Visitor Agreement.
Also, IIRC, Volvo (V70/S60/S80), I believe is limited to 1100 pounds w/o trailer brakes. Ford is somewhat sneaky on this issue. There is no mention of trailer brakes in their owners manual (at least in my Explorer's manual, and I believe[?] all new Explorer/Expedition manuals). However, if you ask for their "Trailering Guide," which is a brochure, it "urges" people who tow, to have trailer brakes on ALL trailers.
And, yes, all these vehicles have a much higher maximum* tow rating.
* = Read the fine print! In the the brochure it will usually say something to the effect: "with proper equipment," which means check the owner's manual. "Proper equipment" is often code for trailer brakes, as well as other possible items.
Bob
I try to avoid trailers like the plague - no telling how many of them are brakeless, overloaded, etc. There oughta be a law!
If you're wondering if you're doing it right, check out the Towing tips for SUVs for some expert advice.
Steve
Many already having warning stickers, of some sort, on the hitch. None to my knowledge mention trailer brakes.
<< There oughta be a law! >>
There are laws. Virtually every state has trailer brake laws. The problem is the state laws often list higher weights than the manufacturers do. Here in Maryland every trailer over 3000 pounds must by law have its own brake system. Well, what about all those vehicles with a manufacturer's limit of 1000 pounds? There's a 2000 pound discrepancy between what the manufacturers say, and what the law requires. To top it off, trailer dealers only comply with the state law, so you won't find any trailers here in Maryland, that are rated under 3000 pounds with trailer brakes. In addition, every trailer dealer that I've spoken to, has been ignorant of vehicle trailer brake restrictions.
Bob
The ones that really scare me are the home-made trailers overloaded with firewood heading back home at dusk after working in the woods all day.
Steve
-mike
We used to do that when we were kids. Of course, we'd sit on top of the pile of wood, throwing acorns and rotten apples at other cars (until our friends' father who was driving found out!).
Steve
Bob
-mike
Bob
I had a trailer in the mid-70's (homemade by someone else). I knew zilch about towing and maintaining it and didn't learn much while I had it. I figure a big percentage of towers out there are as dumb as I was.
Steve
-mike
Steve
My reaction: What a bunch of legal-manuevering hoooey!
I *sincerely* wish all of you Escape/Tribute owners good luck and safe driving.
Our only stall happened three weeks after we drove it off the lot. "Poor maintenance" had nothing to do with it. I always use good gas like Citgo, BP, or 76 too.
Even though I am 99.9% sure that our Escape will never stall again, I still follow this issue pretty closely. The NHTSA has closed their initial investigation into the stalls and opened a new one (the engineering investigation) on the same day. The next step is a recall from what I understand.
-mike
There are better, and there are worse brands than these. I said good, not the best. Exxon, Mobil, and Shell stations just happen to be few and far between around here. I've never heard anything bad about the others though.
I forgot about Sunoco. I do use their gas quite often. They, Citgo, and BP have several stations close by. Texaco is really close, but I tend to pass them by all the time for some reason.
Where can you find quality ratings for gasoline anyway? Please don't say CR either.
-mike
I suspect the vast majority of owners who have experienced stalling, even repeated stalling, haven't reported anything to anyone if their car restarts after failure. I also wonder how the Ford/Mazda network handles complaints versus repairs -- my guess is that no one is keeping track of the stalls that aren't registered by mechanics. Likewise, not many people go to the trouble of contacting NHTSA and/or their local Consumer Affairs division to "get it in writing".
-mike
From the get-go, this problem has had all the features of bad electronic design in the Escape/Trib. Automotive computers can be very tricky -- the symptoms manifest in erratic mechanical failures, but the root problem can be a tiny solder break, power supply fluctuation, etc. The variables are crazymaking compared to the good old days of tracing an electrical (not electronic) or mechanical malfunction. If someone's car stalls, they might be told it was a fuel system failure, or transmission failure, etc. due to the symptoms, have a mechanical part replaced (under warranty, shops still make their money doing this), and still have the same intermittent problem with the electronics that will crop up again, sometimes in another part. I doubt manufacturers relish the prospect of negotiating an ECM, BCM, etc. redesign and then recalling every vehicle that has a computer with an established flaw -- so much easier and less expensive to stall or use the band-aid approach. (How long did Ford know about the Explorer/Firestone problem before they moved to resolve it? History does not support Ford's proactivity with regard to resolving safety issues.)
Imagine the law suit of the first person seriously injured or killed because of this. Sad to say, Ford/Mazda are likely cost-factoring that likelihood, as most manufacturers would. If my car stalled, and word was circulating that there may be a manufacturing defect behind that with no solution, I'd be contacting lots of consumer protection agencies to register my concern.
Octane is the only reliable measure, and even that doesn't measure the quality of gas, only it's resistance to pre-ignition.
This stalling issue is strange, because the Duratec engine has been used for years in the Taurus, and those haven't been too bad (about average).
I actually expected the weak link to be the CD4E tranny. Mazda used it in the 4 cyl auto 626, and those were just horrid. In the 626 topics, you'd be told to avoid that drivetrain combo at all costs.
-juice
Yes I did. I didn't even know that you could until I started searching around for the problem on the web.
Someone on another forum actually requested the documents from the stalling investigation. As I recall, the NHTSA did send a letter to Ford stating their findings, and that document on the 'problems' board is just Ford's reply to their findings. They (Ford) are just agreeing with the NHTSA's findings in that letter.
Since 'step 2' of the NHTSA's defect investigation has been opened, it seems to me that they are still trying to figure out what to do about it.
I actually expected the weak link to be the CD4E tranny."
Yes, it is rather strange. That's one reason why it has been taking so long to find an overall solution. I still think it is some sort of PCM programming mistake though.
Cost-cutting can happen at the employee level too.
-mike
-juice
I've heard that Chevron dumps "techron" in the tanker trucks just before delivery so the otherwise identical gas doesn't wind up at Exxon with techron in it. Makes for good conspiracy theories if nothing else.
Steve
SF's were stalling due to something around the camshaft being mismanufactured, and the CR-V's were stalling due to premature wear on what I think was a starter wire. I can't remember the exact parts, but both were causing stalls among other things.
It happens, but I agree that it should not happen to so many people at once.
-juice
Which CRV's had the stalling problem? I have never heard of that.
Regardless, recalls have been done for much less.
Sounds like they're focusing on sloppy electronic design and/or integration, which makes lots of sense given the complaints. I hope they figure out what's going on before someone else gets rear-ended or worse. It must be enormously frustrating to be the owner of a randomly stalling car, no matter what the brand. Even owners with otherwise flawless Escape/Tribs will be much relieved to know if a fix is discovered.
You claim that 'recalls have been done for much less'. Recalls are generally only issues if there is a safety issue involved. In this case the NHTSA's own findings show there is not a safety hazard with the Escape.
Also, why are you trying to speak for Escape/Tribute owners by saying 'Even owners with otherwise flawless Escape/Tribs will be much relieved to know if a fix is discovered'?
In order for one to feel a sense of 'relief' would require one to be feeling 'uneasy' about currently driving their Escape. There are hundreds of thousands of owners who are completely satisfied with their Escape and know it is a safe and reliable vehicle.
I appreciate your perspective as someone who doesn't like Ford. Your tactic (which has unknown motivation) is to maximize or make more of an issue than there really is. Not very creative but the best you can do for now..
Where are you getting that "the NHTSA's own findings show there is not a safety hazard with the Escape"? That has yet to be proven.
I've read more than a few compelling posts here and elsewhere (including the biggest Escape board) from those who have had problems with stalling. For example, one was from a guy who was concerned about his mother freaking out behind the wheel when the engine died. Others are not enjoying their Escape/Tribs because they are constantly on alert for the next stall. Let's see where the recall investigation goes. Meanwhile, it's patently unkind to minimize how annoying and/or scary this situation has been for owners of stalled cars, whether by someone on this board or by a corporation.
And let me confirm this for everyone: I *do not* have a problem with Ford products. I have owned them, and have had good experiences with them. Once they resolve the stalling issues and confirm it is indeed as reliable as most alternatives, I'd be very comfortable recommending an Escape/Trib to a friend -- it is generally a very good design (I like the Tribute a bit better). I *do* have a problem with corporations that evade issues and dodge accountability. Don't you?
I have a friend with a Tribute, and I think these are great vehicles, and I really hope all these seeming shots in the dark to fix this problem have finally paid off, because I truly do NOT want to think of his wife, who is a timid driver already, being behind the wheel of this thing if it does stall unexpectedly while she is driving.
Let's not buy TOO MUCH into the legalese hype of the Ford corporation, whose wording is such as to not admit liability in the typical manner of lawyers.
2. Park you Escape on some RR tracks, and get out.
3. :-)
1999's and earlier. I think the recall involved some other Honda and Acura models too.
Here's the text from the NHTSA site:
Year: 1999 Make: HONDA TRUCK Model: CRV Recall Date: 05/20/2002
Type of Report: Vehicle
Potential Number of Units Affected: 1000000
Defect Summary:
ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES, ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS STARTED.
Consequence Summary:
WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
Corrective Summary:
DEALERS WILL REPLACE THE IGNITION SWITCH. OWNER NOTIFICATION BEGAN JUNE 14, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Ah, if only I could get rid of it!
My sister has a 99 CRV, I wonder if hers is effected. I should ask her if she recieved a letter.
It's quite different, IMHO.
-juice
