Visitor Agreement.
Here is the manufacturer page: http://www.autotap.com/welcome.html
$289 for the import one, $489 for the universal.
-mike
GM Recalls Midsize SUVs
Tue May 7,11:17 AM ET
DETROIT (Reuters) - A federal agency said on Tuesday that General Motors Corp. will recall 60,000 of its popular mid-size sport utility vehicles to fix a fuel filter problem, the fifth recall involving the models in the past year.
The National Highway Traffic Safety Administration (news - web sites) said the new recall covered Chevrolet TrailBlazer, GMC Envoy and Oldsmobile Bravada SUVs built between September and November 2001. A fitting on the fuel filter can come loose, cutting off fuel to the engine and possibly causing a fuel leak.
The other recalls included one for a weak suspension piece in all three models, two for problems with four-wheel-drive systems in the Chevy and GMC models, and one on the Envoy for a technical violation of NHTSA rules.
I'll keep my Trooper thanks...
http://isuzu-suvs.com/events
-mike
Steve
-mike
As for the first point, I have actually had the tower arms rip my rubber gasket at the top of the one rear door. Even though it is ripped I have not noticed any water coming in except when i go through a high pressure car wash. Even then the amount is minimal. Go with Yak and you will be glad you did.
Bad spark plug wires would have nothing to do with oil leaking.
There are valve COVER gaskets, which if they leaked would allow oil to cover the outside the engine, perhaps coating the OUTSIDE of the plugs... there are little gaskets that seat the plugs to the head, but they wouldn't have anything to do with oil leaking.
Stupid question maybe, but have they checked the PCV valve? Once clogged, these things can (at least in some vehicles) wreak havoc, causing all sorts of symptoms that don't seem like they could possibly be related... check that the oil filler cap is seated tightly, too.
This engine isn't so exotic that any good mechanic couldn't go over it. I'd take it to a reputable independent shop for a once over. At least they'd probably be willing to give you straight answers and show you what they are talking about...
Some owners have reported a little marring of the paint in the door frame. The Q tower kit comes with some vinyl protector strips to prevent that. They look a little "light duty" for the job and I may replace them if they fail over time.
One nice feature of the rack is it's flexibility. I have mine set up for maximum spread since I often carry a canoe or a kayak on top. Add the optional gunwale brackets and a couple straps and the canoe doesn't even move.
Think about adding locks and a wind faring to protect your investment and keep down the wind noise. 20% off is a good deal on Yakima racks. I'd like to find a deal like that when I'm ready to buy a storage box (rocket box).
In my Monterey, there is an electrical connector that hangs down just behind the factory fog light in the front bumpers, on both sides. It is not connected to anything.
Does anyone have any idea what they might be for?
-mike
Please read post #4209. There must be something I just don't understand about what's being stated in that post.
-mike
"Consumer Reports, the magazine that uncovers safety problems in everything from appliances to beauty products, says it is guilty of giving consumers a potentially dangerous product. The magazine...is recalling 15,000 glove compartment organizers.
The kits contain a flashlight that can overheat and melt the case and a tire pressure gauge that gives inaccurate readings...
The (NHTSA) says customers should remove the batteries and throw out the flashlight and gauge."
In my case, one connector is attached to the fogs, the other is something like an 8 or 12 way connector IIRC. Too much for just fog lights.
Think I'll get the multimeter out this weekend and see if there are any light circuits or something else running through it.
Maybe it's prewired for the Japanese Bighorn's stability control.
How about your LS Paisan, is there an extra connector behind your fog lights?
-mike
-mike
-mike
-mike
From what I've been told the 275-70s should fit w/o cranking the t-bars or lifting it at all. My 275-70s with the OME springs in the rear and 1" of T-bar lift in the front have no problems even on full-lock and compression. I have a slight .5" rake on mine so that when I put the trailer on it doesn't sag.
Cranking the T-bars will not change the leaning at all. Only changing the stiffness of the t-bars will do that and cranking will only change your downward travel.
-mike
I'm looking to get larger with Michelin LTXs 265/70/16. Should this size tire fit okay w/o disrupting turning radius/clearance? Note: there have been no mods done to suspension, etc. I'm told 255/65/16 is the largest recommended, but 265/70/16 should work, no warm fuzzy with "should work". Thanks in advance
-mike
Just found this posted on one of the subie boards so you guys might want to check em out.
-mike
-mike
-mike
That is funny that they are cranking the T-bars to stop brake-dive, cause they can crank them all the way up, that might shift some weight to the rear but not enough to make a difference, they also will limit down travel, but not up travel, which is what gets used during a brake dive. Stiffer T-bars is what they really need.
-mike
Just my 2 cents, I like the look of 275/75/16s on a Trooper, but I selected a more practical 255/70/16 for better performance since I can't see the tires while I drive anyway.
-mike
I've found the Michelins to have the best highway ride of any truck / SUV tire, and they last forever. The set on my pickup has over 60k and they still have ample tread left.
I've found you can go up a size or two from stock and still have a quiet, smooth ride. I've also found they have plenty of bite for general off road driving and they take can take a pretty good beating.
The only downside is initial cost - but you recover that over time with longer lasting tires.
How did you find the LTX M/S, particularly when off-roading?
The tire I really do want to get is the LTX A/T. However Michelin in Aus has no plan to import any 16" 70 series tyres in the A/T. So if I want to stick to Michelin, my choices are limited to the LTX M/S or the new Synchrone, or go to a 75 series in the A/T. Michelin claims the Synchrone is between the M/S and A/T for off-roading capability.
If anyone else can offer an opinion, let me know.
PS... For those that are interested, the extra connectors behind the fog lamps that I was talking about last week. I found power on only one pin, when the ignition is on. It doesn't seem that any light or turn indicator circuits run through it. So I'm none the wiser on what those connectors are for.
Any perceivable performance or consumption hits on your Trooper, by going to 255/70R16 tires?
Savvas
