling, I would keep it through a winter up there, and see if it meets your needs.
Andy
-mike
Charlie
http://www.isuzudealers.com/
-mike
And speaking of Bells and Whistles, I am still waffling on selling my '99 Trooper LTD, powered heated leather seats, powered heated mirrors, moonroof, 6 CD changer, trailer hitch, the works. 34.5k miles, Mobil 1 synthetic, never smoked in, never wrecked, never off road. I now have a good commuter car to replace it, but come to think of it, they do look nice together. I will consider any rational offer. Thanks.
-Ken
(Northern Virginia location)
ken_salen@hotmail.com
I'll be passing through there tonight in the am.
-mike
2004 Rodeo (SUV)
Isuzu says the next Rodeo will NOT be a rebadged next-generation Chevy TrailBlazer off the GMT360 platform. Rather, the company indicates it will go with its own design, retaining body-on-frame truck construction and a range of four- and six-cylinder engines.
Maybe the Trooper's safe from GM?
-mike
Jim
I'm up to 1600 miles on my new 2001 Trooper S. Isn't it better to go ahead and change out the first oil now than wait for the 3000 mile mark? Isn't it best to get those nasty break-in engine shavings out of the engine? Or is that a myth?
Also, is the Mobil 1 worth the investment? The guy who bought my Millenia said that synthetic oil has the downside that it never gets dirty, and therefore, he reasoned that all that black stuff stays in your engine rather than coming out when you change your oil. I always thought that the oil turns black or dark because it was breaking down.
I think that I'll try to keep this truck for a long time. I plan on towing a pop-up camper a few times per year and my wife will use it for daily shopping and driving the kids.
I think the Isuzu is a good value given the utility and the warranty. I'll keep you posted on how it holds up.
Second, the inside of your engine will be much cleaner with synthetic, because synthetic effectively doesn't break down. With dino oil, the sludge that builds up in an engine is due to breakdown of the molecule chains, and the burn-off of the lighter fractions. Dino oil is a hodgepodge of molecule sizes, while synthetic molecules are basically uniform size. Another effect of lighter fraction burn off is that the viscosity of dino oil will thicken over time, while synthetic will remain the same indefinitely.
I could go on, but tired of typing...let me know if you have any more questions. You can also read back on this forum...this topic has been discussed periodically before.
I think with today's manufacturing standards there is little likelihood that the engine has much in the way of shavings. Nor does it come with breakin oil that must be changed very early on. That being said, for very few extra bucks why not do the first oil change early just in case? FWIW I did mine early and found no metal bits on the magnetic drain plug.
As for Mobil 1, many people swear by it. However many of them claim that you should not use Mobil 1 for the first several changes. As to the "logic" that Mobil 1 is bad because your oil stays clean longer, how absurd. If your friend really believes that draining out really dirty oil is the way to go just tell him to do 50,000 miles oil changes.
Happy Trooping!!
I've got a related question or two about other things. 1st for those of you with leather interiors, what are you using on the leather to keep it soft and supple? And for those of you with the colored plastic flares on the wheel wells of your Troopers, what are you using on them and your bumper covers, to clean them after a good handwashing?
Charles
BUT..... I think my wife is at the end of her rope when it comes to the A/C . We're in Phoenix, AZ and it just doesn't cut the mustard when temps hit 105 to 115 degrees out. A trip to a mechanic confirmed it's putting out cold air (44 degrees), but just not enough volume. I'd just tough out the summer months if it weren't for our 15 month old daughter. We worry that she's not getting enough cool air in the back. I know the above mentioned temps are really hot, but our BMW and Mazda Protege do fine.
Any suggestions to boost the A/C output? Are the newer Troopers better?
Lee
Just curious, is that the going price for the Trooper? it seems really low - either they're trying to get rid of them year end or you got a GREAT deal. Well probably both. How'd you do it?
Congratulations on your new ride.
