We have owned the above car since new, and were advised by the dealer that there were only 500 or 1000 of these cars ever sent to the U.S., and only in 1996. Since then, we've seen at least a half dozen in Colorado alone, and are wondering if the info given to us was really true. Can anyone help with this one? Also, we managed to break off our right front mudflap, and the dealer wants about $150 for a pair --only--. The aftermarket outfits we've consulted don't sell trooper parts. Any suggestions on this one?
I suspicion you might be on target on this idea. I go to the dealer tomorrow to get it checked out. I 'll report back what I find out. You folks with suspected too loose LSD, might want have an adjustment if I learn that this is what is wrong. To those with the 96' SE Trooper, I suspect you were getting a "snow job" on the rarity of that model. I believe it was a very popular color and as you say, there seems to be a lot of them on the road. They seem to be frequently seen on Ebay. Trooper parts are hard to find other than at the dealer. Comes along with the territory. Happy Trooping!! ;->
Made the trip to the ISUZU dealer in Little Rock today. Had them take a look at what is going on with this "whine" in the rear diffy. The technician scoped it out and said we will have to change out the ring and pinion. They aren't meshing up right and that is causing all the "singing" as he put it. Not a problem with the LSD itself. The rearend vibration at about 78 mph was a totally different issue. Looks like the brake rotors are warped. They are going to do all the work under warranty though. They were not sure about the rotors at first, but came back and said, "we will cover them too". That was good news to my ears! Total time spend at the shop about 2.5 hours. Not too bad, I thought. Bad news is, they have to order all the parts, so it will be another week or so before any real work starts. The vehicle will have to be left with them about 3 days to complete the job. I hope they can beat that time estimate. While I was there I got to take a good long look at a 97' shop manual. This diffy LSD is not a complicated device. There is nothing in there that can be adjusted other than by shim thickness. Thats part of what takes time after the repair work is done. It will be set up by spec. and then be driven to hear the results. If shims need to be replaced, it comes apart again for shim changeout, and another test drive etc etc. I have a few other things about this visit I'll post separately.
Took a good look at the Axiom while at the dealer today. Man, what is ISUZU thinking?? Looks like interior room and comfort, is taking a back seat to flashy looks. I doubt anyone over 5'10" would sit comfortably in one. They look cool from the outside, but that interior must have been designed by somebody smoking wacky weed. And the colors leave something to be desired. I don't see myself transitioning to one for sure. I just don't get it, less car for more money. Oh, more flash, less car for the money. I've got a feeling they aren't selling very well. There were a bunch of them on the lot, even more than there were Rodeo's. Hardly any Troopers to look at. I was really disappointed. They had only 4 units in the whole place. One of each model level and an additonal anniversary model?? Not much has changed since about 96' except the front design. The window stickers ranged from $26853 on the S to $34685 on the Limited model. I was surprised, I didn't realize the S model has NO window tint whatsoever. That seems like a ripoff to me. The consolation was, they were having a $7500 price break offer on any model you picked. The other disappointment was, none of them were 4X4. All 2 wheel drive models. That really surprised me! If I'm not mistaken, a lot of the Axiom's were 2 wheel drive also! Looks like ISUZU is getting out of the 4 wheel drive business. I'll post a few other notes separately. Happy Trooping!! ;->
While at the dealer today, I invited myself to the shop and its library. You can learn a lot from a shop manual in a couple hours. I was like a kid in a candy store. I've got to get me one of these shop manuals for future reference. ISUZU puts good details in their manual, and lay it out so a 5th grader could use it! I looked at several things. The rear differential exploded view. A discription of trouble "sounds" and isolation techniques. "Whine" is actually a term used in the manual to describe specific trouble types. I also looked closely at the front axle layout and found that 4 wheel drive sensor I've been looking for. My 4X4 light doesn't come on when you go into 4 wheel drive. Now I know where it is and how to test it! I also looked at the wiring harness layout and found several possible things to check to see if I can isolate that voltage dip I'm seeing when quickly pressing the accelerator. Guys in the shop were very helpful about letting me look in their library. Overall I'd give them an A- rating so far. The minus is for the lady at the service counter, quite illiterate about what shes doing, and slow to boot. Thats it for now. Happy Trooping! ;-?
I have OME springs in the rear, and Rancho 9000 shocks. Using my Hidden Hitch, I towed my subaru XT6 on a dual axle u-haul trailer weighing about 5200lbs total. No problems, just make sure your tounge weight is correct. I had the tounge weight too high (engine in the front of car on front of trailer) and it severely pushed my rear end down (but I also had about 700-1000 lbs of cargo as well) Towed excellent, even got 11mpg @ 75-80mph.
Guys, overloading your Trooper (or any other vehicle) is asking for problems down the road at best and maybe a white-knuckle surprise at worst. The Trooper is rated to tow 5,000 lbs with a max hitch weight of 500 lbs. That's all models (at least for model year '01 - not sure about other years, but I suspect it's been that way for awhile). Keep in mind that the 500 lbs hitch weight counts as part of the ~1,000 lbs max cargo load (varies by trim level from around 1,160 for the S to 1,010 for the LS to 895 for the Limited). Passengers/driver, fuel, and anything you throw in the back also counts as cargo. FWIW, a full tank of gas is just over 100 lbs. If you figure two people @350 lbs, gas at 100 lbs, and a hitch load of 500 lbs, you're just about maxed out. Sure, you can exceed it some, but you're overloading the chassis, suspension, and drive train. If you do it very often, you'll most likely have to take Isuzu up on that 10yr/120k mile warranty. A good weight distributing hitch will help some, but you still can't (or at least sholdn't) exceed the front and rear Gross Axle Weight Ratings (GAWR) or vehicle's Gross Vehicle Weight Rating (GVWR). Check the sticker on the driver's door pillar for the limits (the rear GAWR is 3,085 lbs, IIRC). It's also a good idea to pump the tires up to max allowable pressure if you're towing any significant weight. How good of a hitch you get depends on how deep your pockets are. A top of the line Hensley weight distributing anti-sway hitch will run you around $2,500 (but they don't have a custom fit for the Trooper ;-( The best way to select the hitch is to decide what trailer and load you'll be towing and shop for a hitch that will safely handle it. It'll pay in the long run to get the best hitch - matched to your load - you can afford. It would also be a good investment to take your rig, once loaded and hitched up, to a truck scale and pay them to check your weights (front & rear axles, trailer tongue weight, and trailer weight. Suspension upgrades (shocks, springs, bushings, etc.) don't increase any of the above limits - it says so on page 9-3 of my owner's manual in a bright yellow caution sidebar. At least the tires aren't a problem. The 684's on my truck say max load limit is 2,094 lbs. Now way I'll come close to putting 4,000 lbs into the truck! Keep in mind the Trooper wheelbase is just over 108". A rule of thumb I've seen a couple of places says the ideal is a 115" wheelbase for a 20' trailer, increasing by about 4" for each additional foot of trailer. It quickly becomes impractical, but you get the idea. That's why the anti-sway devices help out. Also, independent rear suspension is better for towing than the leaf springs on the Trooper. Leaf springs translate lateral push from the trailer into twisting of the chassis, which wants to shove the rear end (rubber where it meets the road) around laterally. A large surface area, a little wind (say from a passing semi), and a winding road can make things squirrelly. IRS doesn't do it. I'm no trailer towing expert. Heck, I don't even play one on TV, but I have been doing a LOT or reading the last couple weeks. I'm in the market for a travel trailer (aka camping trailer) and am doing my homework just like I did before I bought my Trooper. I like to think I made a smart purchase on the truck and I'm trying to do the same by matching a trailer to it that it can handle. I really like the Trooper and don't want to abuse it and I sure don't want to endanger myself by over-extending the truck. I've narrowed it down to a couple of ultra-light trailers that run 3,500 to 4,000 lbs with a hitch weight of 350-400 lbs (dry weights). These trailers will carry a surprising amount of cargo, too. Some of them upwards of 1,800 lbs. With proper load balancing, I can carry quite a bit of stuff in the trailer and still stay under the 500/5,000 limits. I guess the bottom line is that it's your truck and your life. Use them as you see fit. HTH, Charlie
In all your research, you didn't realize that the Trooper doesn't (and hasn't since '92) had rear leaf springs? It has a rear 4-link Coil spring suspension.
I agree, normally if you tow on a 24x7 basis you should tow about 75-80% of the max trailer weight. Had I backed the car onto my trailer the tounge weight would have been 500 or less and would have towed much better. Also I'm not so sure of the IRS being better than Leaf springs. From what I've read rear leaf springs are actually better for towing, but you seem to have done your homework.
My 1995 Trooper-S has a single upper link from the top center of the differential housing and two lower links from the outer axle near the wheels. These three links all lead forward. The large verticle distance between these points and the way they are attached gives excelent leverage to counteract the opposite reaction of the axle to the tires pushing the road. The lower links resemble the traction bars they put on dragsters to counteract the twisting from turning the tires. The 4th link is the link from one side of the axle to the frame on the other side of the Trooper. Again the mounting angle gives this bar excellent leverage. I am impressed by how well thought out yet simple the Trooper rear suspension is. I am suprized that this has not been copied by other SUVs or trucks. There are coil springs holding it up and external to the springs the shocks are easy to change.
I am about to install the sway bar poly bushings. Where else on the Trooper suspension can Poly bushings be used? Has anyone installed all possible poly bushings? I imagine the road feel was excellent. Was there too much road feel, to rough a ride as a result? Thank You
to Paisan and everyone else for erring on the Trooper's rear suspension. I was going from what I had read in one of the RV'ing forums. Apparently the writer was talking about an older Trooper - he didn't say what year and I never thought to verify the info. Needless to say, I'm very happy to be wrong! I also want to apologize to anyone I offended with my earlier post. I've read it a couple of times and I'm afraid it comes off too strong. I'm not trying to tell anyone what to do but was just trying to share some info I've dug up. We drove down to Richmond, VA yesterday and made a deal on a 24 foot Trail Harbor travel trailer. Overall length, with trailer tongue, is 25'8". Dry weight of the trailer is 4,136 lbs with a dry hitch weight of 330 lbs. It's a dual axle unit and will carry a load of up to 3,194 lbs (which would drastically overload the truck). I can safely carry 800 lbs of gear and supplies and stay under the truck's 5,000 lbs limit. It is new, but a 2000 year model, with several options, so I got a good deal on it. It's identical to the 2001 Trail Bay model 24BH. If you're curious, you can see it at www.trail-lite.com. Yeah, trailer base models are marketed pretty much the way automobile base models are. Oh, you want air conditioning? An awning? Leveling jacks? A stereo system? Microwave? etc., etc. They're all extra cost options. It doesn't take long for that $10,500 base price to jump by 50% or more. The dealer will install the hitch, anti-sway and weight distribution, plus electric brake controller (including dash control) and set up the truck/trailer for $895. It's a bit pricey, but worth it to me. The hitch guy wasn't in yesterday, so the salesman took all the info on the truck and said the hitch guy will order the correct hitch (custom). It will be either a Reese or Easy Lift. These two hitches are rated in the top 5, with the Hensley Arrow generally regarded as #1. The Pull Tite and Draw Tite round out the top 5. These are hitches that are designed to allow for hookup of anti-sway and weight distribution that is strongly recommended for towing travel trailers. I was going to go with a Hidden Hitch, but not sure there is enough of the hitch exposed to allow for it. If you don't plan to tow anything with a relatively high center of gravity and a large surface area (makes a good sail), there's no real need to go with a hitch of this type. I may be going overboard, but since the truck's wheelbase is marginal for this size trailer, I'd rather be safe than sorry. Also, regarding my comment on suspension upgrades: What I didn't say was that even though they don't increase the payload, I think anything that improves road handling and vehicle control is well worth it. I plan to put on poly bushings and shocks (probably rancho 9000s), and may add progressive rate springs (OME), depending on how things go. I also am going to contact my Isuzu dealer and schedule the installation of a transmission cooler. BTW, on the 200 mile round trip to Richmond I got 19.3 mpg. That was at speeds between 60 and 70. The Virginia State Police were out in force, as there was heavy traffic going to a NASCAR race at the Richmond International Raceway. I saw a lot of people pulled over. I guess they think they should be out on the track, too, from the way some were driving ;-) Based on what I've read, I expect the mileage to drop to the 10mpg range pulling the trailer at highway speeds. I'll let you all know how it goes. Charlie
If you only need room for three people, you have a wide range of options. The 24' we are getting sleeps 4 adults and 2 children. If you're planning on towing it with a Trooper, I wouldn't go over 24' or 25', and pay close attention to the weights. Everything counts. Water, LP gas, options, truck's fuel, passengers, baggage, and so on. At least in this region (Mid-Atlantic), the dealers I visited (3) don't stock much in smaller trailers (18'-22'). I did see a 21' Palomino, but it weighs more than the 24' I settled on. I started with a search on "travel trailers" but that was too broad. I then did one on "ultra lite travel trailers" and that narrowed it down. Once I saw one I liked, I went to http://www.campersfactoryoutlet.com and was able to price it out, options included. They have a worksheet you can fill out for a quote. The price only jumped about $500 from 21' to 24', so once you get into a trailer, size doesn't make too big a difference on price. I'd say if you expect to pay $14,000 to $16,000 then you won't get sticker shock - and you'll have a very nice trailer that will serve you for several years. A popular small trailer that has a good reputation is the Casita. Trail-Lite (they make the Trail Harbor I'm getting) also has a good reputation and they offer smaller trailers. It appears that the campers factory outlet site will take your order and then have it built for you, so you could get (theoretically) any trailer you want, just the way you want it. You also can get a lot of good info (at least I did) by joining the forum at www.rv.net. If you register, you can post questions. As I said before, I found a 2000 model but it was still 'new' so I got a really good buy on it. List was ~$16,500 (I think just about all dealers will dicker same as a car dealer) and I got it for $12,600. I'm getting kinda far off topic for a Trooper discussion group, so if you have any other questions, just ping me at <charlesrodgers@earthlink.net>.
No problem, you had some good info. I agree, that if you are gonna be towing a big high trailer, a weight distributing hitch is the way to go, and get the best equipment possible with pro-install. I generally only tow my 17' 3000lb boat, so it doesn't even aproach the limits of the Trooper. If you get the tranny cooler installed, be sure to drop me an e-mail with price/part #s and I'll put it in the FAQ on http://isuzu-suvs.com
A friend of mine recently had a transmission cooler installed on his Honda Rodeo. It was a bright aluminum color - almost white - and it is directly behind the grill. The rest of the stuff behind the grill is black. So there is a great view white on black of a transmission cooler when you see the front of his Honda. You can see him coming a half mile away. His A/C has suffered a little from the transmission cooler getting first dibs on the cool air. I think it is worth asking for a black transmission cooler or getting it mounted somewhere out of site. By the way, Isuzu says the Trooper will tow all 5000 lbs. without any additional cooler. My buddy has a 3.2L in his Honda Rodeo and the automatic transmission, he says that it is a far better tow vehicle than the Jeep Grand Cherokee it replaced. Never overheats. I have a 1995 Trooper-S and pulling my 26 foot 4000 lb. boat is not problem, but I have a manual transmission so I can use any gear that does not lug the 3.2L SOHC 175hp engine. Please post on how well your Trooper tows that trailer.
Well, I just spoke with the Isuzu Service Manager at Brown's Buick-Isuzu in Fairfax, VA and he recommends NOT installing an auxillary transmission cooler as long as I stay within the towing limits of the vehicle. He said that they can put it on for me, but that the internal (to the radiator) transmission cooler is designed to handle towed loads up to the 5,000 limit. He said there are some things that can be done to increase that 5,000 limit but since I don't plan to exceed it, I didn't ask him what they would be. He said that I should have the auto trans serviced more frequently than the "normal usage" 30,000 mile interval - as often as 15,000 depending on how many towing miles I rack up. I don't expect to do more than a couple thousand miles a year, so I'll shoot for the service every 20,000 miles. Charlie
Yeah never heard of an external tranny cooler put on a trooper either.
2002 trooper announced. No major changes, just some minor ones:
1) S model gets privacy glass, inglass antenna, and arm rests 2) S model loses auto-climate control 3) Limited gets side tubes 4) LS gets moonroof and outside temp/trip built into clock 5) rear cargo accessory outlet and additional in-dash acc. outlet added. 6) cup holders built into center arm rest in rear seat
i wanna get into a trooper 2000 or 2001. i have never bought a used but gotta start playing it smart.
i know i want a 4wd with leather interior with the wood look dash and with the big sunroof. what can i steal this at? is it just the limited that would carry all these options? or can the S make this happen?
thanks matt
am totally leaning towards the 2001. whats the cheapest 2001 new out the door with these options? if its just a matter of another 1500k of lost equity i would be willing to do that. i live in san diego if that makes a difference. are the dealers here ready to give the 2001 ones away?
so msrp is over 35k at edmunds and carsdirect for 2001 limited 4x4.
but looks like loaded u can do one for under 29k with gold package. so its like 31500 out the door with everything?
i couldn't find a used limited on autotrader.com. bunch of 2001 s with cloth for less than 20k. then there are some 2000 ls(my guess is the l stands for limited here) for up to $25900. big jump going from 2000 used $24900 and 2001 $19995.
am i to stay away from these rentals? i always beat my rentals up. usually on business with free gas(comany pay) and free wear and tear on someone else's vehicle.
love the trooper look and need to get in new or used bottom at the bottom.
To budddddylee - From your requirements you need to buy the Limited. I know the dealer here has two or three he will sell at a big discount. Based on the price I paid for a 2001 LS last month (no trade) - with leather - I would guess he would part with one for $26,500. If interested let me know and I will point you in the right direction. They have a lot of troopers on the lot - and now is the time to buy. Good Luck.
S: No moonroof available, no factory leather, no power folding mirrors, no privacy glass (except rentals), no in glass antenna (except rentals), no arm rests (except rentals), downgraded seats, no stock 6-disk in-dash changer (optional) 2-tone paint.
LS: Best bargain IMHO, adds power retracting mirros, heated, upgraded power seats, optional Moonroof, no leather, Privacy glass, in-glass antenna, different rims, 6-disc in dash, monotone paint
I believe that the Limiteds go for around $29K after you take the $4-$6K rebate, LS for around $26-$27K, S for around $22-$24K These are rough #s, but very ball-park conservative. You won't likely find an LS or Limited 2K car around, possibly an S. 2001, you should be able to get any of the 3. They did announce the 2002s on www.isuzu.com, no major changes, except in 2002, the S gets privacy glass, in-glass antenna, arm rests, LS gets moonroof std, outside temp and trip built into the clock, and all get rear acc. outlets.
I find the LS to be the best deal around. You can always have your dealer add aftermarket leather for around $1200 which is a lot cheaper than the Limited package. Also the prices I quoted above on the LS are with moonroof (no point to buy a Trooper w/o the moonroof)
well..my check engine light had been coming on recently, and took the troop to isuzu...they said it had a lazy o2 sensor and replaced it. I seem to remember reading something about this elsewhere on this board...anyone else had this problem?....:)
Got a factory rep demo (titled as new) w/ 5200 miles for under $24k out the door. Saw ad in paper for $13,000 off, emailed them and confirmed price and out the door price. Other than ttl, $299 was only fee. You may be able to find something similar at a high volume dealer.
Trooperites, please pray for Mike and anyone in the area, he could be involved in this mess. I think he's close to the towers, judging by what folks at the Subaru Crew are saying.
I was about 3 blocks away. I walked up to Grand Central station about 4-5miles, and then took a train to NJ, where I wound up getting picked up my dad, but then we couldn't get back into NYC via the bridges to Staten Island, so I had to walk over the bridge to Staten Island, and my dad is in NJ with my truck at his buddy's. Luckily my uncle works one floor above me, and we stuck together with his boss who is a big shot, and we were able to go to a posh club near grand central station for the afternoon. More details later, it was a 12+hr commute home for me.
Glad to hear you are okay. The thought did go throught my mind that you might have been in the middle of that. On another positve note, my wife and I had our second child (little girl) yeterday morning at 10:45. What a day for a birthday. Although my wife was born April 19th and my niece on June 12 (OKC bombing and execution of McVeigh). So when she started having contractions yesterday and I got to work and heard about the WTC I knew that she was not having false labor.
Okay, I know everything is still hectic and our thoughts and prayers are with the folks in NYC & DC, but I can't help but plop down this entirely meaningless note to let ya'll know that I took T-3 (my 2001 Trooper 4x4 LTD) in for it's 3rd regular service this morning...and they nicely took care of the 3rd oil change & 2nd tire rotation as I passed the 10,650 mile mark. Only problem they weren't able to fix (because they told me it didn't exist!) was a problem I've been having where occasionally when at a light the engine will shift gears & rev up to 1,500 RPM and lunge forward....oh, that and when at speed (45, 50, 60, 70) it's felt for the past week like I'm towing a poorly balanced trailer (even though I've got nothing under tow)...they ran in for a few miles with a TECH 2 plugged in (and some bigwig from Isuzu (one of their trainers I believe)) and nothing came up as wrong, so I guess I've got to give it some time to see if it was something from the tires needing to be rotated or if I've gotta wait for the CE light to come back on....oh well, all of our troubles should be so....
I am curious, though, if anyone else has come across the lunging thing b/c this is my second experience with it & the last time it ended up with the need to replace the accelerator sensor...until then, my thoughts and prayers are out with everyone & I too am glad to hear that Paisan is safe & still with us....hang in there ya'll... -Cobbo
-mike
http://www.edmunds.com/chat/isuzuchat.html
-mike
I'm looking at a 16 foot dual axle trailer to pull a tractor on - total weight (trailer plus tractor plus other stuff) of around 4000 lbs.
-mike
HTH,
Charlie
-mike
Thank You
on Trooper and Vehicross.
5-link is correct on '98->'02
on Rodeo and Axiom
'9x->'97 Leaf Springs
on Rodeo
'8x->'91 Leaf Springs
on Trooper
-mike
Charlie
THanks
Charlie
-mike
Charlie
-mike
-mike
thanks matt
thankis in advance
matt
thanks matt
i will look this week at the dealer. anyone know what the current new suv deals are.
matt
Limited: Adds leather, std. moonroof, and overhead multimeter (temp, altitude, barometer, compass)
-mike
Our new 2001 S has one armrest on each front seat. Towards the center. When you said no armrests were you referring to the outside of the seats?
George
-mike
so a 29000$ loaded would be 31000 after taxes and tags and then they apply they 4000k rebate. i can be out the door for 27000$.
looks to be decent. they guy was a fleet manager and very busy.
so how can i lowball this guy even more? i can do the 27000$ and be happy. what you all think?
dude also said all his 2001's already have the privacy glass anyway.
-mike
Steve
Best wishes,
Drew
-mike
John
GTROOP - Congrats!
-mike
-Cobbo
-mike
