Visitor Agreement.
Just make sure you have the right kind of control module, as not all can be programmed (only newer ones).
Stephen Hitchcox
hdesign@ica.net
It is unwise to post your email address in a public posting - the spammers love harvesting them and the consequences are predictable.
BTW - welcome to edmunds.com!
So far delighted.
Frank
Only comment is that the horn sounds tinny, but intend to get transmission fluid changed as well as diff and transfer units. Has anybody put on a transmission cooler. I have one on my Chev Venture and for $200 seems a worthwhile investment.
New member here. I have a 2004 Suzuki XL-7 which I love and spent alot of time in. I have a Aftermarket head unit that I want to install that was in my 99 Grand Vitara. But everywhere I look I can't find a installtion kit.
Does anybody have an idea where I can find such a beast if it exists?
Worth calling them, if not already done so, but but put car radio installation kit in your search engine - google as it will bring up a lot of info.
I am looking into a 2005 Suzuki XL7 it is used with 650 miles. They are asking 21,900. That is just on the site. I have not talked to anyone yet. I was hoping someone could tell me about how much they have been paying.
I was also wondering about the comfort and convenience. I have a 12 year old and a 9 year old. We are military so we travel around a lot.
Thanks to anyone that can help a little.
I was wondering if you could provide me with the Tire brand and #s you made reference to in your message posted on 3/14/05? I would appreciate this.I have had nothing but problems with the original tires on this SUV,they are the worse tires I've ever had! Thanks for the info.
Linda
Anyone else care to share their experience? I'd like to hear from you.
As I had drained the oil, decided to leave the old one on as it it went in three days later for a transmission change plus I had the front/rear differentials done as well as the transfer case. So the transmission guy took the old one off and put the new one on for me. $170 the whole lot.
It looks as if it will require a short extension on the socket wrench before it goes into the filter end cap to get at it from the top. It cannot be done from underneath without a lift or you have a pit in the garage floor.
I did want to put on a transmission cooler, which I had installed on our Chevy Venture on the front of the radiator for maximum efficiency, but on the Suze there is not any room.
Fram do one with that black grip stuff on the end, but it seems a small filter compared with the Purolator or whatever was on there. I do like the oil drain plug location and allows you to drain everything out. I normally alllow an hour after a run.
Using Exxon 5-30 which I have found the best across the board.
In Japan, where cars are right hand drive, the oil filter is probably not in a bad location. However, with the steering linkage and master cylinder/brake lines moved over to the left side of the engine compartment for North American vehicles, the oil filter location becomes a headache.
Two weeks ago, I traded in my 2002 for a 2005 XL-7 LX3. The 2005 is a beautiful vehicle - Suzuki did a lot of refining on the XL-7 in three years. However, the oil filter is still in the same location. Guess I'll need to keep my contortionist skills intact for the next several years.
Got it on line at Fox Performance in Grand Terrace CA for $30.82 plus the Filter Care Kit for $8.68. UPS Ground included.This was the best price I could find.
I bought it used from a Subaru dealership and they have no idea about it. The local Suzuki dealership also says that they have not heard of this and that it must be aftermarket. Any help would be appreciated. Thanks!!
Ivan, kc5yti
2002 XL-7+
Regards
Got them at NAPA part 4899 which costs 33.49 for two...This is about the cheapest I could find and the NAPA sales person thought there was only one per box.
As info Suzuki also make a carbon impregnated one, approximately $45 each.
I have a 2001 XL-7 I had it since brand new, pretty much it has been a wonderful vehicle almost 100,000 miles and kicking!! only major work done was brand new sets of tires and a clutch!!, now the problem that I have is that since new everytime I depress the clutch pedal (when cold) it makes a squeaking sound; the dealer says that it is normal but I just want an answer from you all and also why it does it? i will really appreciated.
Manually put the cap on the old filter (I had a 22821 on there) and place the extension into the end of the socket. ( This has to be worked under the steering column shaft). Connect the ratchet drive to the extension but the handle must be pointing down at about the 4 o'clock angle. Once in place you can lift the handle up and rotate the filter.
I did not remove it at first, but then drained the oil sump. Some of the oil from the filter drains out, but not all of it. I would suggest putting an old rag under the oil filter as some will spill out.
At first it would appear that you cannot get the oil filter out between the engine and the steering shaft. However just move it over to the space by the brake servo and it will slide through.
Once I had cleaned the male part from the engine and slightly oiled the gasket and the internal thread of the filter, it was time to get it on the engine.
This is tricky. Take the filter down under the servo and hold in your left hand as you reposition your right hand. Move your body round to the front of the van and use your right hand to screw it on to the thread, which is all done by feel. I found it difficult to screw on working over the left fender.
Once filled with oil and tested go to the refirgerator!
Next day the light went off concluding the gas cap was the problem, so I put back the new PCV and later today the light came back on. Have put the old one back and trust that light will go out by tomorrow.
Has anyone else had this problem as plan to get one from ther Suziki dealer
Frank
Did I do something wrong when installing the new battery? Did I get some bad gas? Or do I just need to break down and take to be serviced. I really don't want to take it to a dealer. I have taken it into two different dealers and had to get REALLY UGLY to get them to finish the job (recall). I really love my XL-7, it has been a great car other than this "hiccup." Suggestions PLEASE!
I have a situation when the check engine light came on and put down to the gas cap not being clicked. I then happen to change the PCV valve then I put the Suzuki one back. The light came on again and although you can take of the neg terminal for a minute to defeat the light it will come back on. This is not a good thing to do as it will mess with the computer
I have a bad O2 sensor and there are four on this wagon. 2 Front and 2 Rear left and right. The mechanic checked them all out and has had to order one from Suzuki dealer and should be in in a few days.
It is worth the peace of mind to get it checked than fiddle around with it.
Also does anyone know of a good upgrade cd player for the xl-7, ones that also not too pricey, i prefer a cd/cassette combo if possible.
Thanks for the help
