Visitor Agreement.
Installation required pulling back the carpet to place the template accurately and to drill the holes from above. Then go below and line up and bolt on the brackets that stay down there. Push the carpet back down and cut holes over the drilled holes for the bolts to pass through. I use one of those new rachet built in wrenches and I store the wrench in the jack cubby under the jack's rubber strap so it won't rattle.
I have not put the seat back into the 2001 yet for two reasons: 1.) I did not save the brackets from my 1995, so I need to order another set and 2.) My wife would like to add shoulder straps and head rests to the seat belts back there. I ordered it with three lap belts figuring that little kids don't like the shoulderstraps anyway and their heads were below the top of the seat anyway. Now they are bigger and the shoulder straps and head rests could get used. I have not contacted them to ask about adding those items to my seat which is the rigid model and I mount mine rear facing to create a storage space between it and the middle seat.
LittlePassengerSeats will buy back used seats when you are done with them so they can recover them for the next customer, they are that sturdy.
http://www.littlepassengerseats.com/isuzu_trooper.htm
-mike
And my transfer case if it fails, is not gonna be a common one (I do lots of towing and offroading)
The warranty is cut in 1/2 on 2nd owners.
-mike
I can laugh about it now. I haven't heard about any engine failures. The T-case thing worries me, however I haven't read really many posts regarding problems with them.
Paisan, does the tranny flush get the T-case? Maybe a separate flush of it would resolve noise issues?
Can I get that from the Trooper ?
On the 1995 in 142K+ miles I hade the lifter ticking issue show up but I was able to keep it quiet with close attention to oil changes. A power steering hose started a very slow seep leak and I had that replaced. That is all on the 1995 until it was totaled by rear ending.
Now I have a 2001 with only 33K miles and so far no issues.
That's 276K miles with very minimal problems, no expensive problems, and never a problem that made the Trooper unable to drive, even the 1995 was driveable after the wreck, but repairing air bags is too expensive.
I'm gonna try a drain fill on it before hitting the dealer for repair. It's due for it anyway.
-mike
I have a noise on my 98 trooper that comes from the lower back of the engine. I have had the engine gone through with the connecting rod bearings replaced, thurst washers replaced, the piston pins checked, rings checked and the flex plate checked. So far everything looks good, but still the noise continues. Any ideas on what it could be?
It sounds like a small diesel engine, it is much more louder when cold and then fades a bit when it is warmed up. thanks for your input.
The point being if I don't know the rules I cannot try to follow them.
For those of you that didn't notice I responded to coupedncal in my post #8549. I pointed out some good and potentially bad Trooper points. He even responded. Now my post is gone.
-mike
If you have questions about edmunds.com Town Hall policy refer to the Terms of Use (to which we all agreed when we signed on and which you can access using the "Member Agreement" link near the top of this page) or contact one of the hosts rather than straying from topic on the boards.
1. tire pressure at 11 pds in two tires after a tire rotation/balance.
2. over filled oil by nearly a quart. I checked at home after the service and took it back. It was starting to make strange noise. Dealer changed the oil again.
3. lost lug nut on front right wheel two days after another tire rotation/balance. Dealer re balanced the tire and replaced lug no charge.
So, this is why I'm a little nervous. I love this truck and it has been perfect except for the service.
Thanks for any input.
I have had bad experience with the nearby (40 minutes) dealership. I am jaded and am now just paying out of pocket.
my dilemma is: should i stay with aftermarket radiator or pay the difference ( ~ $200-300) for getting an original isuzu radiator? is there are any issues with aftermarket radiators? any comments are appreciated.
as far as my usage of the trooper: most of the times it is just commute to work, occasional mild off-road and towing.
$185 shipped on Ebay, if you care to risk it.
I may just get one, because my changer is acting up again (this is the second one). It REALLY annoyed me when it stopped working 1 hour into a 21 hour drive a few months ago...
If the insurance company cannot prove to you that the aftermarket parts are as good or better than the genuine Isuzu parts I think you can demand the genuine Isuzu parts.
Tell the insurance company you are very concerned about engine protection and ask for documentated proof that the aftermarket part is as good as the genuine original. I bet it will be easier for them to back down and get you genuine Isuzu parts than to prove to you that the aftermarket ones are as good. As an alternative, ask for a guarantee in writing delivered before the part is replaced for the life of the vehicle that if the aftermarket part fails the insurance company will pay to replace the part and repair all related damage. Then they can evealuate how good the aftermarket part is at their risk.
They have a couple of CD players (Changers?) too.
-Ryan
Net/Net it was still cheaper to go through 2 vendors, but for about $15 more it would have only been one order from crutchfield.
The player is great, doesn't skip, plays everything and has good features. Ripping my discs to MP3s is time consuming, but the overall storage increase is well worth it.
-mike
Buran, in the case of your 02 vehicle I think you could strongly argue that they owe you a new OEM radiator with at most $50 out of your pocket. Alternatively you might try St. Charles and see if they can get you a much better price on an OEM radiator. If you do, the insurance company might foot that smaller bill. Another option could be to find a high quality aftermarket manufacturer and get one of their radiators.
-mike
As I told here once my Trooper needs to be sold 'cause I want a diesel one.
I took it to Road Police Office yesterday and shown them all as it needs to be done according to a Law. Gosh, they didn't find the engine number though it was written in a Vehicle Card! So they sent me to the Main R.P.O. where I must be next week.
Well my Trooper doesn't want to choose a new owner.
Anyway, does anyone here know where is the number? and could be 3.5'Trooper without it?
All your inputs are very appreciated.
now everything what is on the list for the replacement(after front collision) is OEM, but as Boxtrooper pointed out i have to make sure that OEM parts are actually installed on to my truck.
Thank you all for your input.
Dnestr you might look there yourself. If you find them go back to the local office and show them. I would think the main office should have a VIN finding chart. Then again if you are not in the US maybe they don't have such labelings. Good luck.
My truck was purchased in the US, that's why I'm asking here. But in Russia Troopers are pretty small in numbers and police doesn't know them well, I think. Though they must have to know in any case!
I checked there myself and found nothing, unfortunately.
here is my email just in case satnavigator@yahoo.com
On the driver's side I could just barely see it but only if I used a mirror and a flashlight. It is under the middle coil pack on the driver's side and above the exhaust manifold. To read the number you will probably need a very small mirror, something like one a dentist uses. Without such a small mirror you cannot get the proper angle to see the tag.
For the record, your English is fine. I was not trying to correct you.
Dennis
This C-ring thing could be it. What is the procedure for checking the C-ring out? Is it an easy fix? Is it a safety issue?
Thanks in advance for any advice.
Something else to consider, once a month I run a tank of gas with TOD on just to keep the seals moist, without any abnormal noises.
As to what to do? Of course the definitive test is to open it up see. Lacking that there are a lot of relatively easy tests that you or a shop could do to try and pinpoint your problem. You might first jack it up and spin the tire. Try and find exactly where the noise is coming from. Also, a loose bearing should be easy to check by pulling on the top and bottom of the wheel and checking for play. You might be able to detect a snapring or shim problem by pulling on the halfshaft.
You could also have a totally unrelated problem like a bad cv. Carefully inspect the boots for any tears.
You will need an exploded view of the wheel bearing assembly to make sure everything is oriented properly. But, look very closely if you disassemble it and draw your own picture as you take each part off.
I do my own tire rotations every 5K. I noticed from day one, if you rotated the fronts to clock the stud at 12 o'clock, I hear a ticking as it rotates, almost like an indexing sound, I just assumed that this was normal for TOD?
Another thing, the clunking I get is intermittent and only on high speed compression hits, same for others?
