Visitor Agreement.
~c
wrong-wheel drive.
not near as fun to drive as a Miata, but enough potential for a great driver to humble an average one.
~c
Well sure, I guess an F1 driver could humiliate any of us if he was driving a Jeep Cherokee---LOL!
-juice
I have been digging and will post info as I get it!!
I didn't really care for the Ibuki concept. I hope the production car is more masculine.
I wouldn't mind a lighter, more back-to-basics roadster, though. It's gotten too heavy and sort of forgotten its original mission.
-juice
I've thought a bit about upgrading to an 00 EVO orange or something (passenger air bag cut off and 87 octane fuel). But they cost about $8000-9000 more than my old 90 is worth and for $8000 I can buy a lot of upgrades for my 90 (turbo, suspension, cool paint, custom interior, etc. ....If I want to put in the work that is.
-juice
http://caranddriver.com/article.asp?section_id=29&article_id=- 9059&page_number=1
007
Styling looks good, at least.
-juice
I haven't decided whether or not to try to replace them myself or just pay a shop to do it (kinda cold around here). I also plan on getting an alignment at the same time so I may just have both done in the same trip. Maybe I've been watching too much Powerblock on Spike, but I have a (probably) idiotic urge to try the install with me, my tools and my Haynes Miata manual....hmmmmm.
Either way, after I put a few miles on the set up, I'll let you know how it works.
Here's praying for the same, or lower, ride height!
The way I see it, the main advantage of adjustable shocks is to fine tune them to reach the right balance of comfort and handling for you. If you install the GR-2s and find them too stiff or too soft, you are stuck with changing out the shocks again.
-juice
For $100 I can buy some fabric to reupholster my worn out seats. My Dad and I have those skills so I just need to go out and pick a fabric.
Slightly used, I suppose?
-juice
~c
Here's the best link I have found to a large batch of high quality photos - Discuss!
http://www.userweb.suscom.net/~95redmiata/NC/index.htm
http://autoweek.com/news.cms?newsId=101860
The review says it will have a 2.0-liter inline four-cylinder, up from a 1.8-liter engine in the current Miata . The bigger engine will turn out about 20 more horses as well, reaching upward of 160 hp. The torque climbs to about 140 lb-ft.
007
New design looks great from the rear view, IMO. I like the roll hoops too, and that means you can drive at a FATT event without a roll bar now.
Hood came from the Ibuki concept, so did the headlight shape, though the type is different.
I do like the fenders, gives it an RX8 flavor, that part of it is more muscular.
I'm not crazy about the front view, it could be more masculine, but overall it's nice and the design certainly doesn't seem to get in the way.
-juice
Solistice will be bigger and heavier, half way between the old Miata and a Corvette.
-juice
I think I'd rather have an orange MSM. More power, better looks (IMO) and a cheaper price tag. Unfortunately for me, the nearest Mazdaspeed dealer is at least 1.5 hours away...really inconvenient if I need any warranty work on that turbo.
My '93 has a tan interior and I liked that also. Black gets hot in the sun.
New one should have enough legroom for folks over 5'10".
-juice
Poor Richard
PS I've really seen enough of these Conestoga-Wagon-like wheels with the radial spokes going out to super-low-profile tires. They remind me of something out of an Old West movie, IMHO of course.
The new lights are integrated into the overall style.
-juice
Also does anyone know of of a mechanic in the New York City or Wash, DC metro areas that has experience with this problem?
I'm with shifty here, plug wires are by far the most likely culprit. The stock ones are horrible and usually don't even last 30k miles. Shop around for better ones, there is so much demand that you'll find 5-6 options.
After that, I'd change the plugs and fuel filter, if it's still bad then I'd do a fuel system service to clean that out. That last item solved a major hesitation problem on our 626 V6.
Top leak - I bet your cable snapped. That happened to my '93. I only found out when Performance Buyers Club replaced my soft top, but I'd noticed a loose cable and wasn't sure what it was for.
Cost me an extra $80 IIRC to replace that cable. It basically sinches up the top, so it might be the cure for your leak.
-juice
I'm 5'11" (6' on a good day with shoes) and I'd say I'm right about at the limit. Even I could use an inch or two more legroom.
30" inseam, 205 lbs or so.
And BTW, I put spacers in the seat track to give me better thigh support since my knees are splayed upward.
I have to wear small shoes (driving mocs work best), no boots, or my feet don't fit properly in the foot well, even.
Wait for a 2006 MX-5, it's got a 2.3" longer wheelbase and should be roomier in length and width.
Oh, also, the 2006 will finally get a tilt wheel.
-juice
All told, it was actually pretty simple. I started with the rears and IMO they were harder b/c I had to have my wife pry the lower control arm down to get the shocks in and out.
I then did the fronts which went wihtout a hitch until I had to cut out the lower shock mounting bolt with a pneumatic cut-off wheel b/c it was stuck in the shock bushing. Cutting out that bolt consumed more time than the rest of the project combined (had to run back and forth to Lowe's and Sears for various tools and a temporary replacement bolt...argh).
After replacing them I had to test drive. The difference is night and day. The GS2's are the exact kind of ride I was looking for, not to stiff, not too mushy. If you're shocks are over 50,000 miles or so old, or if you're like me, you don't know when (if ever) they were replaced, then you NEED to get some new shocks in there.
BTW, the spring compressors I bought at Advance Auto Parts for $30 were very simple to use and as long as you take your time, they are completely safe.
-juice
Tools I used were a torque wrench, a cut-off wheel for that friggin' bolt, a 17 & 21 mm socket, and a 17 & 21 mm wrench. You can rent the spring compressors in DC easy, around here, I couldn't find any to rent so I just bought them. I fyou take your time it should be pretty easy. It was quite a bit easier than when I replaced my soft top last summer.
The improvement in handling and ride after you're done will make you kick yourself for waiting so long....trust me.
