I called Toyota Customer Relations. No help there either. I told them if it is the tires, I want a different set of tires (not a warranty replacement) but a different brand. Bottom line the humm "might" be tires, but the vibration is not.
I await the call from Customer Relations on this, and see what they have to say. I will also call my sales rep and GM about this. My wife is up for a new car, you can bet this is a topic of discussion.
LOL! Nice play on words.
But I've mentioned other sites on these boards before without getting my wrists slapped. If this was a policy before, maybe they've wised-up and realized that there's a lot of knowledge to be shared among the different forums. Many owners frequent several boards, you, me, pschreck, to name a few, and I believe there's at least a few other suspects I've seen here.
Getting to the third row of seats to strap someone in is not real easy, but much easier than of an expedition or suburban. You would have to be on your hands an knees.
This is very easy get a feel for, by making a short trip to the dealer and "go through the motions". good luck
With two infants and a toddler I would put the two infants next to each other behind the driver. The third second row seat behind the passenger will tumble forward very easily, then you can help your toddler hop into the back, get into his seat, you do have to crawl in a bit to buckle him, but you would in any vehicle.
The double seat behind the driver tumbles foreword also, then there is a lot of room to get to the third seat. If you would need to.
Last week I had a toddler in the middle of the third row and an infant carrier on either side of him. The seats fit very well. They did not fit that well in my 98 Sienna.
You also have to remember that your kids are only going to get bigger, and it will get easier to get them in the vehicle, very soon.
I like having the 8th seat, it really comes in handy when car pooling to pre-school. When another mom at pre-school saw my truck she said that she wants to get rid of her van and get a Sequoia, she is trying to talk her husband into it. Petro33 is right go to the dealer and try it...you will get a good feel for how easy it is to do.
My husband wanted me to wait for the new Sienna, I'm glad I decided to get the Sequoia.
Thanks in advance
Bob
75-80 mph both ways
going up, locked out of o/d multiple times
min rpm- 2500 (cruise)
max rpm- 4100 (long climb)
going down, locked out of o/d once
min rpm- 2200 (descent)
max rpm- 4000 (brief climb)
going up- 22 mpg
going down- 32 mpg
400lb of passengers
150lb of cargo (trunk)
Altima 2.5S
engine has 7500 miles on it
check out coming back
hows your mileage?
For the 2+ years I have hung around this forum, I have never heard of a similar problem to yours. So this definitely has to do with the Canadian-US conversion. Typically, buying a Canadian version and having the gauges changed is a risky choice to take. Your best case scenario is that this will be covered under warranty.
Let's hope any Toyota sales person here can have an advice for you on how to solve this problem.
I noticed you posted the same message on a lot of full-size SUV boards. Why can't you people get it through your heads that we all have different needs and no one vehicle suits every situation?
Toyota does NOT like these gray market deals. They try to prevent it whenever they can. This leaves the consumer is a tight spot and you will be more reliant on the good graces of the selling dealer to handle stuff like this.
Now, 714cut, your question is interesting - yes it is a silver sky. Is there some coincidence you're thinking of? The dealer had 2 identically configured Sequoias on the lot from Canada - the other was black. The reason I bought the one I did was because it had the DVD entertainment system in it, which I haven't found in the states. Of course, the dealer said they could only get them from Canada with that config.
I hadn't heard of any issues with getting the trucks from Canada before now, but of course now that I've already bought it I'm hearing people on this board saying it's risky. Other than the odometer reading uncertainty and the 3rd party involvement with the gauge replacement, is there anything else I should watch out for?
1. You might have a legal issue if you sign an odometer statement without disclosing the switch.
2. Toyota will NOT allow you to buy one of its extended warranties.
3. Toyota will not finance it.
4. If your dealer didn't enter it into its databank correctly, it will not show up as a valid VIN if you take it to another dealer for service.
5. There may be some parts that are slightly different between the US and Canadian spec trucks.
6. Problems with the dash, odometer, speedometer and gauges may not be covered under the warranty because the problems can be blamed on faulty workmanship at the facility that did the conversion.
That last one can be avoided if you bring it only to the selling dealership. They'll slide it through Toyota where another dealership might not.
Suffice to say, I just bought a Matrix yesterday. Since I also own a Seq. it affords me an opportunity to compare the real 'utility' of a CUV (Matrix) versus an SUV (Sequoia).
Matrix: Tall on the inside, short on the outside
Seq. Tall everywhere - in-and-out
Matrix: versatile seating or cargo arrangement. All seats (except drivers side) fold flat with headrests on. Neat. The cabin volume is close to 51cuft with all foldable seats flat. Not just that, the trunk is real cavenious for many things. Dogs and kernels, fishing stuff, skiing stuff, luggages, etc... It has two tracks you can run your luggages on to make ease of entry and loading. Just so many funky things you can do with this car. Besides, it is quite a head-turner, with its low riding frame, sport wheels, underside body moldings, bumper protector, etc. The best trim level is the XR. If you want, you can get it in AWD, although engine output suffers a little bit (123hp for AWD_versus_130hp for non-AWD).
Most importantly, it is a blast to drive. It is so much fun. A trial will convince you. Do I sound like a sales guy ? Maybe. But I am not. I am just an excited new owner, and I love the car so much more than my Seq. and my Lexus (if you can believe that !) but it is true. I'd rather drive the Matrix than my '99 LS 400. I did not know a car can be so much fun to drive. Maybe it is because I am very conservative in my car purchases. But a Matrix is in a different time zone compared to many other run-of-the mill cars/trucks/crossovers out there.
If you ever buy one, Paul, make sure you send me a commission check.
It is clear Toyota has done something different with the engine. Both of my Sequoias were "tickers" and it was a real negative for me. No matter how cold the 4runner is silent.
The 5-speed auto tranny is really nice. The ergonomics are excellent. The JBL 10 speaker 360 watt stereo with subwoofer is vastly superior to the Sequoia. The locking differential and downhill assist control as well as hill assist control are all excellent useful features, and hey no more plastic steering wheels! The hydrophyllic glass is very cool as well. It acts like permanent Rain X on side and back windows. The electronic latch on tailgate is an awesome feature as well. It closed the latch by itself-no more slamming or reopening if not fully closed. The 4runner is surprisingly quiet although I would still give the nod to the Sequoia. I like the 17 wheels- they look sharp.The X-Reas suspension is awesome. I'll be surprised if some if not all of these features will be on the next gen Sequoia.
Negatives-size and space. Wimpy tow hitch (although it has a 500lb. greater towing capacity than the Sequoia. The instrument cluster is too dark, even on a sunny day. It doesn't get the looks or attention that the Sequoia got and the body cladding is kind of subjectively ugly.
It's definitely worth checking out the 4runner if size or 3rd row seating isn't your primary consideration.
My sense is I'll be back to a Sequoia next generation!!
steve_ "Honda CR-V" Feb 16, 2003 12:22am
The dealer says that they bought the vehicle directly from the dealer in Canada, and that they do the conversion themselves, so the dash light issue should be no problem (so far this is just the sales guy talking, though, so we'll see). I've also submitted a search on LienQuest.com to make sure it wasn't stolen or something. CarFax recognizes the VIN as a 2003 Sequoia Limited but has no records on it. I also plan to call Toyota Canada to verify the VIN and find out as much info as I can, including (hopefully) what dealer the car was delivered to in Canada. From there I'll call the dealer and try to verify mileage, who the car was sold to, etc. Anything else I can do to help put my mind at ease?
I wouldn't sweat the horror story links too much either. It's not like you imported a Yugo after all, and hopefully yours wasn't wrecked or anything. Maybe one day NAFTA will open this market up for cross-border shopping.
Regarding my new Sequoia specifically, everything seems to be checking out okay. It's in the US warranty system, the Canadian LienQuest.com search produced no liens or title issues, CarFax has nothing on it, my dealer is sending me a copy of the NHTSA documents showing the import, and the vehicle is only a couple months old. And if the dealer did, in fact, do the odometer swap there, they should have no reason not to fix the dash lights. I'm planning on having that done when I take it in for the first oil change at 1000-2000 miles.
Thanks to everyone for their help on this issue. It's been a bit stressful, and I am still a bit concerned, but at least it's not looking like it was a shady deal (at least not any more shady than the typical car deal). I'm not quite as happy with the price I got, though! The whole Canada thing seemed so insignificant at the time...
