I have to piut fluid in the radiator every few days. Could by engine be going or is it gone.
Any suggestions will help.
Shop said only Dealer parts will fit right...?? He is charging $55 labor plus parts for rear brakes and only $30 labor for front brake pads plus parts. Is that fair?
or just that the monroe matic plus is not that good as i expecting.What do guys can suggest me?What kind of shocks can you reccomend to put in my car i'd like to have a good ride with my car.THANX...
http://www.planetisuzoo.com/articles.htm/116
The valve cover gasket leak you are experiencing is also a fairly common problem. Isuzu has a new design for spark plug wires which have boots that can better keep out oil. If you lose 1 quart of oil per 1000 miles, then this is considered OK by Isuzu. Many of these vehicles lose some oil. Has to do with ring design that does not have enough drain holes, or so I've read. Overall, I would not panic about your engine unless there are other reasons for which you suspect major valve trouble. The problems you describe above are things that most rodeo owners have experienced and deal with.
I have a 1994 rodeo 3.2 thats been overheating after 20/30 minutes drive time.
I felt the radiator after running hot yesterday and it was cold. This morning
I removed the cap, started the engine, and coolant immediately started
rising up the filler neck. I think there's trapped air, but not sure how to
burp it out. Any help would be greatly appreciated.
Mike
replaced the gear in the vss dealer says maybe in the cluster or pcm extremely expensive waiver is 689$ for emissions. diagnostic will just about get me there
I'm already up to 250$ parts and labor.dealer also says code not matching symptoms?po 502. this is a 2wheel drive v6 3.2 sohc, auto.thank you for your response 2n.any ideas?cause this sucks man!
Anyway, my question is what should I ask and look for to know if the Isuzu is in good condition?
....Any help you can give a "dumb girl" would be greatly appreciated!....I wish I found this place sooner because I have to go check out the rodeo in an hour!
Many thanks!
on another note, my engine fan is unusually loud sometimes, what is this attributable to?
any advice would help a lot.
My brother's 01 Rodeo tranny was ruined because of Jiffy Lube servicing his ATF fluid. Had to go to dealer and repair for $900. Luckily we had a family attorney persuade the dealer to cover the costs.
Fan is normaly loud under hot conditions. Check your whole cooling system. Belts, hoses, and fluid.
I think you are fine with the rear differential change. 2WD have a rear differential if that makes you feel any better. Look at the rear "pumpkin" and you will see a fill hole and drain hole.
Make sure it s a trusted competant mechanic. It should not cost that much to change a gasket and fill the ATF again.
