-mike
-mike
-tom
-mike
In August 2001 I took my Rodeo in because I was going through about 1/2 gallon of coolant/week. Dealer pressure tested my system and said everything was fine.
Obviously everything was not fine and I continued to add about 1/2 gallon of coolant/week. Finally, a service station attendant suggested that I have the gaskets checked/replaced.
I took the Rodeo back last December 2001 and the dealer had the beast for 3+weeks and replaced the cylinder heads (cracked). This has not solved the problem.
I got the Rodeo back last Thursday (1/10/02) and filled the radiator and reserve tank to the "max" line on Friday morning(1/11/02). Between Friday and this morning (1/14/02) I drove 100 miles and my reserve tank is down to the "min" line.
Every time I stop the car and get out, I smell the coolant.
Has anyone else had a similar problem and what was the fix?
Thanks for the help, I am about ready to ditch this vehicle.
-mike
out from Isuzu on the problem. They have a special additive they put in and it solved the problem. No leaks yet. Knock on wood, that was back in August of 2001.
Steve
-Ryan
Anyone have this expereience as normal or is the head gasket starting to go at 71,000? As engien really cools off and on cold nights the gaskets small cracks permit some coolant into the cylinders? Anyone else?
The post above with a coolant smell,. definitely a leak, is the tank cracked at all?
Any ideas on an oil seepage on thsi engien around the alternator, does not seem to be a valve cover but oil drips down from the alternator area. Any gaskets, O rings seals in that area on this engine?
-mike
tidester
SUVs
I'm pretty sure your dealer would be happy to find you the rims - it's going to cost you though. You might also check junk yards or get something that look similar at Discount Tire store or Big-O or any other tire store. It'll probably be cheaper than dealer's prices.
My local dealer has rims in stock and the prices range from $180-350 each. Regular rims (the cheapest ones - not alloys) run for about $60-70 at Discount Tire.
www.aaarims.com
and www.car-parts.com
-Ryan
They slam it big-time.
The biggest issues I saw were build quality, handling, power.
Any opinions? Set me (and them) right, please!!
Steve
-mike
I personally own a Honda Passport, and what a peice its turned out to be. When I bought the truck I thought it would be durable and reliable, but it has been niether. It's a 98 that rattles and squeaks, and after reading all these previous postings, I'm just waiting for my engine to fail.
You seem to take up for Isuzu, but you just don't know how far Isuzu is behind, Nissan and Toyota in build quality and reliability.
You keep pointing to the Tribute/Escape problems, but atleast in those cases the companies stood up for thier products and didn't leave the owners stranded like Isuzu has a tendency to do.
The only reason I bought the Passport, was because fo Dealer service from Honda, which is far superior to Isuzu. So far I have not been let down in any of my multiple problems from the guys at Honda. So basically, Paisan stop fighting a losing cause.
http://www.fastriceracing.com/wwwroot/Personalpages/DaveC/Instructions/useful.htm
Monroe Gas Matics: Part Number: Front- 32336 and Rear- 32337
Montoe SensaTrac: Part Number: Front - 37159 and Rear-37160
-mike
-mike
96 Rodeo
98 Amigo
01 Rodeo
Absolutely no problems whatsoever. Back in '96 I was looking at Passports and realized the price and warranty were for suckers. Especially since they have Isuzu stamped right under the hood!
mnaik, go have some cheese with that whine. If you love Honda so much go get on a waiting list and buy an Odyssey.
The more I research this vehicle, the more I question whether my needs are in line with what it delivers.
We need a cargo-hauling, roomy vehicle to complement a coupe as a 2-car family, that is comfortable enough for medium road trips, would not be used as a commuter, and can handle Ottawa, Canada winters competently. Plus a trip or 2 a week to the in-laws beef farm with a rarely-plowed lane way.
The primary reason I want a 2nd car is so that if my wife and I start poppin' out rugrats, I never have to leave her alone without a vehicle. I question the choice of a Rodeo for a few reasons:
1) What is its target market? Off-roaders who like to get to the trails in style?
2) Is the initial quality an issue, whether it lasts for years or not? I've read a lot that questions it, not just the review in my initial post...
3) Is this vehicle to be replaced by the Axiom as far as a primarily road-going vehicle goes? (ie - Rodeo is built even more tough and off-road able, while Axiom fills in the need for a road-going car-like truck)
4) (For Canadian buyers) - are Isuzu's prices even negotiable, as they are under the Saturn umbrella in this country?
Thanks fer yer time!
I have recently purchased a late year 98 Rodeo LS. I love the look and feel of the truck with one exception. When I come to a stop, I get a "clunk" like the drive train is catching up with the truck. This also happens when I take off from a light. It does not happen in Neutral or reverse. The Isuzu dealer here tells me that it is normal for a 4x4 to do this. I have driven other 4x4 including Rodeo's and they don't do this. Does anyone have any ideas. The truck only has 36,000 miles on it.
-mike
If it doesn't clunk going back and forth from drive to reverse it could be more than the driveshaft. I'd take it to another Isuzu dealer who is interested in really finding out what is wrong.
I paid $21K for my LX 4x2 V6 brand new, so I really don't feel like I got ripped by not buying the Isuzu instead. Anyways, whatever I may have overpaid, I have already reaped the benifits from great Honda Cust Care. And also at the time Isuzu only offered a 3 year 50K warranty, which is the same as a 3 year 36k one from Honda, because I don't drive that much.
Well, this is my situation guys, if all of you can give me some input. Like I said, I have a 98 Passport with 46,000 miles, and mechanically it has been relatively trouble free since I bought it brand new. The only problem is that all the sites that I check including this one and MSN Carpionts, have horror stories about having to replace and rebuild engines on the 3.2 V6. I am in college right now, and my parents bought me this truck when I was in High School. Should I go ahead and sell the truck or keep it until I finish school and hope to not have any problems with it.
I personally am a huge fan of Isuzu Desiels, and I really don't mind my Passport, except for all the rattles. I am majoring in Mechanical Engineering, and all of the guys in my classes including myself are simply in awe of the Duramax, which I think GM takes all the credit for, even thought its all Isuzulogy. I need to get another 60K miles out of this truck, until I can graduate and buy something else. I know that you are all Isuzu crazy, just like I feel about Hondas. Please help me with some suggestions. What do all of you guys, including amigo john and Mike (Paisan) suggest. Thanks for the input guys!
-mike
Has anyone else had a problem with the cat converter that required replacement
-mike
The Rodeo isn't the best SUV out there unless you take price into consideration. What else can you get loaded for under 25k? Maybe a Rav4. A 4Runner is 12k more. My Amigo was $14,500 w/Alloy Wheels and AC. What can you get for that? Not even a lowly Kia.
If it hasn't given you mechanical problems by now it should go 120k with no problems if you take care of it. Sometimes the best car you can have is the car you already own if its paid for.
As for squeaks and rattles, have you ever removed any door panels, dash trim, etc. That'll make one rattle if not done properly. Heck, you're an ME, whip out the screwdriver, foam weatherstrip, etc and track down those rattles and fix 'em. If you'll drive to Alabama, I'll even help you.
I took apart a dash on a buddys '85 corolla that had about 50 business cards folded up and jammed in various places to stop rattles. Everytime I loosened something I would get hit in the head with cards!
Too bad Isuzu doesn't make diesels here. I have a VW Golf diesel with 251k on it and it runs like new.
thank you
-mike
