cliffy1 -- I have no idea whether it's good to have 4WD on all the time or not. From your other posts, I expect that you have the technical background/knowledge to know and that you're right.
But, shouldn't the TRAC (or VSC) system work right in 2WD? It seems that the type of quality vehicle that Toyota has always made (and this is my sixth Toyota/Lexus product) shouldn't have a lag when pulling out into traffic, whether I'm in 2WD or 4WD.
Am I wrong in seeing this problem as a defect/problem that Toyota should correct on my Sequoia?
I think some others had posted here that there was a "fix" for this. I don't know that for sure. I do know that the vehicle is not only safe, but actually a safer to drive in 4WD at all times. It will prevent the situation you describe, plus it can help in panic cornering by providing power to the wheels that need it most.
Trust me, it's ok to drive in 4WD 24/7, rain, snow or dry. cliffy1 knows exactly what he is talking about. No doubt about that.
Have had my '02 Sequoia for 14 months now, 25k miles on it. AC compressor froze at 16,500 miles, 5 months ago. Dealership had my truck for 32 days waiting for parts. Meanwhile I worked with Toyota Corp. to get in a Sequoia loaner instead of the Trooper that had given me. Was able to get a 6yr/75k extended warranty for my trouble. Rotor vibration/warping at 19k, around 3 to 4 months ago. Dealer resurfaced without an issue, and haven't had any problems since. Now at 25k, AC compressor completely froze, AGAIN! Working with Toyota Corp. and dealer Customer Care rep., before bringing truck in to determine timing, loaner, etc.
This is not meant to complain about all Sequoia's or to say that I think that they all have these problems. I really do enjoy my truck and actually would have quite a few positives to point out if asked, but this is getting frustrating. Granted, this is just an AC unit and not the engine, tranny, etc. My concern is that is wasn't fixed (obviously) and won't be fixed correctly this time. Unfortunately I am having to seriously considering my options at this point.
For your front rotors, there is another TSB (BR005-02)which addresses this problem. Rumor has it that this will soon become a full blown recall, but it includes new calipers, rotors and miscellaneous parts. This TSB is applicable to VIN numbers higher than 5TD*T##A#2S136792. Since your rotors have already been grinded once, you would receive new rotors.
I know it's frustrating to have these problems with ancillary systems (thank god it's not the drivetrain!) but Toyota has indeed acknowledged these problems and produced fixes!
I finally received a call from the regional office today. "If it doesn't show up on the computer, how can you expect us to know what's wrong?" and "we've never had anyone raise any issue like this before". From these discussions and the ones on tundrasolutions.com, it's pretty obvious that some people are aware of this behavior/function/operation of the VSC or TRAC system.
Again, I appreciate everyone's input (since it does help to know that I'm not imagining things!) I'm just not sure that turning off the TRAC or turning on the 4WD is the answer. They certainly seem to be good ideas from knowledgeable people, but at the end of the day, the TRAC system "throttles down" when it shouldn't and Toyota says they shouldn't have to fix it. Very frustrating for a long-time Toyota/Lexus driver.
I sent my rig in for the repair before but was told that everything is within factory specification. But all the posts here indeed confirmed my observation. So I called my dealer and set up an appointment for today to check out the front brake and audio.
In the morning when I dropped my truck in, the service manager still insisted that audio sounds good to him. I showed some of the printout from this board and he said something like " Internet doesn't fix my car, toyota does.". SO the experience in the morning was not a very pleasant one. I just insisted to let the technician take a look of the audio system. He didn't mention anything for the front brake repairs.
I received the call that my vehicle was ready. I was completely astonished by my pleasnat experiences. First the service manager apologized to me that he didn't know there was indeed a TSB for Audio. So they ordered the amplifiers for me per TSB AU001-02. I will be notified once the parts arrive. The 355 toyota changed both the front brake pads and rotors. THey even vacuumed my floor and cleaned the car for me. I am fully satified customer now even though I was unhappy about the premature wear in the front pads.
THe following are the part numbers showed up on my receipt.
Pad kits, Disc BRA 04465-0C012
Disc. FR 43512-0C010
Maybe these are the updated toyota brake pad since I feel the brake is so much stronger , even stronger than the vechile was brandnew.
I did have a few more questions. Is there any TSB issue with air conditioner? SO far my air conditioner has been great. SO should I call my dealer to check this out to have some stuffs changed?
Kraus1...my suggestion would be to find the spot that reproduces the problem and get the service manager in the vehicle and show him what is going on.
Let me start off by saying I've always respected your contributions since I bought my 01 LTD in Nov '00.
I've only yesterday visited this Town Hall (after a long time away) and came to realize that others such as Kraus1 have this same problem as I.
I'm scheduled to meet with a third party arbitrator next week because I feel so strongly that this is a serious safety issue involving a very common driving maneuver--turning right into traffic!
If the system is acting as intended, why did they change it for '02? Even if one accepts it's acting as intended, that doesn't absolve it from performing "safely". I've used Toyota's traction control and VSC on my Lexus GS400 since Oct 97 and absolutley love this safety feature. It's the opposite of safe however on my wife's 01 LTD.
When I asked this question before, all I got back was, "why should I do that?" and "it just shouldn't be." Never has anybody directly answered the question which causes me to question to validity of the complaint in the first place.
I'm perfectly willing to use 4WD for the time being so there's no risk. I don't want my family hurt when the VSC\TRAC system decides that pulling out into traffic is the same as slipping on ice or gravel.
On the other hand, I guess I just don't agree with cliffy1 that the "system is doing exactly what it is intended to do, albeit a bit more often than one would like." It's hard to believe that Toyota intends for the system to kick in under normal driving conditions on dry roads -- their engineers have always produced very good cars and having a momentary loss of power when pulling into traffic or coming out of a turn cannot be an intended design feature.
When I said that I didn't think 4WD was the answer, I didn't mean that it wouldn't work. A work-around lets you get something done, but it doesn't fix the problem that requires the work-around. I very much appreciate cliffy1's suggestion about using 4WD -- it's far more than Toyota has been able to do so far.
Thanks for everyone's contribution on this topic.
First of all, to the thousands of Sequoia owners who haven't read your tome on 4wd nor subscribe to this Town Hall, who's responsibility (or culpability to use your term)is it they be made known of this condition? I checked my sun visor and sure enough, there wasn't a sign that said "Warning: To avoid possible rear end collision while turning right to merge into traffic in dry conditions, either place the vehicle in four wheel drive or wait until all traffic has disappeared”.
Secondly, the owners manual states “the active traction control system automatically helps control the spinning of 4 wheels (4WD mode) or rear wheels (2WD mode) which may occur when accelerating ON SLIPPERY ROAD SURFACES" (emphasis added). The crux of the issue is that I and others have described a problem that exists on NORMAL DRY ROAD SURFACES".
You wrote “When you are in 2WD (in the Sequoia and Runner), you still have traction control working for you....There is one thing to be careful of in this condition. When you are in 2-wheel drive, there is a second part of the TRACS that can be hazardous if you are not paying attention. This is the engine speed limiter... if you know you have any reduced traction, make sure you are in 4WD.” What kind of expectation should people have driving these vehicles? "Gee it's a sunny day, I better put it in 4WD"?.
Why sell a Sequoia at all that has a switchable 2 and 4 wheel drive? Why not sell just a 4 wheel drive Sequoia ala LandCruiser? Besides, the lower fuel mileage, I’m sure the wear and tear of leaving it in four wheel drive will be greater, which is why many of us who have had 4 wheel drive for many years want to focus its use on non-dry conditions. The promise of four wheel drive is that when the conditions look like they’re going to become nasty, one can motor on with flexibility that rear and front wheel drive vehicles can’t match. Turning right into traffic--a nasty condition?
I find it patently absurd that for the simplest of normal traffic maneuvers, it is recommended to place such a hurly burly and Lexus-priced vehicle into four wheel drive. I hope that other SUV brand owners aren’t reading this or they’d get a big hoot.
This reminds me of the joke about the guy who walks into the doctor’s office. Doctor asks what’s wrong. Patient says it hurts when I raise my arm above my head. Doctor says don’t raise your arm above your head. This is the same advice you're giving: Don't use 2wd. We'll see what the third party arbitrator says next week and I'll report to the the Town Hall the result.
Where you and I differ is in how we deal with the realities of this. I have offered a solution that works. I don't believe in tilting at windmills. It just causes frustration. If you are going to pursue this with an arbitration proceeding, you will only feed your anger. You'll walk away mad at Toyota, your dealership, the service department and the arbitrator. I've seen it before.
I wish you luck. Like I said, I don't disagree that the system is less than perfect. I just think there is a resolution that will keep your blood pressure down and will actually make the Sequoia perform better anyway. Your call.
I took it to the dealer and they said the problem could be the YAW and Deceleration sensor. They checked the YAW sensor. I already had the new version. They did a zero point calibration on the VSC, YAW Rate Sensor, and Deceleration Sensor. They removed excessive rust from the ABS Sensor. After all of that, everything was working fine. No more hesitation when pulling out into traffic. and it drives great. I was worried that they removed the sensor because it did not kick in at all during dry pavement then it rained the other day and I saw that it was working just fine.
This proves that the problem can be fixed.
--You mentioned you had the new version of the YAW and Deceleration sensor. When and why was it replaced?
--When was your most recent problem fixed?
--Any other comments by the dealer?
I had the service done on Friday 10/26. They test drove my car and obviously saw the VSC light come on. They knew exactly what my problem was when I explained it over the phone. They told me in some cases they replace the YAW and in other cases they re-calibrate. They told me they have done many of them. Call 301-902-2141 and ask for Shawn. The phone rings a long time so be patient.
I hope that helps. Good luck.
Perhaps you should check out the topic "Toyota 4WD Systems Explained". It might help you in explaining things to your customers.
I have a 2001 and asked the dealer about the new design for the tube...he said that they only replace that if the whole unit goes out. We use the AC occasionally so I'm sure that the thing will go out at 37k. I am thinking about getting an extended warranty just for the AC issue.
I am approaching 22k. The carpets get dirty and the rear storage door still pops out. I get the stink smell, I have to turn down the base, the kids change the FM presets, the outside gets dusty and the neighbor's dog pees on the tires. Other than that, I am still happy with this vehicle.
point where there is frost on the windshield. This is normally not a big problem as I live on the West Coast, but this
time of year it happens from time to time. Luckily I do not normally use it for commuting as I live close enough
to my job that I can walk to work. I have had it in the dealer's service department twice for the same problem and
they simply cannot diagnose the problem. The first time they replaced some part of the ignition system (which they
had previously took apart piece by piece and stuck in the freezer) and the last time they replaced the entire CPU.
My rear speakers also buzz when the engine is running and although they replaced the rear amplifier it did no
good. They are going to replace the entire stereo system this next time so I am keeping my fingers crossed that this
will be successful. The service department is very good and so I have been patient but I have now told them that
when I bring the vehicle in the next time, I do NOT want it back until they can guarantee that both irritating problems
are fixed. If they are not successful I fear I will be bidding my "giant green tree" a final farewell. This is the only new
Toyota that I have ever purchased that has had such problems, and this is my seventh. Anybody have any similar
problems that I can relate to the technicians?????
TSB # AU001-02
Title: JBL AMPLIFIER IMPROVEMENTS
Models:'01 - '02 Sequoia
February 8, 2002
Introduction
New JBL amplifiers have been designed for the 2001 and 2002 model year Sequoia to address the following concerns:
Intermittent pop noise from the audio system when cycling the ignition key. Excessive bass even with bass controls set to "-5." Insufficient amount of sound from rear speakers.
Applicable Vehicles
2001 - 2002 model year Sequoia vehicles built before the VINs listed below.
Sequoia Front Amplifier - 5TD#####2S067029
Sequoia Rear Amplifier - 5TD#####2S077332
Now, for your A/C TSB:
TSB # AC001-01
Applicable Vehicles: 2001 - 2002 model year Sequoia
Introduction: To improve the durability of the A/C compressor on 2001 - 2002 model year Sequoia vehicles with rear A/C, a new refrigerant suction tube is now available. If an A/C compressor is being replaced, the new suction tube should be added at that time.
