But it might be slow going if you have a 5K trailer and want to go 75-80mph.
-mike
-mike
Because I did not find any good after market seats in the US I got one from overseas.
The only US manufacturer seams to be Corbeau. See: www.corbeau.com.
But there email communication was very poor and they do not have orthopedic seats with a high backrest. So I ended up with Greiner in Germany. See: http://www.greiner-gmbh.de/e/scheelmann/index.html
They have a seat with an extra long backrest. It is the vario XXL. Now I even cannot pull out the head restraint to the max, because it will touch the roof before. The seat is just perfect.
After I got the seat, I modified the adaptors that came with it. The main change was, that I replaced the mounting holes in the adaptor to get the seat a far back as possible.
Because of this I gained about 2-3 inches of additional leg room. And because the aftermarket seat has a lower cushion and I also have a little bit more head clearance.
Beside Greiner there is an additional German seat manufacturer, which even officially distributes in the US. It is Koenig seats. See: http://www.ritec-int.com/konig.html
Recaro officially does not offer adaptors for the new Trooper.
For any questions please do not hesitate to contact me: harhir@hotmail.com
Stefan
Here is a link in UK to explain what I am looking for: http://www.cheammotors.co.uk/ecomms/itm00819.htm
the seat stitching is pulling apart!
This happened to mine too. The local corner
upholstery shop removed the seat fabric, turned
it inside out, sewed it up and charged me maybe
$55 for the deal. It has been fine since.
It was on the drivers seat, right where I happen
to stick my right elbow when I get in.
Fixing that is small beans.
My Trooper at 111k takes a licking but keeps
on tic-tic-ticking (valve noise).
AFAIK Isuzu doesn't officially offer any type of roof rack in the US except for the accessory Yakima ski rack, which only holds like 50lbs. The roof rails in your link look interesting, but $300GBP is pretty expensive, so even if we could get them in the US I'm not sure if we would want them.
-mike
http://www.rola.com.au/
I think the parts are available everywhere.
Jim
"Down Under" Holden is the name for GM and Jackaroo is the Trooper.
I am looking for something where I can detach the bars and also re-position them along the roof. That is the main reason why I am interested in a roof rail.
-mike
Rola does make a track mount system suitable for the Trooper, the RO-TM035. However it is different to the Isuzu setup in the UK.
The tracks sit flush on the sheet metal in the frame above the doors, and the roof bars attach to the tracks. Downside is that you will be drilling into the sheet metal, therefore it is a permanent fixture. Load limit is 80kg. Here's the link...
http://www.roofrackcity.com.au/site/srchMake2.asp?ProductID=RO%2DTM035&MakeID=236&ModelID=4559
-mike
The roof rail available in Europe uses the existing ones.
Can these be imported from Japan or Europe?
Maybe since Isuzu is no longer making the Trooper they will lighten up on the restrictions on importing the neat stuff we so far have not been able to get in the USA.
Woudln't it be wonderful if a future engine or hybrid system became avaiable as a retrofit kit for the Trooper that gets fantastic MPG.
But I guess as soon as the Ascender will appear in the US, the Trooper is gone. And with it also the Japanese quality.
I would be interested what happens to Europe, Australia and Japan. What is replacing the Trooper in these countries? Cars like the Ascender can almost not be sold in Europe. No Diesel and too big.
And if I look at the new Chevy Trailblazer which is the same as the new Ascender I am not very happy. I think with the Trooper Isuszu will loose its last good 4 Wheeler.
The only thing Holden has stated is that it has a whole new range of all-wheel drive crossovers vehicles to be released during 2003. It has already released the Cruze which is a tiny AWD vehicle based on the Suzuki Ignis. There will be a range of AWDs based on the Commodore/Monaro/Statesman platform. But that's all that is being said at the moment!
TOD/Transfer Case ATF - looked good but we swapped it anyway
Front diff - he said the fluid looked and smelled perfect (maybe the dealer did this before they sold it), mechanic suggested I not waste money replacing it.
Rear diff - same story
Front bearing repack - checked both wheels, the grease looked perfect, no particles, etc., he suggested we leave that alone also
Oil - using Mobil 1 and not burning any, swapped oil and filter
Replaced air filter
Brake pads looked like new
Tranny - mechanic guessed (correctly?) that it has a GM trans. but wasn't sure if the fill hole was where he thought so we'll do that later. Is the fill bolt just 1.5" or so above the drain bolt on that trans. Anyone have a picture?
I tend to be careful with maintenance but this guy has always been competent so I trusted his advice with the things to leave alone because they were in good shape. Seems like someone (previous dealer or owner) had a lot of service work done on this vehicle sometime before I bought it.
Bill came to $180.00 including the expensive Mobil 1 oil change. Seemed quite fair to me.
P.S. Mike, I'm going to try your CB mounting idea, what's your URL again? I want to look at the pics. Thanks.
Sean
It's working great by the way.
-mike
Anyway, the OEM roof bars in Australia are just rebadged Rola bars. The OEM versions sell for something like $50 a pair more than the Rola version. Something like $350 not fitted for the OEMs to $300 fitted for the Rola.
Holden has a lousy amount of accessories available for the Jackaroo. I'd go to aftermarket suppliers usually. They are cheaper and have a wider choice of gear.
I'd still like the rear wing, though.
Bling!
We had a few system hiccups earlier and a few reports about posts not showing up (including one of my own).
tidester
SUVs; Aftermarket & Accessories
Any answer to the tranny question?
Sean
I have been reading a little about other SUVs trying to anticipate my next one. The Assender is nearly as heavy as the Suburban 5115 lbs! compared to 5225 lbs. The Tahoe/Yukon non-extended had a turning radius of 37.8 ft. and is a little lighter than the Assender. I can get a big employee discount on GM products, so the Yukon sounded pretty good, until you mentioned that they failed in your area. So please tell me what was the problem with them there? Was it reliability? Was it off road ability? Was it the huge rate of fuel consumption?
Thank You
BoxTrooper
tidester
'97 Toyota Land Cruiser
or
New Yukon/Tahoe, SWB
Definitely not Assender for me.
-mike
I am hoping for a new wave of power plants for SUVs. I want a new 2007 Trooper/GBX with a hybrid diesel electric that gets 40 MPG and tows 6000# over the mountains and is still great off road or in snow. Yet it will be like the current Troopers huge inside and rather compact on the outside compared to other large SUVs so it can be easy to park at the mall and easy to fit around tight turns off road in the woods or rocks.
Why a '97?
Last year of solid front and rear axles on the TLC.
Tons and tons of aftermarket worldwide support.
Factory front rear and center lockers.
Love the looks of the FZJ80s
Affordable
Heck I probably should have bought one instead of my '00 Trooper but wanted something "new"
-mike
-mike
Tahoe is about the same weight as the Ascender. Last time I spelled it Assender, it was not intentional.
The Cruisers are legendary of course and most will run forever. They're the bees knees off road, I'm told, but onroad I like the road feel of the Trooper much better. Horses for courses I guess.
As for the Yukon/Tahoe...well my 99 Suburban was pretty reliable but nowhere near as tightly built (as I discovered routing the CB cable in the Trooper today). The GMCs are good, comfortable trucks and handle very well. Mine never felt nimble though and the Trooper always does. 1999 was a good vintage for the Suburban/Yukon, 2000 was a year of teething problems which I would bet are mostly sorted out now.
If you don't mind the gas mileage penalty, the Cruiser is in a league of its own compared to the GMs, and I say that with full respect for the GM Burban I put 83,000 miles on. But my curiosity is peaked...your Trooper is far from the grave, what's prompting all the mental truck shopping?
Cheers,
Sean
P.S. Good advice on the antenna mounting, works great.
Curious how you routed your wiring? I just routed the wiring on my K40 over the weekend. I had had my old wiring in place for my mag mount but finally got around to hiding the wiring on the K40. I just shoved it between the plastic pieces on the passenger side with a flathead screw driver up to the piece of plastic for the rear seatbelt then unscrewed that and the moudling @ the bottom of the doorways and ran it under them. Then had it go under the passenger mat to the CB.
I'm loving that spoiler mount
-mike
Today I am thinking of keeping my 1995.5 because it has already got all the stuff I need to make it a better fit for me, such as: 3rd row seat for three kids, cd player, OME springs, OME shocks, and OverLander/Thule roof rack. An additional plus for me is that the bumper covers are not painted, scratched don't show and my 1995.5 does not have those big plastic wheel flairs. And the money I save by keeping my 1995.5 can be used for more stuff like a ECB winch bumper and ARB airlocker rear diff etc... Still, if my Trooper's engine starts lifter ticking I can't stand it then I really want to swap.
There just happened to be a guy around with a very fancy meter and we found that antenna was giving a very consistent impedance and SWR (under 1.4) across all 40 channels with the antenna mast lowered all the way into its receiver.
Works great overall, thanks for the idea.
Sean
The 4WD Limited Trooper is profiled and comes out as follows:
Original Price (MSRP)- $37,270
Value after 3 years- $11,675
Needless to say, that's a heck of a hit. BUT... as we all know Troopers are heavily discounted when you buy them. If you are in market for a Trooper, please make sure you get the best deal when you buy (some areas have $10,000 off MSRP).
Acura MDX 4WD
MSRP- $37,800
Value after 3 years - $21,400
But as many of us know, you will pay close to MSRP for the MDX so it's really not a fair comparison... Just another example of how the Trooper's poor market image comes back to haunt us. I'll keep my 99S until it dies (somewhere around 200k miles...lol).
WSJ, 8/6/02, Page D1 for your reading pleasure.
Your job is much more professional than mine I think
-mike
Heck, I think I could get about $11k for your 67k miles, 4 year old 98 Trooper w/Performance Package.
-mike
I did not get the Frontier rack from Performance's web site, I bought it at their store on clearance. They don't have it on their web site. I bought at Performance because it was a few dollars cheaper and I didn't have to have it shipped (Performance has a shop here in Gaithersburg Maryland).
I am all but certain the Nashbar racks are identical (Nashbar has the 3 and 4 bike rack pictures with the wrong listings: this listing for the 4 bike rack has the 3 bike rack picture and visa versa). Go to www.bikenashbar.com and search for NS-HR4 or NS-HR3
Nashbar used to sell the Frontier rack and their own. They are clearing out the Frontier racks. I'm betting their brand is made by Frontier with the Nashbar name decal'd on. If you can get Nashbar to measure the foot of the rack, from end to end, I'll be happy to measure mine and let you know if its the same. Nashbar is a pretty considerate company. I'll bet they will measure it for you.
The tours are going great. August is intense. I have staff leading two tours from August 11 onwards while I lead two tours for Honda from 8/12 forward. Looking forward to the slowdown in mid-Oct.
Sean
