Visitor Agreement.
And, yes, we do frown on publishing contact details for dealers. It looks too much like promotion and solicitation.
tidester
SUVs; Aftermarket & Accessories
BTW, the cost difference b/w the 265/70/16 and 275/70/16 that I found is only ca. $30. I am getting price quotes of $730 - $760 OTD for replacing all four tires. Are these prices reasonable ?
whotheman
We also took it to a frame shop that balances tire on the vehicle in hopes it would correct the problem but it still shakes. If anyone has/had a similar problem we would love to hear it. Positive outcome or not!!!
On the dedicated Tundra site, you will find the requisite alignment specs posted for your vehicle. You will need to ask your dealership check your alignment and see if it meets factory specs.
They all only cover defects. On the plus side, almost every component listed will not suffer from wear so if it breaks, it must be a defect. The big exception to this is the timing belt. That can wear out and need replaced. If it breaks before the recommended replacement time, it would be covered as a defect.
While "aftermarket" warranties may cover the same components (although none I have ever seen really does), you are still better off with the genuine Platinum Plan. If you ever need warranty service away from your local dealer, the service writer will roll his eyes when you produce a warranty form from an outside vendor.
If your dealer will not offer the Toyota plan, find one that will.
Has anyone else seen similar problems?
Steven Dunker
As for the VSC kicking in, it is possible that the sensitivity is too light. Others have posted here that they were able to get a new computer that was less sensitive to things like gravel at an intersection.
They however go to extreme lenghts to detail every minute of what happens at the toytoa service dept.
Oh well.
Steve
Mine is in the shop now having the brakes replaced under warranty for the third time. I have 24,000 miles in 22 months.
Love the truck but this is becoming a problem I hate dealing with.
Brakes are indeed not big enough for this vehicle. As long as its being replaced under warranty I live with it for aleast the reminder of my loan which is Nov 03. Then hopefully it will be corrected with the 04 model year which I will probably do then.
Overall though I'm very pleased with my Sequoia.
Steve
Since then, I tried to replicate this problem but never got the noise again.. Any clues as to what happened? Even though it is summer, I am using the 4x4 at least once a month as mentioned in the manual. I believe this is part of the break-in process. Anyone experience this before? Thanks.
As for the time it took to disengage, that too is normal. Tapping your brakes while moving will make disengagement faster.
Any advise?
After reading about other owners spending so much time hassling with dealers I decided this was a potentially more productive path to take.
Since then I've put another 2000 miles on my truck, so it's to early to tell if the warping problem is history. But so far, I really like the performance of this set up.
If you're interested, check out:
http://www.wheelersoffroad.com/tacobrakes.htm
These folks seemed knowledgeable and said they were fulfilling a demand initially from Tundra owners who had problems with rotors warping and that they now had quite a few Sequoia customers.
bk
Anyone have experience towing a travel trailer behind a Sequoia? What size and weight are you towing? I have a 19'- 3200lb trailer and I'm trying to get some first hand knowledge on your experiences. Thanks!
