http://www.nhtsa.dot.gov/NCAP/Cars/2003SUVs.html
I now own an '02 HL and am thinking about trading to an '05 SEQ. I really like the ride of the HL, and am wondering if anyone else has made a similar switch and could share their experience - ride, driving, etc.
Unfortunately, a number of posts got lost during our software upgrade and we regret the inconvenience.
Price: Sequoia will average about 13k more
Warranty: Same
Engine: highlander 3.3 v6 vs sequoia 4.7 v8
Drivetrain: highlander AWD,traction control, vsc vs sequoia 4wd high and low, transfer case, locking center diff, vsc, traction control, and 2wd mode.
Power liftgate window: sequoia only
Suspension: highlander front and rear independent vs sequoia front independant and rear solid axle.
Structure: highlander unitized body vs sequoia full boxed ladder frame
Seating: 7 highlander vs 8 sequoia
Power steering: sequoia has speed-proportional steering
Rear brakes: highlander disc vs sequoia ventilated disc
Turning radius: highlander 5 ft tighter
Cargo capacity: highlander 81 cu. ft vs sequoia 128 cu. ft
Towing: highlander 3500 lbs vs sequoia 6200 lbs
Gas: highlander 18/24 vs sequoia 14/17
Fuel tank: highlander 19.1 gal vs sequoia 26.1 gal
Length: sequoia 20 inches longer
width: sequoia 6 inches wider
height: sequoia 8 inches taller
weight: sequoia 1300 lbs heavier
ground clearance: sequoia 3.3 inches higher
As for driving, I was very surprised with how easy the sequoia is to drive considering the thing is huge, in fact it was the easiest to drive out of all the comparable SUV's I test drove by quite a large margin.
The highlander is very similar to the Sienna minivan, same engine, same towing, similar room and dimensions, same suspension design, unitized bodies(full frame for sequoia), and similar drivetrains. Even though the sequoia rides quite nice, it's still a truck and you'll get a nicer ride from the highlander.
Hope this helps, I've tried to be as unbiased as possible being a sequoia owner.
I can recall spending nearly $400 for a Yakima bike rook rack system for my Avalon but do not want to head down that road again. Yakima's system is too inflexible.
I noticed that this car sits really high and I don't have much visibility while parallel parking.
My wife and I are used to the reverse sense park assist system that we had on our previous SUV. I got an after market quote to install this which included a visual LED system installed inside the car (at the back end of the roof) for $500. Has anybody installed an after market reverse sense system?
Wonder why Toyota doesn't offer a reverse sense system?
Unless you were in deep snow, you were not feeling 4WD. That would do nothing unless you had wheel slippage.
my Sequoia. It is not pure wind noise and it does
not seem to be really speed related. At first I
thought that a loose moonroof wind deflector was
the problem so I removed it. The sound still persisted. I think that I have narrowed it down to the roof rack but I am not sure. I know it is
not a leek around either the moonroof, windshield or windows because I can hear it louder when the
moonroof is open.
Any thoughts before I take it into the dealership
to have them look into it???
Seriously, I'm very close to ordering an '05 SEQ and trade the HL, so I appreciate all the information from SEQ owners like you.
The are some rare exceptions to the above but in general this definition holds.
4WD vehicles often come with a low gear range but that is in no way a requirement for much of the driving public.
There are a myriad of ways of implementing AWD out there in the marketplace, some of them not very functional, and some extremely so. It will be up to the buyer to do some serious research in a specific implementation to determine acceptability for a given driving style/location/climate.
1. It appears from using wedsites (e.g., Toyota.com, Cars.com, Edmunds.com) that a SR5 can be optioned out such that it is the same as the Limited, but at a lower cost. I find this hard it to believe that it would be the same, but cost less. What am I missing?
2. My Toyota dealer confirmed that the 2006 model will be a redesign, thereby making me a little cautious to spend $40,000 plus on a 2005 model. Waiting for the 2006 would make sense since I own a Pathfinder today. Is it generally recommended to stay away from the first year redesigns, therby meaning one should wait for the 2007 model.
I appreciate any thoughts.
I can't wait to try one out, but I realize that there is going to be an initial rush with the bucket seats option. Perfect for my family!
That said - I'm really having a hard time getting used to the new exterior design. The hood is a bit more raked back, and the grill opening is smaller. I told the sales guy that it looked more like a station wagon front end vs. the 2004 which truly looks like a truck. The tailights are also different - there is now a big round bulb instead of the three hash marks. The sales guy said they are going for a "more sporty" look - which I guess I can see.
But the 2004 really looks more tradtional vs. the trendiness of the 2005. I've pre-ordered a blk 2005 but I'm thinking of canceling. Any one else feel this way?
If the it was under the Lexus nameplate, Toyota would turn themselves inside out to remedy our problems... The GX470 share the same Drive Shaft technology and when LEXUS Owners complain with the same problems Lexus acknowledges it and offers a solution... They have a Technical Service Bulliten to correct that exact problem... Our TOYOTA SEQUOIAS cost in the $40,000-$50,000 range. We need to get the same treatment as the Lexus GX470 drivers.
We as a group can make a difference...Everybody who brings their truck in to Toyoyta for this problem can not be dismissed by the dealer telling us it is normal when LEXUS recognizes this as a PROBLEM with a REMEDY.
WE NEED TO START A CLASS ACTION SUIT TO MAKE TOYOTA FIX IT.
Register a complaint into the government website www.nhtsa.dot.gov or call them tollfree 888 327 4236
TOYOTA has to acknowledge each one of these complaints.
MAKE TOYOTA ACCOUNTABLE.
I invite replies to further this QUEST
Instead of making a major deal out of it why don't you try a different dealer or an independent shop.
I took my truck to 2 different Toyota dealers. Dealers say it's "normal".
I went lemon law in July 2004 and lost even after reproducing the problem many times to the L.L arbitrator.
btw, we don't have time to verify phone numbers here so please don't post them (see the Member Agreement for details). Thanks,
It's a PROBLEM . Two separate Toyota dealer looked at it (18 times).
Sequioa owners are paying Lexus prices and must unite to get the same level treatment.
GO TO THE www.nhtsa.dot.gov WEBSITE and file a complaint. Make TOYOTA ACCOUNTABLE
Report back as to whether his suggestion worked or not. We'd like to know.
They tried all the "forum " fixes and within weeks and only a few hundred miles the problem reoccurs. I have made numerous phone calls to Toyota corperate Printed out fixes from "forum" sites & even gave copies of the LEXUS TSB for MY SAME EXACT PROBLEM for both dealers to say their hands are tied .Toyota must empower the service Depts. to FIX this problem not mask it.. I DONT EXPECT TOO PAY any outside non TOYOTA SERVICE dealer a penny too fix what is a warranty issue
The dealer says Toyota will not pay them to fix the truck... I paid almost $50,000 for my sequoia LTD which I OWN not lease . I want it to be RIGHT...If I spent $50,000 on a LEXUS GX 470 I would be treated like an appreciated client with a valid problem that requires a remedy....NOT it's NORMAL deal with it attitude!!
If all sequoia owners would file a complaint it will send a message to Toyota .IT's A TOYOTA PROBLEM TOO.If people don't stand together and respond like you ,TOYOTA WILL GET OVER on the CLIENTS time and time again
sjk2, thanks for the compliment, but no I don't work for Toyota. I'm just a happy customer.
Life is too short to waste so much time obsessing over a vehicle. 18 trips to the dealer? I bet they hate to see you coming. I have made exactly 1 trip to the dealer in 3 years so they could show me how to program the door locks.
Every problem has a solution, some just take longer to figure out than others. The dealer is obviously stumped, and you have probably worn out your welcome there... you did sue them didn't you? They don't like that. And using caps (yelling) won't help your cause on this board either.
The dealer really agreed to try all the "forum" solutions? I get a lot of eye rolling whenever and wherever I mention that I heard it on the internet. Did they replace the driveshaft? You don't give us much information (history) but want us to jump on your one man "bandwagon" to pressure Toyota about your problem. Hmmm, not too likely, as your problem has not surfaced as a major issue with the owners who post on this board.
If you are still reading... and are still willing to work on the problem, I do have another idea that you could try without involving the dealer. Does your Sequoia spend most of it's time unloaded with one person aboard? If so, try this: load enough stuff in the back to drop the truck a couple of inches (300 or 400 pounds should do it) and then drive around for a few hundred miles. This will cause the driveshaft slip joint to wear in a different area and may loosen up. The Sequoia is sprung pretty stiffly so that joint moves very little (and so doesn't distribute lubrication very well and binds up) in an unloaded vehicle.
Well that's my two cents hope it helps.
THD
I want the sun/moon roof but am not happy about the look of the wind deflector. Will I have noise/wind problem if i order the Seq without a wind deflector for the sun roof?
Thanks for any input
This board ROCKS
I pop in once in a while. It's gotten awful quite around here lately. Now that cliffy isn't around and with the demise of heatwave it's not as lively as it used to be.
Take care.
714cut and others. It is nice to know that there are others who have been reading this form for as long as me. I got real good advice from the forum when purchasing my '01 seq.
Biggest problems before were, no heated seat with SR5 leather upgrade! We have come a long way. I guess things will get pretty lively when the new seq comes out (body and engine)....
