-Ret
I know that one of the problems that Toyota is looking in to is piston related. I don't think this noise is from the pistons. I have an appointment with my Toyota District service rep today. I'll post if I learn anything new.
Does anyone have trouble getting 26 gallons of gas in their tank. No matter what I do 20 is the most I can get in.....
IS there any emptier state than "empty"?
-Ret
I think Lexus will build a SUV based on the Sequoia in order to compete with larger luxury SUVs like the Navigator and the Escalade. Like the void that existed in the Toyota SUV line-up for a true full-size SUV, I think there is a need for an ultra-luxury, true full-size SUV in the Lexus SUV line-up. My guess is that the 2003 model year will include a Lexus Sequoia when a larger i-force engine is available. I am sure that they would change both the front end and tail lights for a different look but I personally don't think the Sequoia's tail lights are ugly as is. They are certainly distinctive. Like I have mentioned before, I think the Sequoia is the SUV equivalent of the Avalon in styling. The styling cues are similar on these vehicles.
About gas mileage computer, I think the general rule is not to trust computers. I've owned two cars with a trip computer, and none of them ever gave a decently accurate reading. My Seq. has a useless trip computer because it was bundled with some other option that I wanted.
With respect to the Seq., does anyone know how to reset the gas mileage/trip computer? I can reset the trip computer on my Volvo 850 because there is a reset button. However, I can find a way to do that on the Seq. If it can be reset, it might give a more accurate reading.
Did your SR5 have side airbags?
If I don't get the hitch as part of the AH or HQ options, then am I missing additional wiring or cooling or something as well?
jb
Trip computer reset instructions correct.
I had factory fog lights installed by my dealer. Used Tundra switch in blank spot on dash. Looks very good. Cost an arm and a leg though (Canadian dollars don't forget).
-Ret
Somwhere in the manual, it indicates that there are 4-5 gal of fuel left in reserve when the fill light comes on. I have managed to put in max 21.5 gal, after driving several days with the refuel light on. As I recall, the DTE indicator was below 15 mi at that point. I wasn't willing to go much further... it takes a little while to learn the limits of a new car, and running dry is a pain, even if your only a couple miles from home.
I have a friend that says: "If you keep the top half full, the bottom half takes care of itself." I don't take it quite to that extreme, but get real nervous driving in the wide open spaces out here (UT) if the tank gets too low!
I recently saw a couple of postings regarding this topic. Most notably someone who was skilled enough to install an after market unit along with an entertainment system and someone who had looked into the price that Toyota had itemized what the unit and its accessories would cost. If there other information out there I would appreciate it. Thanks.
That is a very important question. In my case, my SR-5 did not have side airbags and thus this was not an issue. I researched this anyway at the time. If your vehicle does have side airbags, most seat heater manufacturers will not recommmend installing after market seat heaters and will not be held responsible if the air bags fail. However, it may still be possible to add the seat heater if you use a highly qualified and reputable aftermarket installer. Personally, if I paid for the side airbag option, I would not mess around with aftermarket seat heaters. Heated buns are not worth defeating a safety feature.
Thirdsuv: I am guessing from your question that you have side airbags and I believe that you also have the PM package. Boy, I bet this really makes your blood boil that Toyota left out the seat heaters in the PM package for the SR-5. And since you have side airbags, adding the seat heaters is tricky proposition at best. I feel for you.
Just curious.
This was a very expensive vehicle and given Toyotas quality claims, we expected better. Perhaps I have been duped into thinking there was something better than a Ford truck out there. I realize now, I paid a premium for a Sequoia that is no more reliable an Expedition would have been.
Anyone have an idea when there will be a fix for the "click"?
Does the tow package on the truck (which I have) include a transmission cooler. I see a small cooler type unit in front of the radiator but not sure of what it is. I have not taken time to look that carefully. Thanks.
Well the toyota party line is that heaters and side airbags are possible but only to be installed at factory. However, you can be sure if somebodies heater broke on a Limited, the local service guy is going to replace just the heater, not the whole seat as a package. I'd bet $100 there is nothing unique about a Limited/side airbag seat then an SR5/side airbag seat. Therefore REPLACING a heater in a Limited would be no different then ADDING a heater to a SR5.
However Toyota has taken the position that they would rather *iss people off then do the go the extra yard. So be it, but I'm gonna make em pay for my loss.
Yes, I believe that when the fuel light goes on there is still 4-5 gallons of gas actually left
(70-85 highway miles). But you don't really want to find out the latter.
With regards to quality, for a first year model I am still impressed that the problems are not "that bad." Lemons are always expected, no matter what brand. For those who can wait, it might be smarter to do so. Fortunately, my SEQ is SMOOOOTH.
The Sequoia is an excellent vehicle, and all the comments have helped with the purchase. Thanks again.
I realize this is a new model and problems do arise. Problem is, I still have a truck with an engine that clicks. It's most annoying and doesn't have a chance to go away as my ride to work is only 10 minutes (tops). Basically I hear it all the time (unless I have the radio on). The service manager at my dealer seem to think they will have a fix soon. Does anyone have any info? I just feel like I made a mistake buying this truck. We had 2 or 3 problems with our Explorer, but at least they were always fixed same day.
I have the same thing when filling my tank. They claim 26 gallons but you can't use 4 of them. I'm already over this one.
a bunch of nit-picking old ladies in My life. One person thinks the tires are to small, one
wants to take apart a brand new 40K plus SUV and try and improve on the sound insulation. And this just go's on and on. First off all, I think half of you don't even own a Sequoia,and second for the ones that do, why don't you do what the car was meant for DRIVE IT AND ENJOY IT. For the few little problems that this SUV has as compared to the US competition,We have a JEWEL, Lets be real about this. I also own a '99 Avalon and between the 2 cars have a large investment. Believe me there the too best cars I have and most probably will ever own.
BTW, mine are the P265/70R16 Dunlop AT21. Is this what you have on your truck? I was relieved that they were NOT firestone/deathstone tires.
Just my 2 centavos.
I think what bothers me the most is not so much the problem itself, but the not knowing if/when this will be fixed. Toyota better do something soon or this will be my last.
