The time to worry is when it stops making the noise.
Ken
This includes removing the hood and the hinge that is rattling. I'd take it to a dealer and let them handle it due to the weight of the hood.
If you do decide to run it in 4WD, you won't notice much difference in MPG. I only lose about one mpg.
I still maintain that this was defective from the start either at the factory or dealership since the Sequoia is used mostly going to and from work, I have never hauled large loads in the rear, never stacked anything above the bottom of the window. The only exception was our Thanksgiving trip and by then at least one attempt had been made to fix the defroster.
I find it amazing that Toyota and or the dealership would leave me with a bad taste in my mouth and risk me bad mouthing Toyota or the dealership, not purchasing Toyota again, whatever on such a minor (on their part) repair.
I liked the new 4Runner too...;-)
I normally drive it in 4WD because a number of times, while driving my former '96 K1500 PU, I lost traction on gravel or wet pavement while pulling into traffic. Everytime, I thought to myself that it would be great if I could stay in 4WD all the time to avoid that without the binding that comes with Part-Time systems.
I will say that for a truck based SUV, this thing drives like a dream. But I believe that most Sequoia owners would agree. When I test drove a new 4Runner I was equally impressed with it's handling.
Any suggestions Cliffy?
Most likely you have one of two problems
1. Brake pads are worn and need to be replaced. This is normal, your fluid level drops as your pads wear, when new pads are installed the fluid level will move back up to full.
2. You have a leak somewhere in your brake system.
Adding brake fluid does nothing to solve either of these problems.
Question: Should the brake lights have come on or not ? And if not, is this peculiar to mine or is it *normal* ? In any case, maybe I need to get my dealer to take a look at mine just in case there is some blown fuse or something in the ECU which prevented the brake light from coming on ? Anyone else have any thoughts on this ???
Our link: The Edmunds Maintenance Guide
Take a look in your owners manual under brake fluid - it most likely says - "Do not top off brake fluid"
Anyone with a Sequoia owners manual handy?
This deals with a low "thunk" noise--The dealer did one fix but it is back 9 months later.
When driving at a constant moderate speed with very little or no pressure on the
gas pedal--floating--and slight pressure is added/increased on the pedal, there
is a thunk that sounds like it comes from a drive shaft. I described this to the
dealer last March and the service department looked at it and found that there
were burrs or rough spots on (and now comes the part where I get fuzzy) a drive
line or other line that is connected to or a pert of the transmission. Apparently
there was slippage where the line was connected to a sleeve. The service
department removed the excess metal and the noise was gone.
I rarely drive the car, but I did today and I noticed that the thunk is back. It
appears that the service department repaired the symptom rather than the
cause of the problem.
Does anyone have any ideas?
Conrad007
2005 models (out by fall of 2004) will have 5.4 L engine. Same year Lexus will introduce LX540, as well, replacing their LX470. The LX540 will contain the same powertrain and same engine 5.4 L as that of the 2005 sequoias.
No clue on other add-ons, though.
I got this info from a lexus lead sales person.
Northwesterner - Good point - if you have a high mileage car adding a little fluid may be a good solution. I would not expect a 2001 / 2002 vehicle with 20K miles or less to be so low on fliud that the dummy light comes on. Do you accept that as normal?
I know the Sequoia has had more than its share of brake problems - maybe warped rotors and adding fluid are normal.
Please advice
This either a really important question or, due to my ignorance, a really stupid one. I was under my Sequoia this morning replacing the spare and noticed what appears to be "rust". I can see it clearly around the rear axle where the wheel attaches and around the inside of the axle while looking through the hollow sections. I assume that this is rust because it looks like rust - same color and texture. I have never driven off road so I am sure that I have never scratched the undercarriage down to the bare metal - although this would not account for the interior of the axle cross bar showing the same rust color. I do a lot of mountain driving so, during the winter, I run into a lot of snow and therefore salt from the road crews. However, I have been very careful to wash the undercarriage thoroughly after each mountain trip. Honestly, I am not sure if this is rust or not but if it is, I hope that I might get some advice from you guys. Thanks in advance for any advice that you guys might have.
Bottom line is, it isn't a big deal. You'll drive yourself nuts if you let it bother you.
But even better was when I took them back today. We took the Interstates the whole way. Since the roads were snow covered to semi clear to clear, it was great to be able to run in 4WD the whole way without any of the worries that a Part-Time system would have brought on. I had power to all four wheels at all times, which is very beneficial in those types of conditions. Trucks with Auto 4WD Part Time systems can't compare since they only get power to the front wheels after rear wheel slippage has occured.
This experience shows me that the combination of Active TRAC and Toyota reliability is the best thing on the market.
