It's been a great truck. So long ole girl!
There might be two different cv boots available: one that you can put on and glue together, and the one that you can pull on by disconnecting the axle from the wheel. Once again, I don't know what's available for Rodeo and the only experience I have as far as changing the cv boots was on '88 Chevy Nova.
At that time (about 7 years ago) I was recommended not to get the "split" type cv boots as they don't live long.
It is actually a Honda Passport ESM, Electronic Service Manual, copyright 2004 by American Honda Motor Company.
It is a bunch of pdf files...I haven't looked at it much and still haven't found much of an index. But it is all there.
Joe
I'm just migrating over here...sold a 2002 Honda CR-V and bought a '01 Rodeo cuz I needed better off road clearance and capability, and more towing ability.
First thing...the Isuzu takes a lot of pedal pressure to stop. It doesn't inspire confidence in braking ability. Should I look at aftermarket and/or high performance brake pads? It has 43K miles on it.
Second thing...I just bought a set of factory fog lights. The kit contained two lights and brackets, a relay, two short wiring harnesses one for each side to connect the lights to existing wires behind the bumper...but no instructions at all? Does anyone know of a set of instructions? I'm hoping all I have to do is plug the relay into the under-hood fuse box, install the switch (hopefully the wiring harness is already there!), and install the lights. any ideas?
Does anyone know if the fog lights work independently of the headlights? When I installed the factory fogs on the CRV, I had to do some changes to the wiring to let the fogs work independently from the headlights. Otherwise, they only worked when the low beams were on. I'm hoping to be able to use them independendtly so they can be used as daytime running lights sort of!
Joe
Just change a boot actually add more work as outer joint is not separatable and they had to open/separate inner cv to get outer boot on.
This occurance has happened once before, but seemed to fix itself. It happened again yesterday, dont know what it will do today.
Heres what happens;
Driving down the highway with the cruise control on, approach an incline (hill). Starting up the hill, the cruise works at keeping the same speed. Suddenly however the engine starts over revving, under revving and so on and naturally the tranny is trying to keep up with this. Not a good feeling. I take the cruise off and feather the gas pedal to smooth things out. Once I am back in town driving, from a stop, I accelerate and the same thing happens. The tach jumps up about 500 RPM and then back down again, over and over. My speed slowly increases, but can't stay constant on the pedal to accelerate.
The first time this after happened, I after the fact changed the fuel filter, but it had already stopped doing this "thing".
I haven't got a clue!
I read through the forum until about page 58 and wasn't finding this occurance per se.
My Rodeo has never had any major problems. It keeps on plugging away and I love it.
Any ideas?
under my car and it looks like anti freeze what do you guys think would that be?Maybe you guys can give an idea.THANX....
http://www.montecarloss.com/TCC_Solenoid.html
ECM think you should change your shifting habits. Disregard it.
Clay
Good Luck!
Installation is pretty much fool proof. Put the brackets under the bumper and screw the lamp assembly to them. The pig tails will connect the lamps to the car wiring.
To remove the switch plug on the dash board, you need to remove the two screws that hold the hood release and the one on the bottom right corner. Then, pull the weather strip out and remove the bottom pannel.
I just finished the installation on my Rodeo and the memories are still fresh :-)
The dealer was asking $3900, plus $400 dealer fees, plus tax.
I offered them $2700 out the door and they took it.
Of those minor things wrong, 1 of them was an outer CV boot. I let this slide on word from a friend that I could buy a quickboot repair kit and take care of it myself.
<<<I've read some posts about expensive boot replacements... to help those folks out with outer CV boot problems, get yourself a few bottles of brake cleaner, prop up on jack stands, remove wheel, rip off the old boot, clean all the old grease and dirt out of the CV with the break cleaner, install a "quickboot" repair kit, I found that Pepboys had some that for my rodeo. They are slitted and do not require the removal of the CV shaft to install. you can do this yourself in ~1hour for about $20-30>>>
The week after I bought it, I drove it on a 3,000 mile road trip cross country to visit family, there and back, all things went very smoothly and I could not have been happier.
Did some 4-wheeling with it this last summer, seems to handle itself offroad as well or better than many other stock SUVs. very happy there.
Then, a little over 150k, the infamous valvetrain clicking began. This was very discouraging. Took it to a good mechanic I know, he wasn't suprised at all and I would soon learn that this is common for these enguines. My "good" mechanic said to keep changing the oil and I would be lucky to get another 10k out of it before it needs to be rebuilt.
Well, I'm sure some of you out there have had a look at the rebuild and part costs for these enguines, not to mention how hard it is to get ahold of the parts for them to do any DIY enguine projects. The hydrolic lifter that is the culprit for the noise, is a little piece of metal, a shim about the size of a .45 bullet. From isuzu they cost about $20 each, that's $480 for a full set. pretty nasty. Isuzu has a somewhat poor enguine design with no roller anything in the valve train that is prone to these problems.
I wasn't willing or able to have the enguine replaced or rebuilt so soon, So I've been on a search for oils, oils stabilizers, oil treatments, cleaners, etc etc. Trying different weights of oil, 5W-50, 10W-30, 10W-40, 10W-50, 15W-50, synthetics, high milage formulas, blends, STP, marvel mystery, rislone, MOA, etc etc.
162,000 miles was my last change, (i'll be doing another one tomaro for my ~165,000 change). I started this set of oil off as usual with a 99% multipass efficiancy filter from fram, this time I tried 10W-40 Mobil high mileage synthetic blend. I should point out that each oil change since the tick has began, has been the onset of a noticably louder time in this little enguines life, seems that the detergents in the new oil clean away varnish that helps bolster up warn out parts. hence- newer oil is both helping and hendering the problem. The mobil brand was no better or worse it seemed. To further suggest that the cleaning action was actually hurting the senario- I tried a karoseen flush using a karoseen based flush. (for use at drain time), after using this, the clicking got much louder.
I loose about 1 quart per 1500 miles since I bought the thing, this isn't suprising given the age of the enguine, it's bound to have some consumption. About 700 miles into my last oil change, (about 0.5quart low) I decided to try adding some oil treatment. This time it would be "Enguine-Restore,".. comes in a silver/black/blue can in different sizes for different sized enguines... (though I think the 8 cylinder size would be fine in the isuzu, since the oil capacity is nearly as much as many small-blocks) This stuff is a blueish milky looking substance that looks like it would never belong in your oil. However, the results were astonishing. The clicking was hardly noticable within 5 minuts of driving, and the very next morning, when those "cold-morning-CLICKS" are usually the worst on these enguines was completally silent. Sounded like this enguine was bought yesterday. If you are having this clicking problem, try enguine restore for awhile. I doubt it will make any enguine last forever, but It might just buy these old enguines another 20-40k before they actually need replacing. I should also note, that my oild consumption dropped slightly.
I should point out, that towards the end of this change, the clicking has returned a bit, but is still significantly quieter than it has been for the last 12K or so. tomaro i'm going to use the larger size can combined with a heavier oil with less detergents. I'll try to post some results in another 3k.
Try enguine restore before rebuild/replacing these things.
I have a 1995 honda passport 2 wd with about 100000 miles. it is in pretty good condition and been having trouble with acceleration on the hwy. I have taken it to about 3 mechanics and have spent over 2500 trying to fix it. The mechanics cannot seem to locate the problem or give me a direct answer to my problem. the just keep telling me to bring it in and they will check it. and i get the vehicle back doing the same thing. what happens is i am on the hwy and when i reach around 50-60 mph i let up on the gas and my RPM"s go below the 2 on the RPM odometer and after that i have poor acceleration it hesitates really bad and i have to push the gas pedal alot to get up to speed. i did some research and i think it might be oxygen sensor but i dont know i just dont want to put anymore money into it. If anyone has experienced what i am going thru or have any suggestions please help me.
I just had the emissions inspection for the first time since buying the car 3 years ago.
The results seem excellent except for the Carbon Monoxide reading which did pass the test, but is double the average emission for vehicles in this class. Does anyone else have the same obvservation? is this normal for Rodeo's? or could something be wrong with mine?
Thanks in advance
Put in a rebuilt tranny and changed the master cylinder.
Any ideas why this is still happening?
If your CO reading differs significantly from other Rodeos then you might have a problem with the catalytic convertor.
Also, I am a little concerned about the price difference between PVC valves in retail stores vs. Dealer. Usually, items like that are priced similary, however, the most expensive PVC valve in Checker is about $10, while dealers charge $20. It doesn't seem to be a complex device, so do you think it's Ok to purchase Fram or other type of brand name after market valve or I'd be better off going with OEM one?
If so, assuming the transmission is OK, it would have to be clutch or linkage. If it is a hydraulic clutch, it may be low on fluid. Or it may be clutch linkage is out of adjustment.
Where does the clutch pedal "catch" when you are releasing it? High or low?
Just prior to changing the master cylinder and tranny, we did notice that the system was leaking somewhere because after a week or so of driving, the resovoir was empty.
This was happening before and after replacing the tranny with a rebuilt and a new master cylinder.
I read somewhere else that someone was having a similar problem and someone mentioned a possible cause as the sychronizer, but would that still be feasible with the problem being present before and after a tranny swap?
Thank again.
Also, look for a leaky transmission - gear oil and not hydraulic fluid from the clutch linkage.
Check the gear oil level in he manual trans see if it is low. If the hydraulic fluid in the clutch slave cylinder is full and the clutch catches "high," try and "double-clutch" between gear changes and see if that helps.
If the fluid still drops in the master, check the slave cylinder on the trans body for leaks.
I'd really check the clutch out, including making sure the hydraulics are working properly.
I have a 95 Isuzu Rodeo that had trouble starting this morning. It would turn over, but not start. A friend came to give me a jump and it worked so I headed off to work. When I got to work I turned it off and decided to try to start it again, but this time it wouldn't even turn over. I've tried jumping it again, leaving it charging for 5-10 minutes, and nothing.
One strange thing is each time I try to start it, and it doesn't turn over, my hazard lights start blinking (specifically the two lower ones on each side, and the upper left parking light if you're looking from the front). The lights will blink for about 4-5 minutes and then stop. Is this some sort of code? Oh, and just in case you're wondering, the hazard light switch is turned off inside.
I thoroughly cleaned the posts and am now just looking for advice.
Thanks in advance.
Thanks for any advice anyone might have to offer.
David
