Visitor Agreement.
Recently, I've come across a couple of Japanese Trooper ("Bighorn" there) sites that might be interesting to some of you.
See Trooper and other Isuzu vehicles in action. You can view pictures by clicking headers in yellow color (I think that's how it appears in English-language system).
http://www.canal.ne.jp/~hiroshi/kurokan.htm
Another site showing Isuzu vehicles owned by members. Intersting to see different versions/accesories available there. See "Oweners Vehicle Photo" section.
http://comminet.or.jp/people/big-horn/
...Eiji...
1) lay down under neath the jack storage area, you will see a rubber grommet against the side wall of the truck from underneath.
2) Pull that grommet out, and bam! there will be a plug in connector there.
You can buy the other piece (flat connector + wire through a grommet and connector for the part that's on the truck) from Drawtite.com or Hiddenhitch.com See my webpage below for the exact places I got the wiring harness from. I believe it was $25 and a 5 minute install. No spilcing required.
-mike
http://www.iace.com/ia/trooper
Mike, you mentioned that the ECU could be reset. How? I'd like to know since my erstwhile Isuzu dealer is booked for the next week and a half.
Basically what is happening is that the ECU is searching for the proper RPMs and Fuel mixture. It is probably causint eing the truck to run extremely rich and that's why it is choking out at idle. Here is the method for re-setting the ECU. Tonight when you get home, disconnect the battery for 12+ hours (over night) and re-connect it in the morning. This will effectively cold re-set the ECU. Normally what happens is if you just diconnect the battery, the capacitors in the ECU hold a charge for a # of hours so that just disconnecting the battery doesn't re-set the ECU fully. I've successfully fixed the CE light and similar problems on various cars. I had a similar surging problem on my Rodeo '97 which was fixed through this method.
-mike
Has anyone noticed on cold starts a high pitch squealing type of noise in engine area that goes away after about 10 minutes? I have taken the Trooper into the dealer with this problem and first time diagnosed with a bad fan/clutch assembly this was replaced but problem continues my Trooper is parked outside and not in a garage! Any help or thoughts appreciated! Thank you.
2 weeks ago, upstate NY i drove around in about 1-2 feet of snow on saturday. Had it in 4wd TOD, 4wd Lo, etc. No problems. 24 hrs later drove 30 miles and all of a sudden the TOD light and check engine cam on, so I pulled over, and did what you did (2wd, 4wd TOD, 4wd Lo) no effect. Turned off car, turned back on, BAM! problem gone. Haven't had a problem since. My local dealer pulled the code a week after that and said it was "Error 27" "Moisture in TOD unit had triggered the check light" I do have a whine in TOD, but I think it is un-related to the check light coming on. Do you know or can you find out what the error code # was? I went upstate NY this past weekend again, and tried to drive through as much snow as possible to try to repeat the problem but couldn't.
Someone with a Vehicross had a similar problem on the Vmag board (they have TOD and 3.5l engine also on the Vehicross) having to do with snow/ice setting off the TOD check light. His didn't go off after the re-start though.
-mike
My dealer said the 15K serice is only visual, and that the major service is at 30K
-mike
They only changed the transmission and differential fluids at 15K. As well as other checks. The back of my Trooper manual has a laundry list of items to be done. I did a lot of sand driving this last summer and hit a few mud holes, so I did the 15K maintenance to make sure there was nothing inside the fluids that would cause trouble. I have read that if you get any vehicle in water above the hubs/axles/differentials you should change the fluid afterwards. I try to be aware of this while off-roading. Everyday drivers could do major damage to their vehicles by going through 2' of snow and then commuting 30 miles to work for extended periods.
It concerns me that deep snow would get moisture in the TOD System? What about going through deep water. Maybe it is just the actuator and not the transfer case? gears and moisture do not mix.
-mike
Link here:
/direct/view/.eea1204
I start it up in the morning, let it warm up, and then take off. I drive maybe a 1/4 mile though sometimes only 50 feet and I hear a WHIRRING sound like something spinning and clicking real fast, I slow down and the clicking turns to a thummping and the truck feels like its got a flat in the front (The origin of the noise is the front, possibly a little more to the passenger side. I pull to a halt, the sound and the bumpity bump stops...I continue on fine..any ideas? Thanks...
Any ideas??
I was a little annoyed that they missed things like checking the tire pressure after rotating. The mechanic even told me he checked it. I had the fronts set to 32 and the rear at 37 psi. Maybe he thought a 5 psi difference wasn't a big deal.
My name is Chris and I am so far the happy new owner of 2 LS troopers. Bought one for me and one for my dad for Christmas. Looking at what everyone said they paid I am very happy with the prices paid. Have spent alot of time looking for aftermarket accessories. This site has been alot of help in that regard. Just became a distributer for Katzkin leather seats,so if you need a set I will without a doubt beat any price on the net.
I am thinking about setting up a site dedicated to aftermarket parts for troopers only. If anyone has any ideas or thoughts they would be appreciated.
Both vehicles had a vibrating driver side mirror and both are going to be replaced. May or may not solve the problem. I have seen posts about a rattle in the dash(particularly when cold)and have this problem on one vehicle. The dealer is going to start tearing the dash apart to try and find the rattle. If anyone has had this problem and their dealer has corrected it I would appreciate some info. Maybe even your shops name and number so my shop can call them.Would like as little dismanteling of my dash as posible.
Sorry for the long message.I look follward to making some Trooper friends and hope everyone has continued success with thier Troopers.
Chris Miller
ChrisMiller007@aol.com
P.S. sorry for any gramatical errors, not used to the spell checker
There is already an aftermarket discussion at the new Isuzu Owners Club here at Edmunds, or where you referring to a website?
Steve
I have a 2000 LS 2wd. Had the same rattle. Its not the dash or inside. The fuel line under the hood rattles agains the fire wall when cold. Had to leave the vehicle over nite for the dealer to hear it, as it would warm up on the drive there. The dealer is Andy Jones Isuzu in North Augusta SC. Let me know and I'll give you more info.
Had the mirror replaced and its the same. Drove other new trooper, same. I think its the same for all 2000's. The dealer said the mirror snaps into the main part witha plastic piece, so not much support there.
Marcin
-mike
Isuzu Forum Spokesman
Edmunds Isuzu Forum
IA Trooper Homepage
Thanks for the info.I would bet that will prove to be the problem.I was really not wanting to have the dash torn apart so I hope it is.
Steve,
Thanks for your input.I was really thinking of a web site devoted to the Trooper that one could actually order most of their parts from.I don't know if their would be enough interest to make it worthwhile. That is why I was hoping to get some thoughts.
I came to realize I posted my greeting in the wrong forum so I will probably post one in the right place too.
Thanks again,
Chris
The HVAC controls on both these Troopers are the same; I don't know if the mechanicals are too.
I can't be sure if the '96 had any custom mods re: the A/C system, but I doubt it. Overall, it just seemed to blow colder, cool the cabin quicker, and keep it cool more easily. However, I still find the '98 does an adequate job vs. 95 degree temps. Things usually stay cool with Recirculate selected and the fan on 2, sometimes 3.
It seems that perhaps the automatic climate control on the 2000-2001 Troopers is not as powerful as on the previous model years.
-mike
Edmunds Isuzu Forum
IA Trooper Homepage
What about running boards like the ones Isuzu sells only for less. Thanks for your help!
-mike
Edmunds Isuzu Forum
IA Trooper Homepage
I encourage everybody to post their comments in the appropriate Owners Club! Thanks to all who worked hard to make it happen.
Rancho 9000 adjustable shocks (5 position adjustable)
OME (Old Man Emu) rear Coil springs
Calmini Front and Rear upgraded swaybars and bushings.
-mike
/direct/view/.eea11fe
Replaced all 4 shocks with Edelbrock IAS;
Replaced rear coils with Old Man Emu coils;
Replaced front torsion bars with thicker Sway-A-Way torsion bars.
The vehicle now has a firm, controlled, yet forgiving ride - many times better than original. I have very little roll, really not noticeable, and virtually no nose dip now. Hard emergency stops only produce about 3/4" of nose dip at most; normal stops the nose barely dips at all. I can now fill the cargo area up with gear, say a few hundred pounds and the vehicle rides perfect and level due to the progressive design of the OME coils.
I too feel the stock Trooper suspension (at least the '99 I'm familiar with) is completely unacceptable and very unsafe during severe/emergency maneuvers. It is the only major critique I have of the vehicle, but fortunately one that can be easily fixed.
I recommend EVERYONE replace at least the 4 shocks; if only replacing the shocks and since the rear coils are so weak, I recommend either a strong rear shock or an adjustable one like the Rancho 9000 mentioned above to compensate for the stock rear coils.
Good luck on your decision!
-Sahara111
-mike
Yesterday we traded our '98 Trooper on a new '01 Ford Expedition. Worked with four Ford dealers before we got more than $12.5-13.5 as trade-in offers. Boy, THAT sucked! Finally got $14.1 for it. About half what we paid for it, with only 28K miles. In our estimation, the Trooper's slipping values are not offset by its reliability.
May you all live long and prosper! Adios!
All of the trucks come with power everything and A/C
-mike
PS: 2000 Trooper LS w/moonroof, 15K miles no major problems.
I am also concerned about adversely effecting the wheel travel of the truck, the extremely soft suspension allows the truck to have 9" of wheel travel, what did you find or think?
Thanks for you input.
I actually set my front end such that it is slightly nose down with no load in the rear. With a normal load in the rear (one or two people, plus cargo in back) everything levels out just fine, and then the rear end will not sag much further in spite of additional weight since the OME springs are a progressive design (softer at first part of the travel, then they firm up).
These are excellent coil springs. The extra height is in no way a hindrance. I've been very happy with my entire setup as I described earlier, and would do it all again the same way except probably use the OME shocks instead of the Edelbrock. You can get the OME shocks in two flavors - heavy duty off road oriented, or softer on road use.
Resale: Yes, I believe the Trooper has a slightly poor resale performance, mostly the result of the negative (incorrect) publicity about the rollover tests, and also from addtional negatives such as the rear bumper tests last Fall. This along with higher fuel prices and huge new car inventories that are hurting all SUV resales. The bottom line is to be aware of it going in, and be sure you want to drive the vehicle for at least 4-5 years. On the flip side, I believe it is these very factors which hurt new sales, and in turn make the vehicle an outstanding purchase for those of us willing to use our thinking caps in an objective manner. Just be sure to get the max discount possible when buying a new Trooper. I received about $5300 off sticker on mine; but I've seen many people since then get 6-7k off including very recently.
Past History: I have about 34k on my '99 and so far not a single problem. The transmission has an excellent reputation (see previous detailed posts on this subject), the TOD full-time 4wd system works like a champ, the vehicle gets from 16-19mpg on the interstate in my experience, and the engine is a follow-up effort that was tested extensively by Isuzu, one of the biggest truck (and truck engine) manufacturers in the world. I also have a friend with a '92 model with over 100,000 miles on it - he just recently had the starter rebuilt for like $20 - the only "problem" encountered so far, and I have an in-law with a '94 who has also had great service on his. Also, this vehicle is used in many places around the world under extremely brutal conditions and has proven itself.
