While on the highway to south Jersey, the highways were very slick with a lot of ice and snow in between the lanes. I noticed when I crossed lanes the system would kick in and sometimes the wheel would not turn, at one point we thought we were going to hit a guard rail, but the system gave us perfect control over the vehicle putting us right back in the lane. Remarkable! This is a phenomenal system. The ABS works great even on the ice and hard packed snow, it keeps the vehicle straight. Only concern is that the other vehicles around me do not enjoy such a remarkable package.
if you can find a huge open empty parking lot that is snow or ice covered, you can have a little fun and test out your system.
Here is what happened in my case:
At 25K miles, the brake pads and rotor needed to be replaced. Cost $550 + tax. At the 30K miles service, the brakes were wearing *normally*. At 35K miles, I noticed front vibration upon braking. Took it in and had it checked. Yes, the rotors were warped again. I insisted that the brake upgrade be performed. The dealer tried to wiggle out, but after reminding them of the cost I paid 10K miles earlier to put brand new pads and rotors, and showing them a copy of the TSB and a mention that the online superhighway has LOTS of info on this from other owners, they relented and agreed to fix it under the TSB. It took a day of work to get all the parts replaced, and there is a lot of things to replace under this TSB. That is why you should have yours done too. I strongly recommend it.
The difference is incredible !!! The new brake calipers are far bigger than the old ones. The car feels more solid under braking condition, and even Toyota service tech told me, the problems with warped rotors will disappear with the new brake system.
Get yours in today without delay, regardless if yours ain't warped yet...
Here is a clip from raddboy's post #6738 on the brake TSB:
"...This TSB is applicable to VIN numbers higher than 5TD*T##A#2S136792...." So if your car does not fall within the above VIN #, it may have the upgraded brake system, as some late model '02 and ALL '03's had the upgraded front calipers and rotors.
Hope his helps
Also, I have only 5500 miles on my vehicle and only noticed that the breaks makes a thumping noise and the break pedal gives a little when applied while putting it into gear. The dealer said the breaks are just setting and is normal. Please inform me if others have similar problems.
If requested by the owner, does the Toyota dealer have to repair all TSBs (like all recalls) or is it up to dealer's discretion?
Thanks in advance
But a tsb is intended (mostly) to help the mechanics expediently deal with problems that have arisen (or for such mundane things as correcting typos in the service manuals). There's no rule that I know of that forces the dealer to perform a tsb.
More here: You, Your Vehicle and the Technical Service Bulletin (TSB)
Catman
Speaking of "staying at the Holiday Inn Express", I already paid out-of-pocket for new brake shoes and new rotors at 25K miles. Think I have a case against Toyota ?
BTW, to reach Toyota Customer Care, here is the number: 1-800-331-4331 (option 3), you will need the patience of a mule !
I fixed mine by putting some self stick rubber in the "V" of the male side of the clip to hold the "V" wider. I think either will work and it is a $5 / 5 minute fix.
Personally, I'm not a big fan of DRLs.
On another note, we've been getting clobbered with snow here in the northeast and this Sequoia is the best! Say what you will about the sensitive, loud VSC....it really works! I don't care if it plays the Star Spangled Banner if it keeps me safely on the road instead of in a ditch.
TSB EG019-02
Applies to the Sequoia with VIN # lower than 5TDZT34A42S110570
Basically, the oxygen sensors have been failing prematurely sending failure codes P0135 or P0155.
Previous Oxygen Sensor Bank 2 part # 89465-34080 has been replaced by # 89465-34140 and Oxygen Sensor Bank 1 part # 89465-43110 has been replaced with part # 89465-34150.
Replacement of these parts is covered within the 36/36,000 mile warranty.
It says that application of this warranty is limited to correction of a problem based upon a customer's specific complaint. Whatever that means. I'd imagine that you at least have to have the check engine light on with the above failure code, retrieved by their diagnostic equipment.
I think that only works with Internet Explorer 6.0. Other browsers have different ways of magnifying the image.
I attempted to find your e-mail address in your profile (per your msg #6949) so I could e-mail you requesting a copy of the TSB for the brakes, but I could not find your e-mail address. Am I missing it? If it's not in your profile, can you put it there?
I would swear my last Toyota owners manual said "do not top off brake fluid" - Maybe it was the Nissan.
OAS3 - Did Toyota refund the $550 you paid for a complete brake job? Seems to me they owe you $550.
Can you give me the name of product/store and instructions.
Do you Sequoia owners have an problems with this?
thanks in advance
I used thin rubber self-stick weather stripping that I had around the house. You can get this at Lowe's or Home Depot. You might have to buy several feet of it though. Cut a small piece and stick it in the "V" of the male clip on the door piece. The problem here is that it will be visible.
To copy the Toyota solution, get self stick felt. This can be found at hobby stores like Hobby Lobby or Michael's. Cut a strip of it and then wrap it around one side of the hole that the "V" connector goes into. This will increase the friction enough to hold the door. It is also hidden. Make sure when you wrap the tape it conforms to the shape of the plastic.
Good Luck!
Who has the high mileage out there?
My questions are: 1) Does there have to be a problem with the brakes before I get there or do I just ask to have the TSB honored?
2) Should I have a mechanic from my local garage look at the brakes?
3)IF they don't put on the new brakes under the TSB when I have to get brakes probably within the next 3,000 miles will they be free OR ar they going to put the TSB brakes on and charge me. WHAT SHOULD BE MY NEXT MOVE. ANY HELP WOULD BE WONDERFUL. THANKS
Q: 1) Does there have to be a problem with the brakes before I get there or do I just ask to have the TSB honored?
A: Generally, a YES. But if you can sweet-talk them, and express your disapproval if they won't fix a KNOWN problem, then maybe you need to go elsewhere. Hopefully, they'll be nice about it and fix it for you under the TSB.
Q: Should I have a mechanic from my local garage look at the brakes?
A: I wouldn't advice you to do this. In such a situation, you want Toyota service people doing all the checks.
Q: IF they don't put on the new brakes under the TSB when I have to get brakes probably within the next 3,000 miles will they be free OR ar they going to put the TSB brakes on and charge me...
A: As you have read of others on this forum, there is NO CHARGE to have your brakes replaced under the TSB. Like I said earlier, take it in and have this service done as long as your car qualifies (right VIN, before 3/36 warranty expires).
When I mentioned this to the service mgr along with the TSB number there were no further questions asked.
By the way, Life is too short to be dealing with a bad attitude dealership, Toyota or not. Find another one.
March '02 replaced front tires under warranty due to Mfg defect, but rear tires are wearing improperly. ** Tear in leather seat on driver's right side - lower section by seat controls - tear from metal frame due to no padding around metal frame & metal wore through from getting in/out of vehicle. Dealer added padding @ frame on both front seats, repaired tear & said to get it back in before 36,000 miles if it begins to tear. Dealer is again in contact w/Toyata re: "NPF" issues. Replaced '92 Camry w/Sequoia. Waited 1 year for vehicle to come out, waited another year to purchase. Love the vehicle but hate the ticking, VSC sensitivity and plastic (?) interior is sensitive to scratches and gas mileage @ 12 mpg. '92 Camry interior still great and looking new after 10 years of use. Paid alot of money for our first "Loaded, Top of The Line" purchase. We will be checking out the new Lexus SUV & the '03 Sequoia - that ticking noise will make us crazy & I think could become a negative resale issue.
