-mike
One more question, about getting a check up on the trooper, what's your advice on how to go about it? I thought maybe give it the 30,000 mile tune up, since i don't think it had it; and that way it gets a pretty thourough investigation. I do think something is wrong though, possibly with my tranny, or brakes. Sometimes it feels like something is sticking like when i let off the gas, it slows down quickly, almost like you forgot to put down the parking brake i guess. Make sense? how should i go about this so that if there is a problem it's still under my warranty?
I also got a warranty on each tire for 14 bucks, if i get a nail or some leak that patching doesn't fix i get a new tire free, and since the dealership is paying for my new set of tires, hell . . . why not! I am surprise at how much your discount tire quoted. I'll do you a favor i'll give you discounts number here in indy where i am, you call them and get a quote, then call yours with that info and demand it cheaper. Have to be tomorrow since i am in chicago tonight.
The transmission stays engaged to the engine, allowing you some engine braking. Imagine if you were going down a hill on a gravel road and took your foot off the gas. It's behaving exactly as an off-road vehicle should.
It feels kind of like a car with a manual transmission when you take your foot off the gas, right?
-mike
Where did you get your "T-tap" from mike?
-mike
01 LS TOD with 46K - so far only problem has been with the surging at cold start on warm days - they replaced both the EGR and FPR - but I think it has not gone away - it did it again the other day when the temp climbed above 70 deg - beside this the Trooper has been outstanding - looking forward to 200,000 miles more. Those posts on changing the spark plugs were interesting - sounds like a scary proposition to do it yourself. If you are getting new tires go to a larger size - the 265-70-16's we installed sure improved the stability and the look. Next stop is to get the front wheel bearings repacked - $80 at my favorite tire/alignment shop here in Alabama. By the way I may be transferred to New Mexico - its all I can do to hold the Trooper back.
I explain to the service writer that it needs a cat and he gives me attitude saying how do I know that etc. I explained that I put my OBDII scanner on it and it shows a catylst inefficiency in bank 1. He said "if it's not the cat, you'll have to pay for our time" I explained it has had a CEL for this before and they reset it and sent me on my way. So I fully expect a fight on this one. Argggg. Worst thing is that it's not even a factory warranty, all they have to do is submit it to the 3rd party warranty company and they'll replace it! Heck they already authorized it when it was at the dealer that went out of bizness (out of Isuzu bizness) but couldn't repair it cause they couldn't get the parts!
-mike
-mike
Biggest suggestions:
Serpentine Belt.
ATF Flush/Fill.
Coolant and other fluid drain/fills.
-mike
Are you going to an independent and getting your extended to cover or is this at a dealer?
-mike
Iteresting though that my IMG went soon after the CAT replacement.
I'm not sure if anyone here will remember me but I had a 1999 Trooper in 2002 and posted to the list pretty regularly while I had it. It was, unfortunately, totalled when an elderly couple pulled out in front of a friend of mine on a coastal road in Quebec. The truck saved her life.
I replaced it with a Chevrolet Avalanche because that vehicle can carry motorcycles as well as people. I'm very happy with the Avalanche but still look with a smile on Troopers when I see them. So I'm thinking about maybe adding a Trooper to the stable again. Is there anyone here who's willing to bring me back up to speed on these vehicles? If I recall correctly, 1998 was the first year of the TODD system and the new engine, is that correct? If so, I would likely look for a 1998 - 99. I don't recall there being any problems with those model years but if there is anything to watch out for, I'd appreciate a heads up. I'm trying to find the link to Paisan's site if that's still going. Interestingly enough, I still have the hitch, nerf bars and rear matt from the 99 that I could use in another Trooper.
Cheers,
Sean Reid
Northeastern Motorcycle Tours
Sean
Not familiar with the soup to nuts the "CAT" and the "IMG" things??
Yes, 1998 was first model year for Torque on Demand (TOD) and the bigger - 215hp 230 ft-lbs 3.5L V6 - engine.
One thing to know about the 1998, and I think 1999, Troopers is the powertrain combinations. Manual transmission in '98 & '99 means shift-on-fly, non-TOD 4WD. The TOD was part of an optional package - I think termed Performance Package. So some automatic trans Troopers in '98 & '99 are shift-on-fly 4WD, and some are TOD. Just something to be aware of.
-mike
-mike
Jim
I have a ticking noise in mine also, but mine seems directly related to the heater/blower. When I turn it off no noise. I have been lazy about getting it fixed, since it probably isn't covered under warranty I just turn up the radio a little bit.
In 2000 they introduced the drive by wire. Also there was a short run of 2000's that had a recall to move a fuel line that could rupture (and did in the IIHS tests). Not a big deal but if you end up in a 2000 something to check.
I believe Isuzu will warranty a new vehicle for 1/2 the original, so if you get a 2000/2001 that had 10/100,000 miles you may still have some warranty left...good luck finding a good dealer, but that is another story.
were the replacement IMGs being installed a few years back an improvement over the original?
Our minivan was taken in due to red oily stuff falling out under it and slipping when shifting into the higher gears, so I expected transmission oil leak, but they gave a loaner car (huge! new Cadillac because I told them we needed room for kids) and they have started work on replacing the head gaskets, they say the red stuff is/was coolant. I have never heard of red coolant. We thought we had a good minivan this time having only been in for repairs 3 times in 36K miles all three times to replace the radio. (our previous minivan was 26 expensive repairs in 45K miles) Now I am not so sure about the current van since once they repair the engine they will start troubleshooting the transmission.
So I am very happy to gain extra respect because my choice of a Trooper has once again prooved more reliable than what my wife drives even though hers is newer. If she could my wife would drive a mini car like a Miata or a hybrid or a diesel Passat, but too often we need to room in the minivan.
I am planning to pull the battery cable today, but I was reading that you can ground the computer and the car will flash you the codes. Has anyone done this or know how to get the codes flashed through the dashboard? I am also going to call Autozone, but don't want to pay $20 if I don't have to.
Still having that "pop" noise from tire/brake area, but i know now is related to the brakes can't tell if maybe it has to do with the ABS or not. I do know that a BMW cut me off and i had to slam on the breaks hard, too fast to realize if i heard ABS kick in or not, but those breaks stopped me and my 4500 lb truck quick like! So, not sure if the pop, or release noise is the brakes sticking or something. Not really sure what to have them look at for either problem.
Suggestions?
Also just got the Yoko's Geolander 051. I have to say a heck of a tire, quiet, smooth and responsive. The previous owner had the tires over inflated causing no treadware on inner, and excessive on outer, plus probably no rotation. Horrible noise and vibrations, but I would suggest these tires to anyone in the city and highway mostly!
So here's the surprise. No loss of oil at all at 2000 miles into an oil change. None, In fact it looks almost brand new. Can still 'see through it' on the dipstick. So, what is the smoke at start up? Is it a headgasket issue? Is the EGR or whatever it's called valve that I see mentioned from time to time? What are your thoughts? The white smoke does kind of smell like exhaust rather than burnt oil, but I dunno. What should I check? 90k miles on the odometer, by the way. Timing belt has been done at ~75k miles. IMG has never been done and I've only seen the symptoms once when I drove up to Colorado and started it one morning at ~20 below zero. It manifested itself as an uneven idle.
Jim
I guess it could also be condensation in the exhaust system.
Water in the gas causing excessive condesation which burns off at start-up? Maybe something in the emissions system went which is changing the fuel to air mixture? PCV, Idle Air Control, EGR, O2 sensor? Maybe a bad catalytic converter causing emission systems problems?
Oil would show on the dipstick and be more blueish. I think white smoke is an indicator of water burning off.
Tom
If due to worn valve guides I wouldn't worry about it - I had a car that put out a puff of blue smoke every time I started it, but it never burned any significant oil.
If the smoke is white, the head gasket may be suspect and as Tom said coolant is leaking into the cylinders. Keep an eye on your coolant level, and visually inspect both the coolant and the oil for abnormal appearance due to cross-contamination if the head gasket is blown.
