Jim
-mike
I addressed a fax to them stating exactly the model I wanted, any of 3 colors, <300 miles on the odo. I had my spreadsheet laying out their cost, less holdback. I gave them back a 3% profit, and I was willing to take delivery Saturday (this was on a Tuesday). I also told them I had my own financing arranged, and no trade in, and the final deal was subject to my inspecting the car.
4 of the dealers ignored me, 4 called or faxed - wanting to "sit down and talk", and 2 faxed me offers (out the door, sales invoices). One of them met my price, so I signed it, faxed it back, and took delivery Saturday. Took about 25 minutes at the dealership.
I had to drive about 2 hours to pick it up, which I calculate saved me $2,000 over the Nashville dealer. I ended up getting my first color choice too - Moonmist grey mica.
Long story short - never sit down with a salesperson. They'll win if they can wear you down. I came to these dealers as an easy sale - I wasn't going to tie up one of their salesmen for 4 hours, and I would take a truck out of inventory that they might be having trouble moving. Isuzu is usually not a fast moving inventory, so you should be able to pull a major deal without spending the afternoon tearing your hair out.
I'm still loving my truck, now with almost 24K miles on it. I'm changing oil and R&B the tires religiously. I would love to see 200K out of it before it goes. We'll see!
Michael
The mechanics, at trooper dealer, said this truck has a fan in that area so the noise is normal when I turn the fan on.
Is any one noticed this noise when turn on the fan?
-mike
BTW, today is a thrilling day for me. I took the Trooper back to the dealer for a realignment, no-charge of course. And they finally got it perfectly straight. I guess I was lucky to get an alignment guy who really knew how to align trucks. It now goes perfectly straight with the steering wheel also straight, even a high speeds on the freeway. It's like, driving the Trooper, which was already great, has reached an all time high. I'm so tickled I could spit! I was worried that that was just how the truck is and that I would just have to take the bad with the good....Well thanks for the replies on the alignment issue. I will probably take the Trooper out for a drive tonight just for the thrill.
Second, sometimes I feel (or hear) vibration in the back of the truck. Is this normal. It would be perfect for a colicy child but my children has past that stage.
Third, when I turn the truck on....I see a very light smoke from the tailpipe. It will eventually stop but it's just the fact that in 100 degree weather, I can see this smoke.
Lastly, how do I remove my bug reflector. It seems like the wind pushes me side to side with this thing. Like I'm fighting against gravity or something. Is it me or am I just paranoid? Please help a single mom out.
thanks and sorry for the lenghty post.
- Troopers are nto that peppy compared to a car
- your Trooper should be able to run perfectly well on 87 octane gas
- that vibration might be because of out of round tires - SUV tires must be rotated religiously.
-My trooper hauls pretty good. Don't forget you are pushing 5000lbs from a dead stop. Your honda was probably 2500-2700 at best. I have had my trooper up to 115mph w/o a problem, and passing on the highway is good, try engaging the "power" button for the tranny, it helps
-I run 87 only in my truck, works fine
-Tires do need to be rotated ever 5K miles, religiously.
-mike
Also, try to avoid turning it on and off quickly. starting a vehicle up to move it in the driveway releases condensation (white smoke at startup)...shutting it off leaves it in the exhaust system, this can cause rust on the inside of the exhaust manifold. I don't think this is that, but something I have read about before.
Hmmm power button. I don't think I have that. I do have the winter mode button. Maybe I do and just didn't realize it was there. I'll check.
Found out my service will cost around $600. I'm sure that doesn't include the timing belt. How long do you think my truck will last?? My Honda had 216k miles when I traded it in and someone bought it within that week. I still see it on the road locally.
The power button should be right next to the winter button, I can almost guarantee it's there.
Oil consumption has been noticed by some of us, as much as 1Q per 1000 miles. My guess is that the place that did your oil change didn't put in enough oil, combined with the fact that these trucks do burn oil.
A steady on check engine light indicates a problem with the emissions system, a blinking one is a "true" engine problem.
These trucks are known to go 200K+ miles so I wouldn't worry about it lasting that long, although they do need some TLC like tire rotations, and oil checks every-other fuel-up.
Find out what's included for $600, also you shouldn't need a timing belt til 80 or 100K IIRC.
-mike
Full service = $600? What mileage service is that. My last service, the 15k/22.5k service cost me $212.19. BUT, I do remember when I had my older 1989 Trooper I called about the service for it and it was a very high amount like your $600 figure.
Yes, you got to rotate those tires. I got mine messed up by not rotating them and they have a noticable roar.
Troopers are nice vehicles and I really enjoy mine even though it does not see much off road activity. Good luck with the SLX.
BTW, how many miles to you have on your SLX?
However, if the engine shutdown due to lack of lubrication that would seem to indicate that some real damage could have been done. The point being that you might want to document this as much as possible NOW just in case. For example make sure you ask the shop to check to for any damage. If they find some and document it NOW you will be in a much better position when trying to get the oil change place to fix the problems they caused. Even if no damage is found you still might want to send a letter to the oil change place. Note how the car died because they failed to properly refill the oil and that you will get back to them regarding damages.
Just some questions and suggestions. I would hate to see someone get stuck 6 months from now with a major engine rebuild and no evidence to use to hammer the oil change place into paying for their mistake.
-mike
For example, I had an alignment problem, the automall and 2 Firestone service centers could not eliminate a pull to the right after several visits to each. My new Isuzu Dealer took one trip and an hour wait, have not had a problem with alignment since.
I was ordering my RANCHO 9000's from a retailer this p.m. He asked me why I was ordering Rancho's for my Trooper. I told him that my initial preference was Bilstein, but they did not have them for the 98-01 yrs. He said that I would be MUCH happier with KYB's Monomax shocks instead. "These are true gas performance shocks. Rancho 9000's are hydraulic and NOT gas, which is 30 year old technology." Also, the GM at my shop said that "the Rancho's are gonna feel rock hard."
Can anyone comment as to the validity or significance of these statements?
-mike
Paisan, I sent you a bunch of pictures yesterday, let me know if you don't get them.
-mike
-mike
http://isuzu-suvs.com/bighorn/bh12.html
-mike
-mike
I know the standard term OEM "Original Equipment Manufacturer," so what is OME?
I should have taken my truck to an Acura dealership. I took it to a tune-up clinic place. I feel they didn't put enough oil in my truck. From now on, I will go behind the next mechanic that services my truck.
I am at 61k miles. The $600 doesn't include timing belt.
I will take you all advice and have the engine checked. Especiallly since I got the extendent warrantee. Guaranteed 100k miles. Bumper to bumper, etc...
Is $600 steep?
Don't jump on me....I'm learning.
-mike
1. What seat covers do you folks favor for the new generation Trooper?
2. I realize there are general discussions on this one, but specifically what paint protector are you using successfully with the newer Troopers?
3. From what I can gather the Lund bug shield seems to be favored. Is that correct and is the Concept II the one that you are using?
George
I certainly agree with your decision to get the engine checked. I also encourage you to give careful thought about what you tell them when you take the car in. For example, if you start with "my car ran out of oil and died" I think that could prejudice their thinking too much and maybe cause them to do too narrow of a diagnostic appraisal. In addition, it may also trigger them into automatically, regardless of the circumstances, rejecting any sort of warranty claim based on your admitted failure (that is how they will spin the situation) to maintain proper oil levels.
Instead you may want to focus on telling them the present symptoms - smoke, lack of power, hesitation, whatever else you have. Let them tell you what is wrong and whether it is a covered warranty repair. If not a covered repair ask them what could have caused the problem(s) and if low/lack of oil is the cause. If the latter is the case then ask them to put that in writing and use that as the ammo to try and get the oil change place to pay for the non-warranty covered damage.
Again, this is just my attempt at helpful advice but like I noted maybe I am misunderstanding the facts of your situation. Good luck.
