They are saying now that it is the OTHER catalytic converter, and have to order the part.
Does the Miata have a front and back cat? Is this a silly question? Do all cars have a front and back cat?
Have you considered a tune-up?
but that said, I'm not positive what years of Miata have two cats.
~Colin
Oh and WRX's also have two CATS so I don't think it is all that uncommon.
Tee hee.
But hey, if it helps makes the air a few percentage points cleaner, I'm all for it.
So I got the Miata back and it seems to be running more smoothly than before. Maybe its psychological. Can't wait to take it to the canyons!
Has your top leaked through the glass window? I've got the side windows sealed up OK but the rear window seems to be leaking were the seams have come loose. If I remember right, yours was doing this too (coming loose). Does yours leak too? Have you had any luck fixing it? I was thinking about using some weather-proof silicone goop to try to plug up the seams...not sure how effective that would be...
When it rains pretty steady for a few hours, I get standing water in my "shelf" behind the seats underneath where the window is. The inside of the top gets damp and the moisture clearly spreads from the window out.
Next time, I'll get a Robbins top...
-juice
"Next time, I'll get a Robbins top..."
What type of top are you currently using? Are you not happy with it?
On my old Miata I replaced the top with a Robbins vinyl top w/ plastic window (for economic reasons) and was very happy with it. Didn't have any problems with rain afterwards, and that was in Savannah. GA, so there was plenty of it around.
http://aabestco.com/merchant.ihtml?pid=1300&lastcatid=963&- ;step=4
And no...I'm not too happy with it. I'd have to say that this is a good example of getting what you pay for.
I no longer own the Miata as I have since sold it and then bought a 90 RX7 convertible to take its place (thankfully the top was replaced before I bought it and is of very high quality!). Good luck and let me know if the silicone stops the leak.
You can add the spring tower braces front and rear and expect incremental improvements. I have the front spring tower brace and a home-made brace on the under side of my '93.
-juice
I'm just having some trouble with it and I was wondering if you had the same trouble, and if so, what you ahd done that helped or hurt. That's all. I'll try the silicone solution and see how it goes.
-juice
I wonder if you could get them reupholstered for cheap. Leather runs $900 for 5 seaters, so a 2 seater should run maybe $400-500. For cloth it should cost even less.
Look in your phone book under Auto - Upholstery. Call them and ask.
-juice
Can someone email me a couple of Miata only websites/forums? I've googled for some and can't find any.
tobympls@mn.rr.com
My Dad ued to own an upholstery shop with my grandparents before it burned down when I was in high school so if I go all out and reupholster the seats, I'll probably do it myself (ourselves:).
What I'd really like to do is the put some 01+ seats in there...those are comfy. The NA seats are a bit small...if they were maybe 10-15% bigger they would be much better.
A place in Bridgeport, CT, had a wrecked Miata and I got all kinds of knick-knakcs off of it. I mean little latches and stuff that had broken on mine for the hood prop rod, the center console latch, stuff like that.
You might get lucky, who knows?
-juice
Aftermarket vendors sell nice struts if you're into that sort of thing.
-juice
PF Flyer
The MAZDA chat is on TONIGHT. Stop in for a holiday visit! Check out the schedule
~Colin
I am a refugee from the Subaru Boards,
I have my eye on a '99 with 19k miles from a Chrysler dealer. It is just off eBay and the pictures and info. looked really good. The dealers is about 100 miles from me and I will inspect before making an offer. I am hoping that the dealer will be in a position to deal... we are in Massachuettts, just got 18" of new snow, it is the end of the year and how many convertibles are sold in New England in the winter ...
This will not be a daily driver, will use my Forester and Saab for that, if I kept my Outback I could be just like Juice ... 2 Subarus and a Miata, not as car smart or handsome of course.
Jerry
I agree with your general notion that the car will sell for more in the Spring than it will right now.
btw if it is 10th anniversary edition that changes things a bit, but not a whole lot.
~Colin
~c
0 or 1, depending upon whether you buy it or not.
-juice
1. How do I tell if the car I bought has the sport suspension? "Yellow Bilstein Struts" Thx locke2c
2. Can I somehow get the original window sticker from Mazda?
3. How can I get the key code number?
4. Should I use synthetic oil?
5. I will be storing car for 3 months, should I fill tank and add Sta-Bil?
6. Regular or Premium fuel?
Any help will be appreciated, Thx Jeff
3. key code... um, dealer should be able to look
this up via the VIN.
4. yes absolutely in every car. the small premium every 4,000-7,5000 miles is certainly worth it. but IMO it's only "necessary" in a turbocharged engine.
5. yep that's exactly what you do!
6. regular. no need for more than 87 with the low compression, low output 1.8L.
~Colin
Had you purchased a 90-00, 87 octane is all you'd need.
Won't it be kind of a bummer to buy a "new" Miata just to stick in some barn somewhere for 3 months?
I won't be in the market for a while but it's good to know this stuff.
-juice
Come on people! Tell me what you know about the upcoming Miata.
Car and Driver TV keeps showing one of the EARLY mules with an RX-8 front end and an NB rear and saying that a rotary option is in the works...all of that is pure Bravo Sierra.
Other rumors include power hartops, 2.0 / 2.3 L engines from the 3 and or 6, lower weight and warp drive with optional SUV seeking photon torpedos.
If I were in the market for a new Miata (which I'm not, my 90 A-package suitsw me just fine for now) I'd wait for the NC before buying a MSM...I wouldn't even consider a "regular" NB, been there, done that.
I'm holding out for that option. One more tall-mounted HID light on an SUV and I think I'd use it!
-juice
PF Flyer
The MAZDA MANIA chat is on TONIGHT. Join us for the '05 season of chat! Check out the schedule
But it's abit exciting to be in the market for another vehicle again. Since the car is for me, and the wife has her own ... I think I'm going to go for something 'fun' again, to act as a daily commuter and a cruiser.
Any thoughts on the possible NC? I'm not sure I want to throw down $26K on a new convertible ... no matter how fun.
But a 99 or 00 NB can be found with decent miles for $8-10K. Not too shabby.
Other than the Miata, what other options are there for "fun to drive", frugal, RWD, sporty cars?
S2000 - too pricie
MR2 - dinasaur
Z4 - not interested in a 6 cylinder
Eclipse convertible - don't want FWD, poor reliability
Solara convertible - no thanx for a FWD
tC - another FWD
WRX - ugly, poor mileage, not interested in AWD
Any thoughts?
I recently got an '02 Miata and would like to find a car cover for outside use. I've read some reviews of a few different brands, but thought I'd ask here for any ideas, as I know many of you are true enthusiasts.
I would typically keep the car covered for 3 or four days at a time, parked either on the street or in a back lot.
Thanks a bunch
>Any thoughts?
None here. You already own the perfect car :-).
Corolla SR5 (older models)
240SX
There's more but they're all pricier.
-juice
But ever since I have mentioned this to my friends, they have been laughing their heads off and taking all sorts of digs at me. Can a 23 year old guy not drive such an amazing car just because it was rated as a chic car? Is it seriously only a chick / gay / impotent old man car? I love the car but I simply dont understand all this opposition.
So you're a smart, middle-aged man. That's what it says about you.
Cabrio is the chick car, if that matter to you. More than 60% female owners.
-juice
If the perceived "girlyness" of your car is an important consideration to you, might I suggest watching Horsepower TV for a couple of weeks for some suggestions. A nice F-body or a Mustang should suit you. Or perhaps a giant SUV would work since it appears that gas mileage and "manliness" are inversely related you could go by that standard.
To me, I never felt more like I was driving a "chick" car than when I had an 02 Chevy Tahoe. Maybe it was because I bought it from my 5'2" mother-in-law or maybe it was because I saw mostly women driving them...how knows.
Either way, I didn't get rid of it b/c of the ignorant perceptions of others but rather I wanted a car that was fun to drive and economical. These characteristics are the embodiment of the Miata. If you are driven (like me) primarily by these two characteristics then ignore your friends and get yourself a Miata.
