Visitor Agreement.
sbcooke wanted to be sure you understand that TOD is as good as it gets: it's full time 4WD high. Your truck has a limited slip differential in back, too, so compared to most "four wheel drives" (which have open differentials and can only bang on the front axle or disengage the front axle) you are putting a lot of traction on the road.
I think you will find that TOD is better than 4 wheel drive low in most snow situations because it can shift power from back to front depending on what's slipping. If you put it in 4 low, you can easily start all four wheels spinning with all the power coming out of the engine and the halved gear ratios. Plus, of course, with 4 wheel low, your top speed will be in the 35 to 40 range, I think (and the engine will be revving at that speed).
So they both should probably be hooked up. I would hook up both and see how it goes - I am just wondering why they were unhooked in the first place...
The Draw-Tite hitch was a fairly easy installation. One frame hole had to be enlarged by drilling it out another 1/8". Did it in about 2 hours in my driveway.
A comment about tire wear: One of my motivations in changing the shocks after "only" 22,000 miles was excessive tire wear (feathering and cupping). I've seen several posts here talking about Trooper tire wear that attributed it to alignment problems. Could be a major culprit is the weak factory shocks. IMHO, cupping is almost always due to poor suspension control by the shocks. I rotated my tires in different combinations to get minimum pull and noise(looked like they'd been rotated once already). Probably have to replace at least two of them within the year.
I have been using only premium since the first time the lifter ticking happenned on my 1995 SOHC Trooper. I figure that by avoiding the pre-ignition I am reducing blow by and thereby keeping the oil cleaner.
The discount warehouse stores like BJs Coctco and Sam's Club all have gas stations at some of their stores. At my local discounter's gas station, they only have 87 and 93 octane with the 93 octane price as good or better than the midgrade price elsewhere.
Vote conservative, or watch the liberals in government come up with even more taxes on premium gas that us evil SUV drivers use.
McCain challenging Bush on environmental issues
I love labels :-)
In other "eco" news, Eco drive records broken at Isuzu Challenge in Cebu
sbcooke-TOD is indeed very powerful. I'm gonna read up more so I fully understand the system.
tkevinblanc-Thanks for the information. Now I better understand why I was the only 4X4 able to get out after our recent storm. Troopers rule!
sdc2-I had to unhook the antenna connections when I removed the factory radio. All aftermarket radios only come with one antenna recepticle however the new Troopers that use the "diversity" system have two antenna plugs-a large and small one. What I don't know is if these two are in addition to a separate signal booster or if the smaller one is that signal booster. Either way my next plan will be to try and identify to signal booster and attach it to the Alpine head units "power
antenna" wire which I'm hoping will remedy the problem. I'll let you guys know if that fixes the problem?
notbrockyates-which Rockford Fosgates? I just installed RF 6 1/2's in the front doors. I've also added manik diamond series step bars which should be fine for me since I'm also not a heavy off road user (beach driving, light off roading)so they should be fine for me. Do you like the factory bug shield? I opted for the Weathertech version and tapeless window visors. I did have to drill a few small holes though did you?
Welcome to the new folks!
Be sure to check out http://isuzu-suvs.com
-mike
I want a bumper sticker that says that!! ;-)
The above quote about Fram oil filters comes from here - http://www.scuderiaciriani.com/rx7/oil_filter_study/
In my reading I also found out that when the ABS is engaged, the TOD system engages full 50-50 lockup to help maintain braking stability.
-mike
I haven't looked at the Gear slector yet.
-mike
Pretty nice cd, I think it was like $100 or something.
-mike
-mike
-mike
E-mail me privately for more details mike@iace.com
-mike
I have one for my Miata but had to refer to Miata.net in order to advance my timing. Though they list some torque specs so it wasn't a total waste.
-juice
They do work in my home stereo systems, so why not in the Trooper? It really stinks as I can't always carry my music everywhere :-(
EDIT: I just noticed (using search) that a lot of you do indeed play CD-Rs in the changer. Would you mind telling me what CD brand, what program, and/or what CD burner you guys use? THANKS!
They play CD/R's fine, but not audio recorded onto a CD/RW.
I am at the end of a four year lease with Isuzu Motors on my 99 Trooper and was approached today with a payoff option from Isuzu. The terms of my lease included a $12,600 payoff. Isuzu has offered the truck to me for $9,600. Boy they really don't want these Troopers back.
I have now purchased a high mileage, well maintained Trooper for $3000 less than my original plan. (It's hard to pretend that you are prepared to turn a truck in that has a 2" lift, 33" mud tires, a black steel bumper and a 2" protective coating of dried mud. I sure am glad it was handled over the phone.)
I mention this because the purchase price was lowered 3 times during my negotiations with them. Hopefully this will help anyone considering an off-lease purchase with Isuzu Motors.
My lease is up at the end of November this year. My payoff is supposed to be $20k AUS. However, current trade-in values are running around the $30k AUS mark. I can actually end up $10k AUS ahead, which is unexpected.
Therefore, I'm considering trading it in on a new Nissan Patrol with a turbo diesel engine and Dtronic engine management system or Toyota Landcruiser Prado 4.0 V6, at a similar or lower lease cost to what I have now, finalise the existing lease, and pocket $10k!
It would be nice if Holden & Isuzu have the new 2004 Jackaroo out by then, but I doubt it.
I use Roxio EZ CD Creator and usually 3M/Imagination CDRs burned from MP3s.
-mike
The mileage penalty is interesting as well. My mileage is always high, so I usually purchase or trade in my vehicles at the end of a lease. If I decided instead to return this truck to Isuzu Motors and walk away, I would owe close to $ 3,600 in mileage penalties not counting whatever they come up with for wear and tear.
I have been planning to purchase this truck from the beginning, I just never expected to have $3,000 shaved off the residual price in the process.
I ended up paying mine off early so it works out to be less than calculated, however for my purchase...I put 4K down and had $405 payments for 60 months which is about $28.5K total.
I am just curious, because leases are/were very popular, and with cheaper buy backs, so your total cost is coming very close to just outright buying the vehicle...with the advantages/options of a lease.
In this case two very different finance options: 60-note vs. 48 month lease were very close in final cost. But only because Isuzu lowered my obligation to them. A 60 month note is the better choice in most cases, especially with a down payment. I was upside down on my trade, so the lease allowed me to cover the loss without any out of pocket expense.
I am provided a vehicle allowance through my company. This allowance is a set amount each month. A lease allows me to keep the monthly payments within my company's limits. I have done this for years and tend to look at a lease as a 4 year note with a balloon payment on the end. I never recommend leasing to others because of the inherent risks involved. For my situation, I usually work the deal both ways (60-month note vs. 48-month lease) and take the best fit. With some of the low APR offers I have seen lately, a long term lease does not make any sense. IMO
-mike
Thanks for the replies, I will relay the info to my friend.
The APs went 45K to 50K IIRC, that was 85K ago.
History of tires on my 1995 Trooper:
New to 45K GoodYear AP
45K to 85K GoodYear RFA (low sale price)
85K to 130K Dueler HL
130 to present Dueler ATRevo
Rated for traction, 1 = BEST Traction:
1 = ATRevo by far
2 = HL tread holds little rocks
3 = RFA rubber got hard then no traction
4 = AP only for clean pavement
Rated for noise, 1 = Quietest:
1 = HL very nice luxery SUV tire
2 = AP GoodYear's quietest tire
3 = ATRevo extremely quiet for an AT tire
4 = RFA OK when new but quickly got louder
Rated for handling, 1 = Best Handling:
2 = ATRevo handling nearly as good as HL
3 = RFA stiff
4 = AP mushy
My favorite by a wide margin is the ATRevo.
Note that with 255/70/16 I get correct speedometer reading based on a watch and the mile markers on the highway.
If you upsize the tires and want some idea of weight difference ask the tire store for the shipping weight of each size.
Our 98 Trooper went 52k on the OEM Bridgestone Duelers. Could have squeezed 60k but wanted new rubber on the truck with winter approaching.
Both my wife and I have a pretty easygoing driving style, and I think that helps us get more out of our tires than some folks.
