AC, CC, DR, FE, PG, RL
DO, P1, L1, W1, SS, AZ
DD
Invoice price quoted to me was $34,531 just trying to be sure.
I also have an occasional dashboard sound -- it is a body flex induced click that turns into a full squeek now and then, and only happens when the temp. is below 60 (colder is worse). It appears to come from where the dash joins the window, but more likely originates on the underside of the dash (maybe the defroster/dash interface). It seems to happen in two places -- behind the instrument cluster, and in the corner on the passenger side.
Some Tundras seem to have a similar problem (see TundraSolutions.com "dash click" or "dash tick"), but they haven't solved it (for sure) yet.
It's probably won't be back until fall, and it is certainly not enough to give up the truck. But it does keep it from being nearly perfect.
Oh didn't you just love trying to find your post amongst 2000+ posts yet alone trying to find someone elses post that you're very vague about date?
When oh when are we going to get a REAL search engine for this TF?? When I asked this question a couple/few months ago I think we were told it was a month away. And of course I can't find that post to check anyway.
AC, CC, DR, FE, PG, RL, DO, P1, L1, W1, SS, A2, DD
Quoted as $34,531.15 (invoice price).
Just trying to verify since Dealer Installed Options are hard to research.
http://www.independent4x.com/item.jhtml?UCIDs=859098%7C928542&PRID=846484
The moulding on the passenger side door was still not properly attached and appeared to be peeling back in some areas as well as having little spaces between it and the car in other areas. Under the SR5 emblem there was "dimpling" in the paint (for lack of a better term) there was still some overspray on the rear window and an area of overspray on the front passengerside door which wasn't supposed to be painted at all. The moulding around the rear wheel well had obviously been removed and replaced and just didn't look right anymore either.
Toyota was horrible, and placed all of the blame for problems on that of the body shop. (Remember, of course that the car should never have been at the body shop in the first place had Toyota not made the original scratches) The body shop guy was so sincere in his efforts to fix anything we wanted fixed but no matter how you slice it, unfortunately once a car has been disassembled, painted and reassembled, it will never be quite the same. It takes a critical eye to see the differences I point out, but they ARE there and through no fault of my own. So I told them I'm not taking the car at this point and I'll contact my attorney. (Which of course, will cost me as well!) The only compensation they have offered is a $330 refund of the cost of the detail jobs. Nothing for the non-original state of the car, inconvenience, depreciation etc.
I am disgusted. Please, please remember.....
NEVER USE CONCORD TOYOTA IN CONCORD, CA!!!!
I think I'm going to print out some signs for my car windows that say "Ask me about the service at Concord Toyota" Or "Don't use Concord Toyota if you know what's good for you" Maybe that will get some reaction from them.
Any further suggestions?????
Probably not the same issue as others, but now the truck is again silent.
thanks,
gator
and could see a little better. Due to the danger of driving so slow I finally pulled off the highway.
Sitting still, there was no problem in visibility. I thought the rain had nearly stopped so I pulled back onto the highway and immediately had difficulty seeing through the windshield again. It appeared that moving through the rain was the difficulty.
I have a 93 4-Runner, a 96 Camry and a 90 Celica in addition to this Sequoia SR-5 and have not experienced this kind of difficulty before and I have driven in lots of rain before. Has anyone else had this difficulty?
Would the bug shield deflector, or whatever it's called, help in this case.
all information appreciated.
I have no problem seeing through my windshield in heavy rain. I'd recommend using Rain-X to improve visibility in the rain. I'm not using rain-X now but I should do so for the rear window. The wiper in the rear makes lots of rumbling rubbing noises when its wiping. I'd also recommend getting your eyesight checked. This is not a smart-aleck comment.
I will definately try the Rain-X. Speaking of having eyes checked, I did that about 2 months ago and had no problems. That was a good suggestion though.
I guess the question I have now is for anyone who has had the bug deflector installed. Can you tell if it helps deflect the bugs AND also help deflect the rain over the windshield.
Dana S. Livingston
Manager, Town Hall
Edmunds.com
The fog lamps are going to be an option (LF code) built into the SR5 models at the factory (not as a PPO).
The keyless remote entry is broken apart from the "CQ" package. Meaning, those who favor the keyless entry but prefer no overhead console or the little extras that come with the "Convenience package" will be able to have the keyless entry separately.
That's all so far!
-Ret
Hmmmmmm. I would think that there would be about 100 off-the-shelf commercial apps and a few dozen free apps that would do this especially since most free BBS's provide it.
". Again, it's not completely complete...but ALMOST!! "
Something tells me I better write this post number down so I can find it in a few months.
I hope to be proven wrong.
Drew
Man I've been on the TF since January and never relized that feature. Thanks
there won't be any disadvantages to owning a 2001 Toyota Seq. this isnt a new car company - toyota has been around for some time last i checked. the changes for 2002 are so minor its not even worth discussing. lets discuss changes when Toyota decides to put a real stereo in the vehicle with steering wheel audio controls, adds wood trim option, a bigger engine option, backup sensors, and moderatley comfortable arm rests. its quite amusing reading about all these trivial changes "the 2002 will have a fog light option with abc package, but no engine comes with the xyz package" "the def package will have green hammertone trim to further look ridiculous next to the oak interior, and the wxy package will have a keyless lock system that prevents owners from getting in to the vehicle all together"
http://www.jimbarkleytoyota.com/pricing/new_cars/inventory.asp?model_id=93
Thanks for the link to the hitch-mounted bumper guard.
That might work, maybe with tie-ins to the frame on each end, since it could have to support the weight of the vehicle's back end sliding down a rock ledge.
I'm not adverse to a little cutting and welding, as long as it's not on the Sequoia itself.
And yes, it was a pain to locate that old post. Fortunately I remembered roughly when I posted it, and that narrowed the search.
Thanks for the info on the bike racks-we went with the yakima Terrafirma, easy to use.... only problem is that the cradles are a little too big for our kids bikes.
Also for those of you that have lost part of your roof rack, we lost the rear cover piece also-replaced under warranty in two days.
Have a wonderful and safe weekend
The 2001 LC "boomy bass" problem can be fixed. (Can read post #823)... You can have the dealer order part # 86280-0W060-C from JBL. Took us less than 10 days to order and have fixed. Sounds great!
This may be old news, but anyone know if this is the same problem as reported in the Seq?
And - as far as fantasyland goes, God Bless Austin, TX. I have the sales rep calling me daily to sell me a 4WD Loaded Seq for 41.5K. (In my choice of colour, too!). Itchy pocket is going to make me buy.....
Regarding the booming bass in the TLC, I have the dubious distinction of having started that thread after a close friend bought one of the first 2001's. While the stereo options may not be optimal in the Seq, it most definitely does not have the same problem as the TLC.
I will post some of my experiences in replacing the Sequoia stereo and some but not all of the components - as I am just finishing up this effort in my Seq (finally!).
Just last Friday I purchased my Sequoia from Debra McNulty at MacMinnville Toyota in MacMinnville, Oregon. I solicited online quotes from every dealer in the Portland metro area that allowed me to do so from their website, and Deb not only quoted me the lowest price at $1,000 over invoice, but did it with as little hassle as possible. No hoops to jump through, no requests to call back for a price quote, just a list of all the options and her price. She was also the only one to give me both the MSRP and the invoice price, and based the offer off the invoice (after she completed the dealer trade, she even faxed me the actual invoice for my approval!).
But it gets even better. When I finally got back to her the next day to move forward with the purchase, the truck she quoted me had been sold the night before by the dealer she was going to do the trade with. She continued doing locate searches at all the dealers in the area, and I had broken down my option selection into "must-have's" and "not-as-big-of-a-deal either way". We made an agreement (over email) that whatever truck she found that met my must-have criteria I could purchase at $1,000 over whatever the invoice was. Within 12 hours, she had found one that had just come in at Olympia, Washington. She arranged the dealer trade Wednesday afternoon, sent a driver to pick it up Thursday, and I drove it home Friday just in time for the long weekend, as happy as can be. A fully loaded 4x4 SR5 (basically everything but the premium audio and leather) for $36,667. Keep in mind if you're looking for a 2wd or a Limited, or by the mere fact that it's one week later, your price may vary. Things should go smoother if you just email and ask for a price quote on what you want, instead of demanding the price I got...don't worry, she'll give you her best offer.
In short, it was the absolute best car-buying experience I've ever had. Email Deb at dmcnulty@mactoyotavw.com and she'll find you the truck you want at her best price. She said she's been selling cars this way for 8 years, and it shows. I talked to her maybe twice on the phone, everything else was through email (very prompt responses!). I swear I will never deal with floor salespeople again, from now on it's fleet managers only, LOL!
No affiliation, just a very happy customer.
Gil.
There is ZERO room under second row seats and next to nothing under the first row.
Any thoughts
I hope that answers your question.
