Yesterday I had the tires cross rotated and the tire shop recommended a front end alignment - all this at a cost of $49.00 -- not bad I thought.
Now the tire noise has moved to the rear but a little less than a time before when I had the bad tires on the rear.
BUT, one thing I did notice after this is that my Trooper's steering is much less "wormy" and much more enjoyable to drive. I've read others talk about the "wormy" steering and thought you would like this observation.
Energy Sway bar Greasable bushing.
Part Number 9-5157 13/16" = 20.63mm
Part Number 9-5163 28mm
I have ordered them and still waiting. My main question is: Should I get the metal bracket with bolt size P# 9-5125(Min 2-1/6" Max 2-7/8") or P#5-5157 (Min 2-9/16" Max 3-5/8") for the rear sway bar? Any comment appreciated.
I am appealing for help with a problem that has just popped up and it appears to be electrical. The engine ignition (or that's my best guess so far) cuts out while driving momentarily (sometimes as long as a second or two, but usually just a hickup) and the temperature gauge twitches towards high and the u/s light twitches between normal illumination and quite bright. It sounds to me as though this could be related to an electrical recall having to do with the PCM ground which apparently did not cover my VIN. Has anyone else had similar problems?
OK, Here's the update on the electrical issue. First let me mention that the starter was also involved. At the time I wrote the first post I had just replaced the starter and hadn't fully comprehended the fact that it was all related until the car wouldn't start again two days later. It was not the starter. It turns out that my guess in the last post was exactly correct. The Ground (P10) was loose and is known to cause all manner of electrical chaos including computer glitches (fuel cutoff while driving), instrumentation glitches and starter failure. There was a recall on very early VIN's (I bought my truck within weeks of the '98 hitting the showroom floor and my VIN was too late to be included in the recall) and the factory "fixed" the problem, which apparently means that it takes much longer to show up now than it did before. This problem is also detailed in a TSB (sorry, don't know which one) which was released last august (2000) and covers all Amigos 1998-2000 (and I would guess this problem will continue into more model years) and may also affect ground P6. If you experience these problems (the first indication is that of a failed starter, which I have been told virtually NEVER actually happens to an Isuzu) Ask your mechanic to check these two grounds FIRST before doing anything else. You'd be surprised at the difference in the repair bill between tightening a bolt and spending 10-12 hours tracking a problem because the service staff doesn't ever actully read the TSB's Isuzu sends them.
That is my best guess ... good luck!
-Ryan
I haven't heard too many aftermarket companies much lower than that. I feel good having the "Isuzu" brand unit, even though others may be of higher quality.
I had to make a couple of trips to Home Depot. 1st I bought 1/4" (hole diameter) steel washers to go in front of the stock locking washers. They didn't fit. So I went back and got the 5/16" diameter, flat, steel washers and they worked beautifully. They came 5/pkg (brown & clear plastic bag).
As for the brackets, use the ones that come with the kit.
Hope this helps... and you will DEFINITELY notice a difference!
I haven't found any single web site with the definitive information, but carpoint is very good.
-mike
-mike
PS: Motor Trend thinks the next Trooper will be an Isuzu product, all hope isn't lost yet! http://www.motortrend.com/future/2002.html
I go to a car show at the Boston expo center each year in Nov. They've always had the next year's trooper there.
-mike
for less. Iwas quoated $20600 fora demo or $21200 new. I ended up buying a
used 2001 S w/ 4wd and auto for $18400. It was an Alamo rental w/ 10000
miles. Mark P
-mike
Made a trip and have a little update on my differential "whine". Trip went great, Troop drove out great. I really like the feel of this vehicle on the open road. Anyway, I pushed it a bit this time feeling out how that rear end is acting.
It is a LSD limited slip diffy, and it is obviously got a different feel and sound than a non-LSD. The thing I noticed this trip is the sound increases from about 55 mph to about 72 or so, then it turns into a slight vibration at about 75 and a significant vibration at 85 mph. Somewhere between 85 and 100 it seems to smooth back out. It's like you drive through trouble area somehow. Only trouble is you can't afford to drive those speeds very long, to many State Troopers out there to nail you! It would have to be most noisy and vibrant at about 70-80 mph. Darn the luck! O well, I think I will be talking to the dealer maintenance shop this week about seeing what is wrong. It will be under warranty a bit longer, so best to get it checked out. Anybody seen any post on ITOG having this kind of symptom?? Any help appreciated.
That poly bushing is going on my list of upgrades. Sounds like a good improvement for a minumum expense.
By the way, I talked with a owner of a Grand Cherokee, I think a 1999 or 2000, and he's very dis-satisified with it. It gets about 10-11 mpg and it has the 6 cylinder not the small V-8.
Happy Trooping!! ;-)
I think if Isuzu put together an SUV with that met the new aggressive safety standards that are out today, with a wider stance to completely, once and for all, debunk the rollover issues, they would seriously challenge some of the other SUV's in terms of sales figures. What I love about my truck, isn't what most buyers are looking for, Land Rover/Land Cruiser off-road abilities, at half the price. Most people want a Volvo Station Wagon, that sits higher than cars.
The LSD on my Trooper is very lose... Meaning that it will not engage unless I crank up on the E-braketo get it to engage. I may bring it to a dealer andhave em check it out though cause it should engage sooner than that.
-mike
-mike
Trooper
Exhibiting a traditional square profile, the Trooper — Isuzu’s
biggest SUV — gets a few minor changes for 2002. Privacy
glass and solar green UV-cut glass are now standard for the S
version, while a power moonroof has been added to the LS.
Also new in the LS is a digital clock with outside-temperature
display, a stopwatch, average-speed indication and a service
reminder. The Trooper Limited now offers Nakamichi premium
audio. The Trooper’s 215-hp, 3.5-liter V-6 engine teams with
either a rear-drive or four-wheel-drive transmission.
I now have about 2500 miles on my 2001 S. I mostly like the truck. I've taken it off-road up in the Catskills, and it was great. I also took it on the beach, and I noticed that I needed to use 4 wheel low rather than TOD if I wanted to go anywhere.
I do have a question about handling. I have yet to experience any loss of control whatsoever, even in the rain. What I am scared about and need to know is, will the Trooper give me any feedback before the rear end swings out or it tips?
In other words, I like to drive cars that tell me when they are about to do something nasty. I grew up with rear wheel drive and I like being about to slide the rear end every once in a while. So far, I'm driving the Trooper way too conservatively to do anything like that. I'm sure when winter comes, I can go to an empty parking lot and find out for myself. But I would like to hear what you experienced Trooper drivers think.
-mike
-mike
-mike
Copied from Kong's message:
#2003 of 2051 Polybush 28mm & 20mm by konghh Aug 30, 2001 (05:33 pm)
http://www.suspension.com/s.b.bushings.htm
