Isuzu Trooper
1187188190192193233
  • seanreidseanreid Member Posts: 152
    Hi Mike,
    What does IIRC mean? I've seen this before and have always been puzzled. I did the harness last night and there is, indeed, a brown wire with red tracer in a place where my aftermarket (to fit Isuzu Trooper/Rodeo, etc.) plug doesn't have a spade. My hunch is that this wire is only in the harness of models with diversity in-glass antennas. So, following a post I found in the list archives, I hooked the blue (power antenna) lead from my HU up to this (brown with red tracer) wire and then plugged the larger of the two coaxial antenna plugs into the jack on my HU. Based on the radio reception I'm getting right now (which is pretty good), I'm betting that was the right wire to power the antenna amp (don't know where that actual signal amp unit is located, sorry cwm).
    I think that right now I'm hooked into the antenna in one window of the vehicle and am powering the antenna amp. I'm thinking that if I can get a "Y adapter" to bring the two antenna jacks (one normal size, one smaller) into one normal coax jack then I should be able to pull signals through both in-window antennas.
    Does that make sense? The only wrinkle in this that gives me pause is that supposedly there's a device somewhere that chooses between the two in-glass antennas to get the strongest signal. That might be in the signal booster amp or it might be part of the stock HU itself. If the latter, I'm not sure how well it would work to bring in both amp leads in a Y as one signal. I'm going to ask an installer how this kind of system works in other vehicles that have them, like Audis.
    Ideas and suggestions welcome.
    Cheers,
    Sean
    is
    If I Recall Correctly.
    I am not positive, but that power wire to the wire on the harness of the car is all we did on mine. No Y-splitter was put in place and I get the same reception I did with the stock unit.
    -mike
    O-tay, Mike, so we've done the same thing so far. I suspect that means that we're hooked into one of the two in-glass antennas and the antenna booster amp. I suspect there's a way to get even better reception by using the signal from both sides of the truck. So I'm going to look for an adapter and I'll report back to the list. I live in a rural area and thus will take all the reception I can get.
    Also...I had forgotten how much difference a head unit swap (even before the power amp and speakers are done) can make. The Eclipse sounds *much* better than my stock tuner/cassette/CD changer combo. I've found a place for the power amp to mount and should probably be able to finish up the installation this weekend.
    I just checked mileage again and I got 16.75 with mostly local in town driving (small towns, dirt roads, rural roads, etc.). That includes extensive A/C usage and some time parked and idling with the A/C on. So, I'm pretty happy with that. The Avalanche got 16 MPG on the highway and 13 mpg around town. This Trooper seems to get 16+ around town and 19+ on the highway. I don't have a lead foot though - I save that fun for the motorcycles.
    I'm diggin' this Trooper, have been driving around constantly with the moonroof open and windows down.
    PS: Thanks for the IIRC def.
    Cheers,
    Sean
    Cool sean! I've got the new shocks and springs in and will be towing this friday. So I'll let you know how they are!
    -mike
  • wildbucwildbuc Member Posts: 88
    I got 15.1 mpg towing a 2800 lb. camper trailer and running the AC across the flat N.C. coastal plain last week. Not too bad to me.
    What speeds was that at?
    -mike
  • bstone3bstone3 Member Posts: 97
    Well after replacing the FPR and the EGR valve the Trooper still continued to surge at start-up in the morning for about 30 seconds - again this only happens during warm weather months and only the first start-up of the day. This time the dealer called Isuzu tech support - just like last time - where the codes said replace the EGR - and they had the tech remove the "PCM" module - some computer board or doomahicky - and had him stick it in the freezer for an hour or so - then re-install and see what happens - guess the Trooper had a real hard time starting - so now yesterday -they replaced the PCM module - and as I am typing this I am waiting for my wife to call to see how it started as she goes to work - so let me call her and find out - well - it worked!!! - smooth as silk - only took a year to figure it out - but it all honesty the dealer - Century Isuzu in Huntsville, Al was terrific - they stuck with it -and gave me a car when I needed it - also had them do a full tranmission service(drop the pan, change filter and fluid)- $160. We will be leaving Alabama - soon as the house is sold - and moving back to my home - Montana - The Trooper, my wife, two dogs and a cat are about the only things I am not selling to pull this move off - now we will see how the TOD, mirror heat, seat heaters and slick traction control really work.
    I am interested too. I did the OME Shocks a few years back and am considering putting new springs on this summer.
    What's the difference between the heavy duty and Expedition?
    What traction control? TOD or do you mean the winter start mode?
    winter start - couldn't think of the right words
    HD are like 919, OME regulars are 912 (my first ones) and the Expedition are 929 supposed to be super super stiff compared to the 919 and 912s. So far so good, I haven't even driven it more than 2 miles since they went on... :(
    -mike
    Winter start is a nice feature, but TOD is so great in the snow I have not found a need for it. I did try it once in the mud, but there wasn't enough torque starting in a higher gear to move me.
  • df2000df2000 Member Posts: 60
    Sean,
    "It seems that if you drain and fill the trans when its cold, you'll be underfilling. Is that correct?"
    I think the colder tranny get the more ATF you can put in.
    Since you put last 2q of ATF with engine
    running and it take me about at least 10 min with hand pump, even if you start with overnite cold
    engine(what I usually do) by the time ATF reach the full level and start dripping out, it is already pretty warm. I try to do this service when outside temp still cold to have more time to fill.
    On another note, I read somethere on Audi forum,
    they have similar no-dipstick tranny, and at 80k mi guy was changing factory fill, it was 1q overfill from the factory and no problem for 80k.
    ean,
  • bsmart1bsmart1 Member Posts: 377
    much like you mentioned on the Chevy engines, it's located on the valve cover near the front of the engine on the right hand side as you're looking in the engine compartment. It's right at the edge of the plastic cover on top of the engine. And it has a black hose coming into it as you described. It's L shaped so the hose runs parallel with the valve cover top.
    It should act like a one way check valve if you try to blow air through it. Easy one way, not at all the other way.
    I now feel better informed about the Trooper transmission. One of the great things about my mechanic is that I can hang out with him while he's working on my vehicles and that gives me a chance to see how things come apart, go together, etc. He knows that I do some of my own work so its helpful to watch him. I've also been educating him about the vehicle and he's open minded. He did the tranny filter this morning and based on what I now know, I'd recommend both the self-pumping flush and the filter change to anyone who wants to stack the odds against future transmission problems. Basically the flush he did last week (which uses the Trooper's own pump to move the ATF) did more than a complete exchange of fluid (including flushing the torque converter which a pan-drop couldn't do). After the flush, whatever gunk was stirred up (in my Trooper's case not much) seems to end up on the filter or against the large magnet (which is not on the drain plug) located in the pan. By swapping the filter and cleaning the magnet (after a flush) I think you get a pretty thorough cleanup and the usual benefits of fresh filter material. Based just on my own experience, I'd definitely recommend both services, in the right order of course. You do have pull a cross rail to drop the tranny pan so there's a little more labor involved than we expected.
    It was Creech Imports who told me that the tranny fluid level should be checked with the transmission running and I figure they're a trustworthy source. So this morning we ended up filling the transmission first with the truck not running then started it and added fluid. I'm not sure but I'm guessing it took in about an extra quart once the tranny pump was circulating fluid. So this does mean that I will be checking tranny fluid levels while my truck is running from now on. Naturally the tranny needs to be filled with a pump through that very weird upside-down (so to speak) fill hole.
    I've learned a good amount about Troopers this past two weeks thanks to this list, Creech and my own experience. All worth knowing for a truck I plan to own a long time and work on more and more myself.
    Cheers,
    Sean
    I was towing the trailer down a straight road at about 60 mph with very little traffic. The trailer doesn't have much wind resistance so that may have helped.
    We made a trip to Manteo, N.C., then went south down the outer banks to Ocracoke. Then we took a ferry ride back to the mainland at Swan Quarter. Great trip!
    Ah ha 60mph, haven't seen that towing or not in a long time :)
    -mike
    I'll begin with a disclaimer, which is that I enjoy car audio as a way of relaxing and getting away from work. As such, I probably get more into this stuff than most people would care to. I just finished a great phone conversation with Jim Wilder who is my local signal-in-the-air expert. This guy has worked all over the world in radio, satellite, etc., with the military and the in the private sector, and so on. He installed our satellite Internet system (no DSL out here) and has tweaked the radio systems in our chase vehicles and motorcycles.
    So, for anyone who's interested, here's the deal with the Trooper diversity antennas (as I understand it). As a class, they're called called slot antennas and they're very sensitive to signal direction. They're more prone than other types of antennas to suffer from multipath interference (where the radio signals are coming to the antenna both directly from the transmitter and as reflected signals (reflected from trees, buildings, mountains, etc). Since these signals come in at varying strengths (and with time lags between one and the next) they can cause distortion, signal dropout, etc. The idea with having the two antennas in the opposing rear windows is that at any given time its unlikely that both of them will suffer from the same amount of multipath problems. So the stock radio monitors both antennas' signals and switches to the strongest antenna's signal in milliseconds. The standard Motorola jack in the Trooper goes to the antenna on one side and the smaller jack goes to the other one. The brown wire with red tracer (in the stock harness) goes to a signal amplifier (as mentioned before on this list).
    So when I swapped the stock head unit for my Eclipse head unit (which is not designed for diversity antennas) I had three choices for radio reception.
    A. Pull the signal from just the one slot antenna connected with the standard Motorola jack
    B. Pull the signal from just the other slot antenna connected with the miniature plug (via an adapter I modified).
    C. Connect both antennas in parallel (with a "Y adapter) and pull the signal from both of them simulataneously.
    First off, I did some informal tests and found that both "A" and "B" give about the same signal strength and quality so one could use either one with similar success. Since "A" has a standard jack, one might as well use that instead of "B" if just one antenna will be used.
    "C", though, was interesting to me. First off, these are probably 75 ohm antennas so hooking them up in parallel brings their effective impedance down to 37.5 ohms. Jim tells me that shouldn't be a problem in and of itself for a radio that only receives signals. Using both of them could actually cause a decrease in signal quality if the tuner being used doesn't have a high rejection rate (tendency to reject weak or distorted signals). But, it could also work better than one antenna alone. The Eclipse has a high rejection rate so it should be a good candidate for using the combo.
    So...I've got the head unit set up on the passenger seat and when I get a chance I'm going to drive around comparing signal quality of option A to option C.
    Why bother with all this? 1) It doesn't really take much time (I already have the dash apart for the audio install). 2) I'm curious. 3) I live in the boonies and signals can be hard to get and hold.
    Cheers,
    Sean
  • quickstepquickstep Member Posts: 12
    I recently replaced rear brake pads and rotors on my 02 trooper. It was pretty easy to do because the parts were not rusted in place. The cost was $94.00, including the sales tax. The question that I have is, are the stainless steel shims on the original brake pads important to put in place on the replacement pads. The fit is slightly different, so I omitted them. The vehicle stops nicely. The replacement pads have the main shim in place on the pad mounting piece. Your input would greatly be appreciated. Has anyone attempted to change rotors and pads on the front. I understand this is a bit more extensive due to the disconnecting of the drive shafts in the front hubs.
  • costello1costello1 Member Posts: 60
    I posted an earlier message about my TOD light coming on in 02 Trooper.What I need to know is this , can and if I drive will it hurt the system??? Why does the light go out when I push the 4 wd button?? It only comes on when I am in 2wd , why is that!! What are the possible causes of this light problem?? I think it may be a hose or bad sensor . Any help would be great!!
  • schweikbschweikb Member Posts: 111
    My dealer sold me a bottle of touch up paint for the flares and trim on my friend's 2000 Trooper. The color code is 753-2.
    My friend had this matched at www.eTouchup.com buying option #1, an aerosol can of the matched color and a can of clearcoat, plus something else for a pricey $29 plus shipping. He claims it looks great. The bottle from the dealer did not really match, showed much darker and too thick. I am really not sure what code he used when ordering from eTouchup.com (the code 753-2 or another code he found on the vehicle itself) - but the eTouchup site shows you where to look on the vehicle for the paint codes, maybe you'll find a different code - but be careful maybe the code you find will be for the basic vehicle color (that is the problem I had when trying to get the same trim color matched for my 1998 Troop). I just gave up and bought an off-the shelf product in the parts store that somewhat matches (sorry I lost that little tube).
    Hope this helps.
  • go-to-akgo-to-ak Member Posts: 11
    Hi all- I'm a new member so forgive me if this had been already addressed. I have a 99 Trooper with 40K and want to change the rear (limited slip) differential fluid. I bought Mobil one synthetic gear oil- does anyone know if the Mobil one already has the LSD additive in it? I have a tube of some generic liquid LSD additive I bought at the auto parts store- but not sure whether I should use it, and if so, how much to add to the Mobil one (the LSD additive is probably around 6-8 ounce tube.
    Thanks! Rick
    were the focus on my attention this weekend. Actually the plugs were on my 01'. Noted earlier, I changed the plugs a week or so ago and immediately started having trouble with the engine running smoothly. I changed out 3 on the passenger side, one per day, in hopes of isolating my BAD plug. Well after 4 days of that my wife (who drives this one) said enough was enough. "Get that car fixed"!! was her cry. OK, I'm under the gun so I spent the big bucks for EKG plugs and replaced them all again. I also took the time to clean the rubber boots with alcohol to remove any grease residue from the previous installation. I checked the continuity of each boot wire extension to make sure none were damaged. They each measured 5ohms, all the same. I checked the old (new) Autolite plugs I removed, didn't find anything wrong with any of them to speak of. Each measure about 5-6 Kohms center electrode. Measured each coil pack and verified they were OK. They were. Re-assembled all plug units again and took it for a test drive. All is well again!! I don't know what to think about those Autolite plugs. I've kept them for future use, possibly on my 99' Trooper.
    I checked the PCV valve on my 99' Trooper which has 62K miles on it and it was starting to plug. It was full of carbon deposits and allowing little air flow thru. I washed it out real good with carb cleaner and blew it out real good. Significant air flow improvement. We'll see if anything changes on Oil Consumption due to this.
    OK the resistor in place of the IAT sensor is a work in progress. I took the 4700 ohm resistor out and replaced it with a 3900 ohm. Stopped all pre-ignition under heavy load conditions, but the pep isn't what it was. Mileage seemed to revert back to about what it was with the IAT sensor installed. I took the 3900 ohm resistor out now and put a 4200 ohm in its place. Seems the pep has come back somewhat, and so far NO pre-ignition under load. Will continue to monitor and see if MPG is affected.
  • troop2shostroop2shos Member Posts: 235
    I just had my trusted GoodYear store change out my plugs at about 45k on my '00 with NGK Laser Platnums. For less than $13 / plug & $59 labor it was worth it to me in letting them do the job. The mechanic (performed a lot of work on my Gen II SHO) said that the plugs showed some minor wear but they were in pretty good shape overall but getting them out took some effort pulling the plug boots. I also let them drain & replace the coolant for $29 - full flush done 2 years ago & there were no deposits noticed.
    FWIW, my '00 developed a minor ping last summer that has been resolved. My wife usually drives the truck & rarely, if ever, gets the secondaries to open. I started driving it more to exercise the engine above 3500 rpms which almost eliminated the ping entirely. However, as the load ping was clearing up, my battery was starting to fail causing the ping to redevelop. No ping whatsoever now since the battery was replaced last winter. So far, my oil consumption remains at about 1/2 quart every 2500 / 3000 miles. I keep reminding my wife to get on the throttle once in awhile (my procedure for DOHC engines w/ secondary / 2-stage intake butterflies).
  • jimmyp1atworkjimmyp1atwork Member Posts: 42
    Are no longer working both in the car and on the keyless remote. So, I think it's an actuator type deal. Seems like I saw something about this once, but I tried a search and it seems to not be functioning right now. For a while, it worked intermittently, but now I don't even get any noise from the switch. When trying to lock it with the keyless remote, it beeps, but nothing happens. Any hints?
    TIA,
    Jim
    Maybe a fuse or loose wire someplace. I would check the fuse first. Do the windows still work? Have you tried to lock and unlock with the key, twice in the open direction should open all the locks and opposite with locking.
    Here are the links to the Mobil1 Gear Oil datapages:
    http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Synt- hetic_Gear_Lubricant_LS_75W-140.asp
    http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Synt- hetic_Gear_Lubricant_LS_75W-90.asp
    They both say they include the limited slip already, so no additive should be needed, but don't take my word for it read the above or call Mobil1:
    http://www.mobil1.com/index.jsp at the bottom of the page there is a "Contact Us" link
    you'll know real quick if you didn't get enough in there, or if it wasn't included in the Mobil 1. As you go from Reverse to Forward you'll get a chattering shudder from the rear diff. Been there, done that!
    Thanks for all the info guys!
    RB
  • cwmcwm Member Posts: 42
    Has anyone gotten the Check Engine code that the EGR is clogged? How do you unclog it?
    windows still work, but even the key in the door lock does NOT work now. I thought I smelled something electrical getting hot last night, but I realized it was a boat cover I had in the back (paranoia, I guess). I'm stumped. I guess the key in the door lock not working could mean fuse or actuator. I'll check the fuse tonight. I sometimes still think I'm hearing a little click when I try to make the locks work.
    Jim
    YEP, see topic about 2 pages back. Remove it and wash it out real good with carb cleaner. Test it by pressing the pintel in and it should spring return to the closed position. If it doesn't, clean it some more and rotate the pintel with a Torx driver, pressing in and out until its free.
    Are you saying that I should remove the EGR valve and clean out that out or should I remove the top manifold and clean down in there?
    Here is an update on the use of Chevron Techron Injector Cleaner that I added to the gas when I had a Check Engine code "P0401 EGR Flow Insufficient" ---- the Check Engine light went away about 60 miles after I added the cleaner.
    Still, it might be interesting to look at the EGR valve like bsmart1 mentioned in his post to see how much buildup is there.
    Be careful not to damage the graphoil gasket. 2 bolts and it easily comes off the maifold. You'll find it full of carbon deposits, I bet.
  • bawbcatbawbcat Member Posts: 118
    I've recently noticed some intermittent pinging in my 98 Trooper. Initially, I thought maybe it was just a bad tank of gas, but I'm still hearing it with a fresh tank. I hadn't heard any pinging previously. Any ideas? Thanks.
    Try dry-gas or STP gas treatment? Maybe there is water in your tank, filling up might not resolve it until it all works out.
    I had pinging (not same as valve ticking) with my 1995 occationally, usually when partially letting off the throttle after a heavy throttle use. I would correct it with a Valvoline 30000 mile gas treatment (they make a 3000 mile gas treatment, but I don't make a habit of additive use) and a tank or two of premium, then change the oil to make sure none of the stuff "cleaned" by the additive contaminated the oil. Always worked for me.
  • dnestrdnestr Member Posts: 188
    Why do you think this sound comes just from the engine? I noticed pinging in my '99 3,5 just in a couple of minutes after engine starts. It had been pinging for about 5 minutes and stopped short as the engine had got warm enough. My mechanic said that it depended on some electric device. He meant a sensor or something.
  • nicksmomnicksmom Member Posts: 1
    When I bought a secondary remote they pointed it at the dome light! I laughed, but they said that's where it was!
  • doublesharpdoublesharp Member Posts: 32
    Thanks for the tip. I've ordered three touch up pens plus clearcoat and it shipped today. I'll post again after I get to match it up with the original paint. Touchup.com is a well organized website with a lot of good info. Hope the paint match is as good as the website.
    Let us know how it works out. It is a pretty good website.
    Ok, the jury is no longer out on these.
    They are positively the best springs and shocks for the Trooper. I just towed the race car on the trailer totalling about 4500lbs behind the trooper that was loaded with stuff for the lakehouse up the NYS Thruway. It was almost as if the trailer wasn't there. Totally amazed at how stable it was and how it kept it level. The expedition springs were great.
    I set the cruise on 77mph and left it there the entire trip. The motor worked hard but handling was great.
    Still in awe of it.
    -mike
    paison,
    I have an anoying daily set of speed bumps that I cannot avoid. Right outside of where I work there are three "speed bumps" or "judder bars" whatever they are called. All of them are about 8" (20cm) high and 16" (40cm) wide. They are at different angles. The first is perpendicular so it hits both front wheel at once. The second is angled enough that each wheel hits it one at a time. The third is more angled so that one rear wheel hits it before the opposite corner front wheel is off of it.
    These give a very bouncy ride one after another all three within 100 yards (100m).
    I wonder how does your OME / Swayaway suspension handle such a set of bumps? Would I be best to get the same that you have or softer to limit the bouncing?
    Would the setup you have be to stiff when the wife rides along?
    Thank You
    I visited a truck proving grounds recently. There is a track that is sort of like two sets of stairs, one for each side of the truck, that are out of sync. This would be a fun test for Troopers as well, I think my stock Trooper would probably make it across, but drag bottom in a few places.
  • crqfliercrqflier Member Posts: 5
    How long is the trailer you pulled? Did you use a weight distribution hitch and antisway? I'm considering pulling a 20 foot camper trailer (weighs 3200 lbs dry), but friends are telling me to not even try pulling a long trailer with a short wheel base SUV (1995 Trooper) - that controlling it will be extremely difficult. BTW, I've got Bilstein shocks and OE springs.
    After owning all kinds of SUV's both domestic and import in the last ten years my 99 Trooper I bought last year has quickly become my all-time favorite.
    For those of you that have had Troopers for awhile- what other message boards and websites have you found useful to learn more about the Trooper? Thanks!
    It is a really cool vehicle isn't it? I've owned a bunch of different SUVs, etc. but I have a particular fondness for the Trooper. Edmunds does not like to see links to other dicussion boards here so e-mail me at sreid@sover.net and I'll give you what links I have.
    Being in the midst of an extensive audio install right now (which has involved disassembling doors, parts of the interior, etc.) I can say with confidence that the build quality on my 1999 is tight - everything fits exactly, everything has a cover, sound damping is all over the place, etc. The plastics and connectors are much like the ones I've found on the Toyotas I've owned.
    Frankly, this makes an audio installation much more difficult than it was on my GM trucks and SUVs. The GMs have looser fitting panels, more uncovered areas, etc. - routing wiring, etc. is a cinch. The Trooper, however, requires time and planning. At the same time that I'm grumbling to myself as I fuss with the Trooper pieces I'm also quietly admiring how well made the whole thing is, including parts in places that most owners will never see.
    Knock wood, but for the first 1000 miles since my oil change (Mobil 1 10-30) I've had no measureable oil usage. Last fillup (local driving - backroads and dirt roads mostly) showed 17.2 mpg.
    Cheers,
    Sean
    I have two Isuzu Troopers - a 1999 I purchased new currently has 65,000 miles, and a 1998 that I purchased with 98,000 miles on it. I am impressed that Troopers with 100K miles on them still drive nearly like new, still look great, and feel they can easily go beyond 200k miles. I remember the old GM cars in the 1960's and 1970's that seem to be worn out by 100K.
    Troopers have a special character that most people are quite unaware of. Too bad Isuzu-America could not recognize that and do a better job of marketing.
    I bought a 96 Acura SLX last summer for my wife to use as a niece and nephew hauler. I got a good deal on a 1 owner that had 125,000. I had the timing belt and water pump changed and we fight over who drives it. I've driven full size GM suvs since mid 80's and I still loce GM but Troopers have won me over. I love the 2000 2wd limited I got on eBay. I really like the premium sound system and the moonroof. The backseat is super comfortable and for a relatively small vehicle there is a huge amount of space. My 2wd is a little quicker but the 96 runs strong. 2wd gets a little better mpg but neither gets bragging rights. I like em both.
    I tow a 18ft car-trailer with my '96 Impreza race car on it, 1900lbs for the trailer, 2700lbs for the car and then add gear etc. Easily up at the 5000lbs limit.
    I tow it with the Hidden Hitch and 2" ball. Single Axle electric brakes (that aren't currently working :( ) and no weight distributing hitch or system. I would say you'd want to upgrade to the OME 919s or 929 springs in the rear they should work well with the bilstien shocks. The OMEs really made a big difference in towing, also I have larger than stock tires which probably doesn't help much.
    Controlling the trailer is not bad at all, with campter trailer you'll probably have to go slightly slower than my 75-80mph pace if you have crosswinds.
    -mike
