Visitor Agreement.
-mike
Yes, troopers do have an internal cooler in the radiator. However, that cooler is simply a piece of pipe passing through the bottom tank of the radiator. I was talking to my local Isuzu dealer mechanic about this issue. He "told" me that it is standard protocol for them to install an external tranny cooler when someone comes in for a tranny repair under warranty. He claimed that the cooler, as currently designed, is designed to quickly heat up the fluid and then stabilize the temperature of the fluid under most driving conditions. However, he indicated that the stock cooler lines do very little to maintain the temperature of the fluid under towing conditions/high temperature conditions. For me, his comments were only additonal information. My father and I have always had GM trucks and suburbans with external engine oil and transmission oil coolers, from the factory. These trucks easily achieve over 200,000 miles without powertrain problems. So I spent $150 to get coolers similar to what I can get on a GM truck and it gives me piece of mind.
Chad
In warmer climes I would do it the other way around, as the manufacturer suggests (radiator first, then cooler).
Q. Should the cooler be installed before or after the radiator?
A. Hayden recommends installing the auxiliary cooler after the radiator to return the coolest fluid directly to the transmission. Installing the cooler before the radiator will still provide additional cooling and may be necessary in some difficult access applications.
Q. Can you over cool the transmission fluid?
A. Transmissions are not highly sensitive to cool operating temperatures. However, in sub-zero (20-30° F) weather conditions transmission fluid can actually gel up in an external cooler and cease to flow, causing damage. Use of the radiator cooler actually helps warm the fluid under these conditions. It is critical in extreme cold conditions to use the original equipment cooler in series with the auxiliary cooler and allow the vehicle to warm up before driving.
After reading this, I believe I made the right call on the routing.
-mike
Philip
-mike
I also read the thread regarding oil coolers. For me at least, I do nothing to put extreme stress on my vehicle, so if it burns a little more oil, I don't care. Unless you are working the vehicle hard, putting coolers on everything with fluid seems like expensive overkill. As always, however, if you sleep better at night because you have a transmission/oil/differential/power steering cooler, then knock yourself out.
Tom
first off, i want to buy this suv in april or may of 2003..
will it still be available?
and most importantly..pricing..
can i get a limited 4 whee drive trooper for around $27,500..arent they giving these away? i mean ive read $$$$ for an LS for like 23,000 or so..so anyone know what the limited is going for? dealers must want to pay you to buy this SUV and thats fine, i think its the best one of them all..but reality please..will $27,500 get me a fully loaded 4 x 4 limited..thx...eric
-mike
With the interest and the deals the way they are I would look now. Perhaps if you were slow at getting it together and dragging your feet you could get a deal started and hold it off until after the first of the year. Down payment and or something.
I was in Kansas City a couple of week-end ago and the dealer on about 65th and Metcalf in Overland Park had a bunch of Limited s. The salesman that I talked to said, "The transports just showed up and started dropping them off". They were really ready to deal. I gave some thought to trading again but came to my senses and drove away.
I would do some homework and find who has some or one and start working the telephone or the internet for one. I would not wait and hope to find one in the spring. But, beware dealers may be a little tough at first, saying it is the last of the Troopers and they are really worth big bucks, give them your phone number and tell them to call you when they are ready to deal.
Good hunting!
Philip
It's a promo for Safari Snorkels.
http://www.safari4x4.com.au/docs/video.htm
This is the perfect US Isuzu commercial. Show a couple in the vehicle floating downriver then driving out. Right out of the river they go up the driveway to the spiffiest, posh, country club and when they get out the couple are all dolled up in tux and evening gown for a lovely evening of dinner and dancing. The valet then gets into the Trooper and drives right back into the river and emerge on the other side to park on the top of a mountain.
Goes after the hard-core 4X4r's and the mini-mall 4x4r's.
If it wasn't for the snorkel, sure the engine would have been destroyed by water intake. But obviously this guy kept his cool, found traction and got out of it.
A class act!
Has anyone been in water deep enough to verify how water tight the cabin is? Do the doors leak in 2' plus water? Mine didn't, but I was going fast enough through to not get water inside.
You may be able to get through upto the bonnet, if you had a blind fitted across the front of the vehicle and maintained enough momentum to create a bow wave so as water didn't have the opportunity to swirl up into the engine bay. I also wouldn't try it without a snorkel anyway. A petrol engine can ingest only a little water without suffering too much.
However, this Jackaroo lost traction and floated away and my guess is the engine bay was full of water. The diesel might be able to keep running as it isn't dependant on an electronic ignition system, but only if the motor didn't ingest water through the air intake. Otherwise at about 20:1 compression, it doesn't take much incompressible water to be fatal to a diesel.
-mike
Liberty
Sorento
Axiom
Montero Sport
-mike
-mike
I always heard one must me careful and not wash a hot engine or put cold water in a radiator for fear of cracking the engine block.
http://photos.yahoo.com/bc/zutrooper/vwp?.dir=/Yahoo!+Photo+Album&.src=ph&.dnm=royal+blue+red+troop.jpg&.view=t&.done=http://photos.yahoo.com/bc/zutrooper/lst?&.dir=/Yahoo!+Photo+Album&.src=ph&.view=t
Did anyone read the reviews for "Mudfest"? This is an event where the auto press tests SUVs on dirt, pavement, and mud. Then awards winners in various classes. It's been all over the MSN homepage. Isuzu got completly snubbed. There were no Isuzu's in the thing. Kinda shabby if you ask me.
-mike
-mike
-mike
I wonder, do the newer Troopers not have this oil to water heat exchanger? Is there more clearance for the filter?
The PL14619 oil filter rubber seal is larger in diamter than the PL24458 3.15 diamter filter that I use by just enough that the seal on the PL24458 fits inside the seal on the PL14619. Still, I did look at the oil fitler flange, and it is a bit wider than the seal on the 3.15 diameter filter, so I suppose the PL14619 would seal up.
I can only say that on my 99 Trooper S model auto/TOD, there are no water cooling lines going to the oil filter mount flange. However, I remember seeing two "pipe" plugs in the oil filter mount flange. Therefore, it appears that Isuzu thought of cooling the engine oil when they designed the oil filter mount flange, and they decided not to for cost reasons or some other reason.
Maybe someone with a 2000 or 2001 trooper will comment.
Chad
jurassic3k "Chevy Trailblazer, GMC Envoy, Oldsmobile Bravada" Nov 24, 2002 12:04pm
-mike
I learned that one thing to watch out for when pulling a heavy trailer on washboard roads is the lug nuts must be very tight. I never had a problem like this before. The lug nuts did not come loose, rather the beating of the washboards was able to move the wheel (wheel and tire running under a little more than max alowable load) under the lug nuts enough to grow the tapered bolt holes. The larger holes allowed more movement and made the rate of damage faster. I noticed the problem when fueling up about 30 highway miles from the trails. One painted while trailer wheel was black. The black was the metal dust from the enlarged no longer tapered holes. I used my two foot long racket to crank the lug nuts tight. I was in luck since there were enough threads left on the damaged studs to turn the lug nuts about three more turns to clamp the wheel tightly again. I checked the other trailer wheel, it was OK, but I tightened the lug nuts anyway to make sure. Now I need to get a new wheel and some new studs before the next trailering event.
Future trailering will include lug nut torque checks in addition to greasing the bearing buddies and checking the air pressure.
Is this a common occurrence? Anything I should get checked out?
