1.)Mine has a vibration between 50-70mph(comes & goes). Started at about 60K. Three sets of tires, Hunter balancing, match balancing, balanced inside and out, alignments, etc. It's still there. I will probably try experimenting with toe-in next (unless it sells).
2.) Had the "thud" sound a few times but not lately. Dealer said NPF at first, then lubed rear shaft splines. Had to have it done about every 15K for a while, then it never came back. Yahoo.
3.) Brakes all around at 64K. First set of tires at 66K. Lugnuts breaking? Yep.
4.) Intake manifold gasket at 74K. Felt like it was running on 5cyl. Rough idle, engine light were symptoms.
4.) Just replaced the battery at 91K (four years old).
Always got loaners at my dealership, but not too happy with being shrugged off regarding the vibes. They made me feel like I was imagining it. Now they admit it and they tell me it could be the wheels. Maybe, maybe not. I've been satisfied with my Rodeo except for this problem. I would buy a 2001 if I knew the vibes would not occur. I may still buy one, but would deal with Isuzu differently (lemon law). I know there's a solution somewhere, but my patience is near it's end.
Nate
-mike
Every Thursday, 7:00-8:00pmPT/10:00-11:00pm ET
Your Community Leaders are paisan and arktrooper1
-mike
I've leased two Honda Civics in a row, and my current lease is up. I went to a Honda dealer to look into leasing a 2001 CRV, because I've been very happy overall with my Hondas, but wanted a change of pace from the Civic. They couldn't meet my price range, but the salesman showed me a 2001 Rodeo LS V6 4wd, with 8100 miles. He said that it was owned by a business, and they went over 6000 miles, and it couldn't be sold as new, so the dealer got it at auction for a really good price. It looks like it's never been driven. It even still has the new car smell. I like the looks, and feel of it a lot better than the CRV's too. Apparently it's a somewhat base model. No keyless entry, no moonroof, cassette instead of CD. It does have a lggage rack. It was almost closing time, and I told the salesman my wife would have to look at it before I make a decision. ( I'm sure some of you know how that is...hehehe) He let me take it home for the weekend while he works up the final numbers, but it's going to be around $255 a month, 60 month lease, and about $300 up front for first payment and title. He gave a very rough estimate of $7000 to $8000 buyout at the end of the lease. He said that I'm getting a good enough deal, that I could probably sell it in 2 or 3 years, and pocket a few thousand dollars. I really like the vehicle, but all of the problems I'm reading about on here makes me hesitant. I'm used to the trouble free reliability of Hondas. Does anyone have advice for me?
Thanks !!!
-mike
But talk of oil consumption, pinging, etc., now I'm scared about the papers we just signed on a loaded 01 LSe Rodeo.
1) Truck stickered at $32K - $2500 discount - $3000 dealer cash = $26500 sell price -> 450/mo for 72 mos. Does this sound like a good deal?
2) How would you rate Rodeo vs: Liberty, Escape, Xterra, etc.
3) Reliability?... I know we have the great warranty, but the oil problems, etc... I have owned a Mitsubishi galant and the big items are OK, its the little stuff that started to go (electrical, etc.)... same problem with the ISUZUs ?
4) Towing? I have a 1400# empty / 3500# max enclosed MC trailer I want to pull-- any problems.? I've heard some talk of the 3.2 being under powered.
Thanks in advance any other words of wisdom appreciated.
-Tim
Great White North, PA
Don't be fooled - that stuff comes in a spray can!
tidester
SUVs
On a side note, the reason for the low risiduals is that the market doesn't particularly like used Isuzus, most likely cause they are a small volume seller so there isn't a pent up demand for them. if you go to some of the Isuzu formums on the net (http://4x4wire.com , http://vmag.com ) you'll see tons of owners who regularly abuse them off road and they just keep running.
-mike
Way to do your job.
P.S. I have never "ditched" Isuzu and regret that you could have construed anything I have said in that way.
tidester
SUVs
-mike
tidester
SUVs
-mike
Here's the info if you're interested:
purchased from www.shox.com
Front: 30-1663
Rear: 30-1664
Total price was $319.00
I'll try to follow up as soon as I get them installed.
To Paisan. These are adjustable, but the adjustment has to be done while the shock is off the truck. There are three settings available. Maybe not the best way to use an adjustable, but it at least gives me an option if I find the initial ride to be a little soft and want to firm it up with an adjustment (although I'm hoping that I like the way they ride with their default setting).
Take care.
I looked at Koni's site recently saw they were adjustable, but had to be removed.
-mike
When I first got the truck I really like them, but I noticed that they barely make any diff with them on or off, Does anyone know of a good and effective upgrade for the fog lights and head lights. I don't know which light bulb i need to make brighter and w/o effecting the electrical system.
-mike
-mike
-mike
Cam
Also, what brands/models have you had success with?
My first question is whether an LS can be an LS without the “standard”
heated mirrors. My follow-up question is if there is a way that I can
determine if the package is actually an “LS” or if it is merely an “S”
with the “power” option that provides power mirrors. I’m paying an “LS”
price and I ran a CARFAX from the Edmunds link and it fails to make
mention of the trim. I don’t know whether the omission of the “LS”
designation from the CARFAX means it isn’t an LS or whether it just
means that CARFAX doesn’t provide the trim designation based on the VIN
Additionally, how do the 3yr, 5yr and 10yr warranties work when I buy the vehicle used?
Thank you in advance for your help
-mike
Regarding the warranties, is none of the powertrain or roadside assistance transferable? Is the bumper-to-bumper automatic with my purchase or do I have to fill out some sort of registration?
-mike
-mike
-mike
Also, do they really worth the money? I had aftermarket fog lights (yellow) installed on my Tercel and they did a great job for me, but the ones that come on Rodeos are not Yellow and I'm a strong believer that in Fog condition, yellow is much better than white. I might be wrong, but I think I've read somewhere on Edmunds that fog lights on Rodeo are not that bright... any personal experience?
I was also thinking about putting Sylvania Extra Vision bulbs in the front headlights. Any difference? I had them on Prizm and they were much brighter than the original ones... The downfall is that they were burning out too fast :-)
Sylvania also offers something that they call "Cool Blue." Any opinions?
-mike
-mike
