There was little affect from some significant wind buffeting.
A word of caution: keep a significantly greater distance from the vehicle in front of you. It takes a lot of room to stop a loaded vehicle while towing a trailer - particularly downhill.
Guess the answer is ADN (any day now).
Steve
Any feedback?
http://www.edmunds.com/new/2003/toyota/sequoia/index.html
Also does the wind deflector/bug deflector need any major drilling or service to install? Of course they said to schedule an app. to have it put in.
Where can I get a wind/bug deflector cheaper? The dealer gave me a price of $175.00. I thought $80.00 was expensive for my past Explorer( which was traded for the Seq.)Thanks for any help.
-mike
He has seen many Tundra's and Sequoia's come through the shop with brake troubles. He said Toyota is finally addressing the issue and says he was told by Toyota that a fix should be available from engineering hopefully by November 2002. It would be retro for any previous Tundra/Sequoia's, which is encouraging. Whether or not it will be addressed as a recall or warranty repair was unclear.
He (technician) seems to think that the brake/rotor issue is due to what he referred to as a "bias" with the front/rear brakes. In another words, too much brake is applied to the front vs the rear. He also agreed that it appears that the brakes are too small for such a large vehicle.
Anyway if this information is indeed true it is somewhat encouraging but should not have taken over two years to address.
Will this update by on the 2003's arriving dealer lots soon....don't know yet!
Is it normal to feel the engine vibrate when stopped in the Sequoia? I am simply not familar with a V8 motor and my expectations for a quiet ride are high. It is nothing major but there definately is a slight vibration at idle. Any feedback would be appreciated.
is replacing the suction tube a big deal? my dealer offered me to replace the whole ac unit of my 02 sequoia, but it sounds a bit scary. i was thinking asking them to replace just the new suction tube to save me a peace of mind, my ac works fine so far but I'm just afraid it may break down on a long trip to some hot weather. (i checked with toyota my tube is the old type.) right now it's still under warranty, 11000, should I wait for another 10k to see if replacing suction tube is a big thing.
thanks in advance,
http://www.toyotawarranty.com/
In answer to the question about where it can be used, the genuine Toyota Platinum warranty is good at any dealership in America.
Also,your feelings on aftermarket leather (local dealer inst.)...
...am getting close to purchase. thanks
Most of my miles are city miles. Do I have a case to have this covered under warranty?
Also, my rear stabilizer bolt came off and I needed the rear stabilizer bar, bracket and bushing replaced all under warranty.
Any comments?
All of my driving, well about 90%, is in town and stop and go traffic. I have ~26K miles as of today.
Once again I'll say that I love my Sequoia but this brake issue has got to be fixed and fixed soon!
Why then would you also feel that you need to buy an extended warranty?
I got the typical response from Toyota that brakes are not covered under warranty. I would like to get in contact with your technician to speak to him about my situation. You are saying that after 21000 miles I should not have this problem. They are saying that it is normal. Maybe if I get something from Toyota that I can present it would help.
When you saw "typical response from Toyota" do you mean the dealer or Toyota itself? Two different entities.
Brakes should not have to be replaced on any vehicle in 21,000 miles unless the abuse on them warranted that. Do you do a lot of towing? If so this may be the cause of early wear too.
Keep me updated.
I don't do any towing or off-road driving. My response came from Toyota. The dealer stated the same thing. Below is my response.
Recently you contacted Toyota National Customer Assistance Center.
Below is a summary of your contact message and our response.
Response (Angelina) - 09/18/2002 07:24 PM
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We apologize for your brake concerns with your 2001 Sequoia.
Brakes are a maintenance item and typically not covered under warranty. Our
dealership technicians are professionally trained to identify warrantable
conditions and handle appropriately. For an explanation of your vehicle
diagnosis we recommend you consult with the Customer Relations Manager at
Darcars Toyota.
Your email has been documented at our National Headquarters under file
#200209181462. If we can be of further assistance, please feel free to <a href
contact us
National Customer Relations
Customer (James Barnett) - 09/18/2002 06:54 PM
I have a 2001 Sequoia with 21,000 miles. Recently my car started vibrating when
applying the brakes. The dealer told me I needed new brakes and my rotors
needed machine/turned.
My question is should this be under warranty. On the Sequoia owners board I
have seen many other owners with the same problem. Most of the time the work is
done under waranty. So why does my dealer charge for this when so many other
dealers are replacing the pads and rotors (or turning the rotors) under
warranty?
I was even told that Toyota is aware that the brakes have a bias to the front
and that the front brakes and rotors wear out much faster than normal. Who
would my dealer contact to ensure that this is warranty work?
Thank you for a quick answer.
Nope, this is an obvious ripoff by an unscrupulous dealer.
Also, post this one before but did not get an answer, what does SR5 stand for?
Appreciate for any feedback.
What am I supposed to tell the dealer?
2001 - 2002 model year Sequoia vehicles built before the VINs listed below.
Sequoia Front Amplifier - 5TD#####2S067029
Sequoia Rear Amplifier - 5TD#####2S077332
Repair Procedure
If the customer complains of a pop noise when cycling the ignition key, replace only the front amplifier for vehicles before the VIN break shown.
If the customer complains of insufficient sound from the rear speakers, then replace the rear amplifier for vehicles before the VIN break shown.
If the customer complains of excessive or booming bass, replace both the front and rear amplifier based on the VIN information. If the VIN is after the front amplifier amplifier implementation but before the rear amplifier implementation, only replace the rear amplifier.
Both amplifiers are ordered through the JBL exchange program by calling 1-800-456-4265.
I was in the market for SUV’s back in ’01 and I researched and comparison shopped for a long time between the Sequoia, ML320 and MDX. I ended up with the ML320 mainly because I was able to get it for below invoice and that my wife refuses to drive the Sequoia due to its size. Now as we are expecting our second child, I wish that I had bought the Sequoia instead.
In any event, don’t buy the MDX because:
1. Way over priced (I would not pay MSRP for any thing.)
2. Cheap interior quality (fake luxury, fake wood).
3. Engine is NO WHERE near as smooth and powerful as the sequoia.
4. Too much wind noise.
5. Ride is terrible as compared with Sequoia.
6. Almost non-functioning 3rd row seats
7. Smaller than the Sequoia.
Although some what pricey, Sequoia is the best full size SUV period. Anyone out there wanna trade one for my ’01 ML320??
I have shopped Toyota on my last 3 Vehicles - ended up not buying because -IMO they are over priced. I saved over $12K up front - factor in the higher resale value, lower operating cost and no need to buy an expensive extra warranty and I will save enough so the 6th truck will be FREE.
