The price, $12,500, sounds especially great!! You mentioned that that 1998 drove better than the new Troopers --- that is the same observation I had before I found my new 1999 Trooper. I remember how great a 1995 LS Trooper drove and how wormy a new 1999 S Trooper drove. Could have been the type of tires on that 1995 I drove and on the 1998 you are considering.
-mike
Isuzu changes the "packages" every year and it's tough to know which year they added what to which trim line.
Any info would be helpful, thanks.
Happy Trooping !! :-)
-mike
If the car is really under warranty, and nothing has been excluded due to neglect or abuse, it could still be a good deal. But check carefully to see if the car has been in an accident or was previously stolen and recovered. That could explain everything.
If you do need to adjust the front ride height, there are two adjustment cam bolts near the ends of the front torsion bars, located about midway back behind each rocker panel. Crank them clockwise to raise, roughly one quarter inch per full turn. Usually turns pretty easy with a breaker bar and a 27mm socket, at least on newer rust-free vehicles.
So, what are the complaints about? It doesn't cool down fast enough upon initial start-up?
2) Ride height shouldn't be effected by the shocks signficantly. The weight is held by the springs. Unless your rear shocks were totally shot, which is possible.
-mike
It's down currently. Got hit with code-red, but it'll be back tonight. Had to get another HD.
-mike
The A/C absolutely sucks for short trips.
David
-mike
Mine is a being hosted by a free hosting service.
Or, is it how I get connected to the Internet?
-mike
Do I have an unusual Trooper? Do the 1995's have better A/C than newer Troopers? I suspect that a lot of cost cutting has been done over the years, the 2wd Trooper is a failed cost savings. If they made limited slip standard on 2wd they could have sold some, but instead limited slip was not even avaiable on 2wd Troopers. Sounds like a bean counter accidentally got in on the decision process where an engineer should have been. 2wd Trooper would have been a great place to introduce an awsome clutchless limited slip like the Torsen-Gleason which is all gears and no special maintenance.
I told my wife about the paison rumor of the 2003 Trooper being a re-badged Tahoe or Suburban. She suggested (she suggested!) that I should get a 2002 Trooper instead of my usual 200K miles and 10 years minimum between new Troopers.
Is my 1995 Trooper better than a 2002 Trooper? Is the A/C better? What else might have been cost reduced?
If they make the Trooper a Tahoe, will they also introduce the GBX? The Isuzu web site lists the GBX with and ultra clean 3.0L 4cyl. Diesel. That is the engine that I want and I think I would like the GBX's practicality.
Robert
The GBX will not ever be.
Long live the real troopers!
-mike
You must be running NT on your website if you are getting the Code Red virus. Last week my home PC, Windows 98, was infected with the Sir Cam 2 virus -- This is the second time my PC has gotten infected. Good luck.
-mike
The specs indicate a real on and offroad truck. The wheels are large however.
You could check that on one of the engine compartment stickers, I believe, or perhaps the owners manual.
One of the downsides to R-12 these days is the cost of recharge. R-12 costs something like 10 to 20 times what HC-134a does now...
-mike
-mike
Also, yup the 99's have regular AC and 2000+ have the push button climate conttrolled ones.
As for efficiency, my 99 is "ok" here in Texas where its been over 100 for about 20 days now. Would I like it to be cooler...certainly, but its not terrible by any means, not anything I'd rule the vehicle out for if it was part of a buying decision.
http://edmunds.yellowbrix.com/pages/edmunds/Story.nsp?story_id=22749829&ID=edmunds
The reason the helper fan *may* help out the A/C is because the A/C condenser cooler is right in front of the radiator, between that fan and the radiator. If there is a fan blowing directly on the condenser it can help it.
-mike
PS: http://isuzu-suvs.com is back up
I bet you can pick up a brand new one from e-bay or someone on here that is upgrading to a custome unit, and will likely sell you the stock one for relatively cheap. There are no known 3rd party cd-players that work with the Isuzu head unit, at least not ones that are controlled by the stereo.
-mike
There is an aftermarket single CD player that is sold regularly on ebay under Isuzu Trooper. Supposedly it works the the factory Isuzu head unit and plugs into the head unit with no cutting of wires. It usually goes for about $200. The dealers usually sell the Isuzu 6-CD indash changer for about $700. If St. Charles has that unit for $400. That's not bad. But of course it would be better to get one from a Trooper owner for less. I wish I would have negociated for a CD changer when I bought my 2001. But hindsight is 20-20.
If anyone here has an Isuzu in-dash CD player or even better, a changer they want to sell that works with 2001 head unit, just email me. I would be interested. I believe 1998-2001 head units are all the same.
Gary
tntmyth@bellsouth.net
Or, for $200, you can buy an in-dash 4 disk changer, made by Sanyo/Excedio. This unit fits exactly in the dash where the factory radio went, and used the existing brackets. If purchased from Crutchfield, it comes with a connector that uses the factory wiring with no cutting. I bought and installed this unit and the sound is night and day better than the factory unit.
BTW the factory unit is an el-cheapo made by Fujitsu Ten. I was told by St. Charles Isuzu that the factory add-on CD is also an el-cheapo - except that it costs a lot.
And I don't believe humidity has anything to do with how efficient an auto AC is, because excess heat is dumped via the condensor located in front of the radiator, humidity has no effect on metal to air heat transfer...
But having said that, AC may subjectively FEEL like it is doing more in humid climates, because of the humidity (condensation) removed from the air when cooling it (which is why your vehicle drools water underneath when the AC is on), in addition to the temperature decrease.
Just passed the first three months and took the Troop' in for the 2nd service/oil change with about 8,200 miles on board...went smooth and quick and was happily back on my way...
Until the next day when that pesky ol' REDUCED POWER light came on with his friend CHECK ENGINE...needless to say I had begun to wonder if this was just some kind of a joke or if the lights were keyed into be idiot lights warning of the need to do an oil change (which had just been done, but maybe the numnut service dude had forgotten to flip a switch or something, right?)...turns out that something blew internally in the "accelerator sensor beneath the pedal" and they've ordered in a new part which they will install tomorrow morning....which is a good thing, b/c I don't mind as long as it's fixed...driving this puppy around on REDUCED POWER is like trying to tow a 5,000 lb trailer with a 4-cylinder puddle jumper up-hill. So, now all that remains is for me to attempt to deduce if I just lucked out with a bad part or if it's the weight of my size 13s that broke the sucker or if I actually move faster off a light than Paisan...*grin*...which I somehow doubt...
Anyway, aside from that, I'm lovin' T3 (as evidenced by the mileage - I've gotta slow down or I'm gonna pass 30k in the first year)...but I just figured I'd keep ya'll posted since I seem to be the only one who ever gets to see these lights...btw, it's a 2001 Trooper LTD 4x4 Black w/Gold Package for anyone who missed the much earlier posts...
Hope ya'll are truckin' well...---Cobbo
... so that means they will probably be discounting them even more to get them out the door.
Comments?
