Visitor Agreement.
Isuzu corporate 10 bolt.
-mike
It's a lot better than an open diff, but it is still a long way from a locker.
http://isuzu-suvs.com/events
We had a blast!
-mike
Only a portion of the Troopers there.
-mike
-mike
I am contemplating getting the 919s as well. I am just not sure if I want to raise the body up any higher than normal. I don't have ground clearance issues the only issue that I am looking to fix is load capacity and being able to comfortably carry more than 500 lbs. When I go away for my yearly trip, between people and gear the rear end gets pretty well loaded down, almost to the bump stops.
On a side note, wheeling with the rocker bars is a great feeling. No more puckering up when going over rocks. This Uwharrie trip was the first one I did with them and it made it oh-so pleasurable.
Just need bigger tires, going to go to 285-75-16s next time around.
-mike
Needless to say I'm pretty happy I had it done.
-mike
I have OME shocks in the rear, you meant springs I assume. I haven't noticed any sag in them yet.
The Flush was $135 with tax, not bad considering that I couldn't do it myself.
-mike
I know that the high-tech flush runs a fluid through, under pressure, in a manner that cleans the tranny thoroughly.
It seems like using 30 plus quarts of ATF to flush, and then tossing them away, would be a little environmentally unfriendly. Not that I'm a tree hugger... well, I guess I do admire trees.
-mike
Just a thought that maybe the module needs to be reset.
It is incredible how much better the cd's sound than the radio! Also, even going over some serious bumps in the road, the player does not skip.
Jim
ATF Flush Fill with Redline or Amsoil
Diffy, SOTF, TOD with Redline or Amsoil
Check belts
Coolant Flush/fill
Brake Flush/Fill Synthetic
PS Flush/Fill
Wash/Wax/Detail
-mike
Jim
-mike
Did you replace the light bulb on your headlights? They look pretty bright than the stock light bulbs.
-mike
My Rancho 9000 left front side was stuck on four. I jacked the front up and then was able to change the setting. I don't know why this worked, but it may help you as well.
-mike
I have a disturbing problem with my 98 Trooper I've only had for less than two months. I've begun to notice a small clunking noise when I stop the truck and put it in park from drive. It will also make the noise sometimes between park and reverse etc, but not between 1st, 2nd 3rd and drive. It also makes the noise when it downshifts to the first gear when slowing down to a stop. I initially thought it was a u joint, but now it seems like it's an internal noise to the transmission or something. Anyone else experience this? What would be the likely causes?
The truck runs smooth on acceleration and shifting when driving, no noises then. Only when it downshifts all the way to the last gear before stopping and when you put it in park.
-mike
The clunking when slowing to a stop is normal. I posted a related response on this in a response to saty in the dealers section.
sbcooke "Isuzu Dealers & Pricing" Apr 7, 2003 8:34am
I cannot remember the specifics, but I believe it is the torque converter releasing as the transmission shifts down or into neutral as you are coming to a stop. It actually is a "feature" because supposedly the way the 4L30E GM transmission works helps longevity.
I hope that will remedy the problem. What is freaking me out is that the truck has 60,150 miles on it and is therefore out of warranty!!
When you say get the ATF flushed, does that mean flushed or just the fluids replaced? Is there a difference? Interestingly, I had an appointment to have the oil and trans. serviced this Friday.
When you had this done, did the problem completely stop, or do you still have the clunk on deceleration. SBCooke says that this clunk is normal. I'm just hoping my new baby doesn't need a new transmission. I really like the truck.
Thanks again.
-mike
However, I agree with Paisan's opinion, clunking while putting it into gear or during normal shifting sounds like low transmission fluid, or perhaps dirty? I had an old Pontiac wagon that used to burn transmission fluid, and as it got lower, it would shift hard when going from P to R or N to D.
I would make sure it isn't the "normal" clunk before you run out and get a flush. I think a flush should be about $100 plus tax.
-mike
Flushing it will drive the old fluid out. It's more expensive, but worth it. Lots of places can do it: my Isuzu dealer did it, but so can my Mobil station at the corner.
-mike
What was the cost of the flush?
The cost of the flush was $91.00 at Jiffy Lube. Like I mentioned before, they didn't hook it up to the machine, but simply drained and filled a few times while the truck was running and shifting gears. The "gear banging" as they called it ( rather disconcertingly!), was supposed to rid the transmission of the old fluid as completely as possible. The manager at Jiffy Lube said there was no real advantage to the machine other than a time savings. I don't know if that was BS or not.
Thanks again.
Dealers offering $9000 of MSRP. Has anyone had issues with the moonroofs that are in the LS. My aftermarket one had leaking issues. Also, anyone out there taken advantage of the $9000 rebate? How low did you get it down to (S or LS)
-mike
Thank you all in advance!
Just drive it around a bit to warm up the fluid before draining. And you will need to buy one of those cheap pumps along with the gear lube to fill. Have plenty of rags handy, it can get a bit messy sometimes...
Regarding the transfer case, do you have a manual transmission model? If not, you have the TOD transfer case, which does not call for fluid replacement at this time (although it doesn't hurt).
The hints as to the existence of the SOTF vacuum switch mechanism and attendant website URLs proved invaluable. A friend with vast experience trouble-shooting such problems and I used his MightyVac to isolate the problem in one of the two vacuum switches on the SOTF assembly on the front axle. In short, the switch was not pulling enough air to coax the system into 4WD.
We carefully tried to bring the switch back to spec (after pulling the assembly off the truck.) This requires first removing a small shield (Two 14mm bolts.) You then can use a 10mm socket to remove the plate holding the two vacuum switches (looks just like top picture in URL mentioned on PlanetIsuzu.) It took a while to trace the hoses attached to understand the logic of how the SOTF system works. We pulled the suspect switch off the plate (Phillips screw at back of plate.) Using the MightyVac and a couple wires, we used the truck's battery to actuate the solenoid with vacuum on it to see if it passed air properly. When it didn't we knew we were close to the bad part. Another check on that theory was to start the truck and use the MightyVac (a hand-held unit with a gauge on it and a handle that you squeeze to pull air out of hoses, bleed brake systems, etc. Gotta get one!) to put a vacuum on the hose that leads from the the suspect vacuum switch to the diaphram on the axle. Instant 4WD!
Dealers being closed on Saturday, we tried a NAPA and another local auto store but no luck on the Denso part. Part #8-97101858-1 is what I read on the part. There's another number I took to be a manufacturer's number: 08480U-2201. It was bit smudgy but those are close.
It took some judicious use of very small wire and eventually a good hosing with carb cleaner, but we got the part's logic to work with the good ol' MightyVac and the actuation of the switch via truck battery. Its resistance also measured at the noted 42 ohms (by PlanetIsuzu.com), so we knew that it was ok electrically.
We put it all back together and my TOD switch now works like a champ, every time.
Of course, my dealer said this would be a $600 repair requiring replacement of the ECU, so you know I'm glad that with my friend Nick's help, we sorted this in a few hours in my driveway.
The moral to this story, btw, is to exercise that TOD switch frequently to keep those solenoids from getting cruddy. I tend to only use 4WD when I 'need' it and thus it was the 4WD solenoid that crudded up on me.
Thanks to those who put us on the right path.
Craig
I think you may have solved my problem too. I on the other hand, left my truck in TOD all winter cause the weather up here was horrible. So mine is stuck in the other direction!
I'm still under warranty so we'll see what they come up with when I bring it into them this week.
-mike
