Visitor Agreement.
1). according to my owner's manual, it mentioned
that there is a AC power in the back of the center
console with a on/off switch in the front dash by
the rear window power switch. Well, there is a cover for the on/off switch and no sign of the AC outlet in my Sequoia. Is this an option? I don't seems to recall seeing it being listed.
2). My Sequoia has a somewhat annoying feature or
bug. After unlocking all doors with my keyless remote, when I open my driver side door wideopen first, it somehow automatically lock all my doors.
This is annoying especially when I accidently open
my door (driver) first before the rest of my family get into the truck. Is this a feature or a malfunction? Anyway, I might take it in and get it checked. Just put in 390 miles - nice truck.
I have seen some discussions with rotar problems and did not know if this was related.
If you're like me and leave your fog lights on all the time, just tap the power (+) wire on the high/low beam (near the either head light). This way you don't need to install the switch and autoshutoff will work.
Note: Use a 15-20 amp in-line or blade fuse between the fog lights and the low bean wire. This is for extra protection and in case you want to turn off the fog lights (pull the fuse).
If you find that the electricity draw is too much for the low beam wire (headlight fuse will break), you can always supplement power by adding a relay.
I saw msgs regarding the inside rear storage door and it constantly falling off, was a fix ever submitted to this forum.
My question is can you go through a car wash( NO TOUCH JUST HIGH PRESSURE WATER)without the deflector getting torn off by the water pressure. or do you think just waiting until spring for a good wash? Thanks
of not starting in cold weather. The main reason that it was there so long was that we had rain
and mild weather for about 21 of the 23 days so could not diagnose the problem until the weather turned colder. (ie below 7 degrees celcius). The problem was found after tearing the
dash apart which showed the wires connecting to the engine immobilizer were barely attached
which was why the vehicle would not start in the colder weather. A very small problem but
one that was not easily diagnosed. Let's see......I have all new ignition parts, a new wiring harness, a new stereo (both the receiver, CD player and front and back amplifiers) and who
knows what else? All because some "smoh" at the factory did not attach a couple of
wires properly. I am not sure that I will buy another Toyota manufactured on this continent, even though I still love the
product. If it sounds like I am just a bit dissatisfied I am, although I am in no way intimating that any other Domestic
product would be any better. My friend with the Denali XL has had his vehicle in the dealership twice to replace
differential seals and his is not yet a year old.
LX 470. I am still considering one but want some unbiased testimonials before I make such a substantial investment.
I am interested not only in performance data, but also sound levels and any effect on the smooth nature of this
engine. Please let me know if anyone has any real world information.
The only drawbacks that I've seen or heard about are that you need to use premium fuel if you're using the S/C. Secondly, it may be beneficial for you to go with an aftermarket set of fuel injectors as the stock may sometimes not keep up with the new fuel demands. This is more individual in basis, so if you get the S/C, see how it works without first and if you need them, you can always do so.
Hope this helps.
Regarding bug deflectors, had one on my 2001 and it came with my 2003. Took it off the '03. I can understand the need in the midwest (bug problems), but out here in Seattle, it seems a crime to cover up that beautiful front end with that hunk of plastic ! (like putting plastic on the sofa....for those of you old enough to remember.....)
normal cruising RPM (around 2000 to 2500) and if it affects the smooth characteristics of this
sophisticated V8 engine. I have a 2nd generation TRD supercharger on my 1996 4-Runner, and
although it is fairly quiet at normal RPMs, I sense that the production of all of the extra HP
and torque may not be quite as smooth as with a normally aspirated 3.4L V6. I know that this
may just be subjective, and that I may have forgotten the normal characteristics of this engine,
but I do know that for me; a change in the smooth nature of the 4.7L V8 would not be an acceptable trade-off for the increased power since I do not tow anything at the present time.
(other than my wife and 4 boys) If anyone could address these issues, I would greatly appreciate it.
Since I've had these Michelin tires on dry pavement, I've found them to be very quiet, rides pretty well and handling is exceptional. I strongly recommend them.
http://thecarconnection.com/index.asp?article=5549&sid=178&n=156
what is your feel of braking distance between your new Sequoia and the mini van that you were driving? The Sequoia is heavier, right?
The reason I am mentioning this is that I got to drive the new 03 4Runner. As a 01 Sequoia owner I was very interested in the new SUV. Let me say that I was very, very impressed. We drove both Limited and sport models and both handled and drove exceptionally well.
The thing that caught me eye the most was the quality of the materials used and the look of the dash. The little things they added i.e. the AC power outlet, lighted door map pocket, much improved JBL sound system, garbage bag holder and so on makes this SUV very nice. If it had three rows of seating I would definately be driving one today. O f course there are some things not on the new 4Runner that I have now but the improved interior quality is definately what won me over. The sport model had rear pillar mirrors that just about eliminated all the blind spots. However, this is not available on the Limited b/c of the new surround sound stereo. Also the cargo area includes a two level cargo deck that is very useful.
I hope and pray the 04 Sequoia upgrades that are planned will included many of the options included on the 03 4Runner.
If you havn't seen one go check it out anyway
