Jeep Grand Cherokee
1252628303149
  • joec4nowjoec4now Member Posts: 3
    'themanx' - Thanks for the input - if you don't mind me asking, was this with 0% financing? If so - great job negotiating and for giving me reason to negotiate much further!
  • themanxthemanx Member Posts: 110
    Sorry Joe.. you get a choice of either $3000 cash back or 0% financing. Since I got 4.75 from PeoplesFirst here on Edmunds, I chose the $3000 back...
    The 03's are starting to hit the dealer's lots, so they do want to sell those 02's pretty bad.
    Good Luck!
    Stan
    Thanks Stan. Looks good.
    joec
  • rcleimbachrcleimbach Member Posts: 2
    I have a 2000 JGC (26F package) that has the Select-Trac 4WD system. Never had one problem with this SUV, except for warped rotors. My lease is up and I have the opportunity to buy a new 02 (26T package) for $29,289 with 0% financing. This one has the Quadra-Trac II 4WD system. Are there any pro's or con's for the Quadra-Trac II with respect to reliability, performance, etc. as compared to the Select-Trac?????
  • sebring95sebring95 Member Posts: 3,241
    The selec-trac you have now lets you choose part-time, full-time, 2wd, or 4lo. The Quadra-trac II is the same as full-time selection on the selec-trac system, only you have no choice to run 2wd or part-time. The selec-trac is much better in my opinion just because of the choices. That is unless you run in full-time mode a majority of the time. The full-time system on these models splits power between front and rear axles. The next step up is the Quadra-drive system which also only comes with full-time or 4lo selection. The difference is it can split the power to all four wheels, instead of just front/rear. There is also a vari-lock rear axle option which I believe is available with both Selec-trac and quadra-trac II systems. This will help split power to the rear wheels as well as the front axle. Selec-trac with the vari-lock axle is a darned good system. Unless you're just driving to the mall in a couple inches of snow, then this is all nonsense:)
    There's been alot of folks complaining about gear whining with the Quadra-drive system so if you don't really need the capability it may be worth skipping that optin.
  • dlcleavdlcleav Member Posts: 40
    My '02 JGC Overland made enough noise on the test drive the dealership is replacing the rear-end. They've been waiting on a bearing for about a month now and I've noticed the gear noise only on a couple of occasions since I bought the Jeep. I'm wondering now if the rear-end needs replacement at all. I'm a bit worried the techs may cause more damage than they solve. Any thoughts? I just went over 10K and run about 3500-4000 miles / month. Thanks - Dave
    I'd leave it alone. You've got plenty of warranty if it starts coming back and bothering you. These are rather complicated 4wd systems, it's going to be hard not to have some noise.
    Thanks sebring95, I'm leaning in that direction. I bought the extended warranty good to 100K miles which ought to cover just about anything that might be a problem.
    Just cancelled the rear-end swap out. The service manager said the shop was waiting on a special tool as the housing is aluminum back there. I think I'll have them check it out when my warranty is about to expire. Thanks for the info. Dave
  • kkuligkkulig Member Posts: 150
    As sebring95 describes above, you have three 4WD systems...
    Selec-Trac (standard and only available on Laredo). Quadra-TracII (optional on Laredo and standard on Limited). Quadra-Drive (optional on Limited and standard on Overland).
    A Vari-Lok rear axle can be ordered with Selec-Trac or Quadra-TracII. Front and rear Vari-Lok axles are standard with Quadra-Drive.
    The difference between Quadra-TracII and the old Quadra-TracI transfer case is that the QTII utilizes a gerotor coupling instead of the viscous coupling used in the QTI. I've never owned a Selec-Trac, so I can't tell you what's in that transfer case.
    Out of the 3 systems, the Quadra-Drive is my only choice. You just drive it and it does all the work. You feel nothing as it engages or disengages. It is hands-down the best 4WD system in snow that I've ever driven. I haven't had any trouble with the 2 I've had and I haven't noticed any abnormal tire wear from this system either.
    The Quadra-Drive gear whine was most noticeable on early production 99's (built prior to 4-99). And not all of this whine was attributed to the Quadra-Drive system itself. From then until now, the entire system has become much quieter. The 99 can't compare to the quietness of the 02.
  • paramedic99paramedic99 Member Posts: 64
    Well I have been away from this board for a while - too busy with work ! But I just returned from the 4WD section of the OBX and wanted to bring a few things from my observations to this group based on many previous discussions.
    1 - The MDX did horribly on the beach and I saw several stuck. True, it could be attributed to the driver however in 8 days of observation and discussion NO Jeep product was stuck on the beach.
    2 - If you own a Ford Explorer walk up the beach, as you have a zero chance of making it. I personally helped 5 get unstuck.
    3 - The Jimmys and Blazers did OK but the new Trailblazer was fine.
    4 - Several people made it through spots the MDX and Explorer got stuck with their Subraru Outbacks. That is extremely impressive.
    If you have no experienced beach driving I am talking about huge ruts, deep sand (soft variable depth), and water.
    I have read lots of stuff about the Jeep being substandard etc but I am now completely sold. What else could I drive through bad off road conditions with the a/c on, sipping coffee ?
    Other vehicles that made it are:
    GMC Yukons
    Large pickups with 4WD
    Ford Expeditions
    Ford Excursions (although I saw 1 stuck)
    Land Rover products
    The choice by far was the Jeep which was also driven by rescue, fire and law enforcement in this zone.
    I dont even bother including the "luxury" SUVs from Lexis, Mercedes etc as I dont even think of them as off road capable. The same holds true for the Rav, and the Kias none of which I saw on the beach.
  • bluetrainbluetrain Member Posts: 1
    I'm getting ready to buy an 02 Grand Cherokee Limited 4x4, and was wondering what the real world gas mileage is of the two V8's. Jeep lists both the 4.7 and the 4.7 High Output at 14 and 19.
    What are you guys really getting? Also, Is the High Output V8 really worth the extra money?
    I'm averaging a steady 17.6 on my 02 with the standard 4.7L engine. This is with a round-trip commute of about 50 miles a day. Mostly open road and freeway (60-75mph) with a little city driving. I only have about 4.3K miles on it so far and expect to see some more improvement as it breaks in. This is a great engine with plenty of power.
    I haven't personally driven a 4.7L HO so I can't comment on it. I've read that some people think it has noticeably more power and others say little to no difference to the standard 4.7L. All you can do is test drive the two for yourself and decide if it's worth it. The HO requires premium gas to see the published HP/torque figures, although it's supposed to run fine (lower HP/torque) on regular.
  • olizerolizer Member Posts: 38
    That is always one of the best shows on earth -
    If they would air down most would make it. There are just too many people who buy SUVs and think they are go anywhere tanks. You could spend your whole day pulling out the tourists, but you are correct - can't remember seeing a Jeep stuck. Maybe because they're more educated on how their vehicle works.
  • skijeepskijeep Member Posts: 8
    I am on my second JGC, the first was a '99 Laredo, the current one being a '02 Special Edition, both with 4.7 V8. The '02 only has about 3,800 miles on it and I have been averaging around 16.8 mpg in a mix of driving. On my '99 I saw anywhere from the worst average of 14.5 mpg (local driving in the mtns of VT), to the best average of 21 mpg (all hwy driving). In my own opinion I would not be concerned with gas mileage differences between the 4.7L and the 4.7L HO when considering between the two, but instead the horsepower and torque differences. Do YOU notice the difference and if so, is it worth it to YOU to pay the extra money for the HO engine?
    I personally have not driven the the JGC with the 4.7L HO engine and was never considering it. I believe the power from normal output 4.7L is outstanding and was worth every dollar over the I6 engine which if I remember correctly only gets about 1 to 2 mpg better than the V8. For me the normal 4.7L has suited all my needs perfectly, but that is my own opinion and of course the next person that comes along may have a completely different opinion.
    On this Town Hall posting over the last three years I have read opinions praising the current JGC model to ones calling them crap and lemons. I don't disagree that there have been owners that unfortunately purchased models that were Lemons or JGCs plagued with problems. Though, I don't believe that ALL JGC are bad as some have tried to claim. In my own experience with my '99 that I just recently traded in, I did experience defects, but no where near as bad as some owners have complained about in this forum.
    The only grievance I had with the '99 was with the front rotors warping and that in only 31,000 miles the rotors had been replaced three times and the front brake pads replaced twice. Except for one set of brake pads, every problem was replaced under warantee (by a dealer that I did not even purhase the vehicle at) and I was never left stranded by a break down. Overall my '99 was great, I enjoyed driving it and I think otherwise I would not have traded it in for the '02 which is noticably better.
    To each his own, but one thing I would keep in mind that on forums like Edmunds Town Hall, people will always have more of tendency to take the time to voice their compliants, grievances or basically vent thier anger becuase they feel they have been cheated or ripped off. There are far less postings giving acclaim or praises. Why? becase those who are happy are out enjoying what they have. The JGC is a great SUV, and unfortunately every so often somebody gets a bad one. But it is not for everyone and that is why there are so many different options of vehicles out there in the car market.
  • santy99santy99 Member Posts: 5
    I'm about to by this car. It's red w/black molding, just like the one in the movie w/Kirt Russell. It's loaded w/leather and power everything including a Premium Sound stereo system w/CD. The owner was very honest and showed me all the maintenance/service records including the recalls for the 97 models, it was all taken care of. However, it looks like this high-maintenance car needs to be on a tight service schedule to keep it reliable. Is this normal for Jeeps? The car looks very clean and the report from Carfax.com came out clean. I've always been a Jeep fun although I've never owned one before. I love this particular model and I actually already put down an offer and we'll be closing the deal soon. However, after all the problems I'm reading about, especially on the 99s and 01s models I'm getting scared and tend to pull out. Can anyone with experience with the 97 models give me some advice before making a $10K mistake... Thank you!
    Well, it can be a crapshoot either way and that's a decision you have to make as far as buying a 97. I had a 93 that was great, a 98 that went back under the lemon law, a 99 that was relatively trouble free and currently an 02 with no problems so far. As with any vehicle, you can get a bad one.
    The I6 (not a V6) is a good engine, but it's a little anemic in a GC. They had some issues with this engine, like problems with the crank position sensor failing and many people have also complained about overheating problems.
    The earlier GC's were plagued with transmission problems/failures and some even had steering gearbox failures. You didn't mention what transfer case was in this particular GC... but with the I6 engine, I assume it's a Selec-Trac. The earlier Quadra-Trac I transfer case (used with the V8) had problems with the viscous coupler failing. (The 99-up uses a gerotor coupler in place of the viscous coupler... no more problems). And of course, the infamous brake rotor problem, which is simply solved by replacing the rotors with any decent aftermarket brand of rotor. Those are the major issues... everything else is relatively minor.
    Sounds like a lot, but really no more problems (and in some cases fewer) than other comparable 97 SUV's. You take a chance buying any used 4WD with that kind of mileage. Now it sounds like this guy took pretty good care of it, so that's something in your favor. But also realize that things can and will eventually go wrong. It's still a used vehicle and like other SUV's, it's mechanically complicated and can be expensive to fix. My 93 was extremely well cared for and trouble-free. I sold it at 84K miles to a private party when I bought my 98. Within one month of selling it to this guy, the transmission and steering gearbox failed. Who could predict this would happen?
    Despite what you've read/heard, there really are no "horror stories" with the 99-up. I don't know who coined that term for the GC's. It gets used a lot when people complain about the brake rotor problem. That isn't a horror story, and like I mentioned above, it's a simple fix.
    Yes, they had some problems early on in 99. The 99 was an entirely new design and bound to have first-year bugs to work out. (The majority of problems on the 99 were on vehicles built prior to 4-99). The improvements made since then are significant. And even with that said, you still can't compare the overall quality and reliability of the WJ (99-02) with that of a ZJ (93-98). They are two different animals, but still better than most anything else out there today.
    I don't think the GC is any more high-maintenance than another SUV. Other than routine service (oil changes) the other thing is to change the front/rear differential oil, trans and transfer case fluids at the recommended 30K mile intervals. That can get expensive, but it's one of the things you put up with if you want to drive a SUV.
    I've tried to hit on some of the pro's and con's for you. And it probably adds to the confusion more than help you make up your mind about buying this 97. Personally, I'd scrape up the extra money and buy a WJ with fewer potential issues. I think you'd be more happy with one of those if you still have your mind set on a GC. Good luck with your decision.
  • janzjanz Member Posts: 129
    You seem quite knowlegeable, however, Quadra-TracII with Quadra Drive are both options on the Laredo and you can have them both. I do. They are not necessarilyseparate/different systems.
  • erickplerickpl Member Posts: 2,735
    Does anybody know if the TSB for the brakes has any limitations (mileage, year, etc)?
    My JGC is a 2000 Limited and I'm beginning to notice the pulsating others here have mentioned.
    Thanks for any information.
    -Paul
    Unless they changed something mid-year, what I stated above comes straight out of the 2002 model year catalog. KBB's new car pricing bears this out too.
    For a Laredo, they list the Selec-Trac (NV242) as the standard transfer case and Quadra-Trac II (NV247) as the optional transfer case. There is no mention of the Quadra-Drive system being available on the Laredo.
    Also on the Laredo, a Vari-Lok rear axle is an available optional with either Selec-Trac or Quadra-Trac II. Note: having this option with Quadra-Trac II does not make it a Quadra-Drive system.
    On the Limited, Quadra-Trac II is the standard transfer case, which can also be had with the optional rear Vari-Lok axle. Quadra-Drive is the optional system, which gives you the Quadra-Trac II transfer case plus front and rear Vari-Lok axles.
    The only 4WD system available on the Overland is Quadra-Drive.
    Note that Quadra-Drive employs both FRONT and REAR Vari-Lok axles as standard. It is a totally separate system and only available on the Limited and Overland models.
    Also, Quadra-Drive is only available with the V8 engine... at least that's the way it was when they came out with it in 99. I believe that's still true today on the 02's.
    The easiest way to tell if you have Quadra-Drive? Does it have the Quadra-Drive emblem on the console by the shift lever and one below the Jeep emblem on the lower left side of the liftgate? If not, then you don't have it.
    Unless someone can show me that I'm wrong here, I have to stand by my original statement. :o)
  • kullenbergkullenberg Member Posts: 283
    I think the only thing you missed was that you can option the Vari-lock rear axle with a 2wd GC (I think it must have been the Ltd), and in fairness, that's not a 4wd system, which was what the discussion was about. Otherwise it was right on.
    I need, sometime in the future, to talk with you about the Quadra Drive system in extreme winter conditions. My short list of replacements for a 99 MB ML430 includes a Volvo XC90, a VW Touareg V10 TDI,and the JGC Overland (hopefully with the Hemi), all of this happens in May, 04
    Cheers
    Pat
    Fire away with your questions when ready. I'll do my best to answer them for you. :o)
  • evaddaveevaddave Member Posts: 156
    Does anyone out there know of a good website to order parts and accessories from? (hopefully some place that sells below msrp) Having an '02 JGC, I'm now looking for cross rails for the roof rack, since they no longer come with the Jeep.
    And if the price is right, I may just bolt on some tow hooks, too.
    -Dave
  • tim_hooligantim_hooligan Member Posts: 143
    I thought I'd throw this one out to you guys...
    2002 JGC Laredo Sport 4x4 4.0L I6
    6000 miles
    What would be a fair price for this Jeep? Dealer asking in the 23's, but I know these thing are going for about 25 new...
    evaddave - I'm new at this only recently a new owner of a JGC. I've used Jeep.com as well as jparts.com to order the cross rails, bug shield, cargo mat, canoe carrier, utility bar etc...
    There are probably more vendors out there. Jparts.com appears cheaper than the jeep site with the quality the same. Dave
    I have the badge on the liftgate, and on my shift console and the original sticker with it listed as an option. We discussed the benefit of this option at purchase.
    I have seen several Laredo's around town with the Quadra-Drive lable on the liftgate. And at least one didn't have the V8 badge.
  • stlshopper12stlshopper12 Member Posts: 11
    I have 2001 Grand Cherokee Limited, 4x4, v6, white, beige leather, sunroof, cd changer, 12,250 miles, and very clean vehicle. I'm trying to sell this privately with an asking price of $24,500. I'm in the St. Louis area. Does anyone have any opinions on this? Do you think it's too high, too common to sell privately, etc? The dealers around here are asking about $26-27,000 for similar ones. Any info. on price would be great. I have it listed on autotrader.com and in the newspaper. Thanks.
  • cstillermancstillerman Member Posts: 2
    2001, JGC, 4.7, 2WD. I am getting ready to take my car through the "Lemon" arbitration process. My problem, which Jeep says is normal, is that when I take the Jeep out of gear, it make a very loud "metal to metal" sound. I have had work done on it 4 or 5 times but nothing seems to help. There is a lot of torque in the transmission when I take it out of gear. I am afraid that it is just one step away from going back into gear. I have driven several other similar Jeeps and they don't have this "normal" operating problem. Please e-mail me with specifics if you are experiencing a similar problem. (dstillerman@mindspring.com) Thanks.
  • tekoah137tekoah137 Member Posts: 1
    I'm looking into buying my daughter a 98 GC (She's 16) was wondering if this is a good purchase? The tranny seems strong along with the base I-6 engine, are there any signs when there are problems with the tranny? The truck has 60000 miles but after reading some of these posts has me wondering about the reliability ... Thanks for any help ... feel free to e-mail me if need be ... tekoah137@aol.com
  • jimmyx2jimmyx2 Member Posts: 26
    My son is considering buying a used GC - maybe 2 years old. He hasn't looked at them yet. Is it better to think about buying a new or 2002 GC instead of a used one? What would be the price difference between them? Currently he has a sports car with only seating for 2. But he is feels he now wants a back seat and he has had his present car a few years and it will not be worth much unless he turns it in shortly. Is the GC comparable to the Honda CRV or other SUV's or am I talking apples and oranges?
    Why should someone choose the GC?
    We don't recommend posting email addresses on Town Hall; better to mark it "public" in your profile. We can't keep spammers from harvesting emails but it's tougher to get them from the profiles.
    Steve
  • timkansastimkansas Member Posts: 1
    I love the look and drive of the car but keep reading so many bad things about grand cherokees - is this a good car or not??? it would be the first american car i have ever bought. looking at used ML's and QX4's.
  • bigorange30bigorange30 Member Posts: 1,091
    I would highly recommend the QX4 or Pathfinder over the JGC. The QX4 was rated the most reliable vehicle made, in the April 2002 edition of Consumer Reports. That's not just among SUVs but all vehicles. The Nissan Pathfinder LE is just a cheaper (~$2000) version without the personalized service at the delaer and the classier appearnce. The JGC does have better reliability ratings than the ML though.
  • tloke1tloke1 Member Posts: 185
    timkansas, go for the Grand Cherokee, it's a much nicer vehicle. The problems you have read about have mainly been concerning the 1999 redesigned models. Reliability has improved tremendously since then. The 2002 models have been almost flawless, with no major problems reported at all. I have had mine over a year now and it has been perfect. A ton of other 2002 owners have also reported next to zero problems.
    You'll be happier with the GC over the Pathfinder and many other models. Much more power (265hp HO), much nicer looks, more comfortable ride and seats, better sound system, better fit and finish, nicer options and accessories, much better handling in snow and mud, and on and on.
    There is a reason that the Grand Cherokee outsells the Pathfinder, by almost a whopping five to one margin (!!!), it has so much more to offer. For August 2002 the PF was No. 26 on the top-selling SUV list, while the GC was near the top.
    Even the Buick Rendevous out-sold the Pathfinder, that alone should say something!! And the QX4 is not very popular with consumers at all, it's near the bottom of the sales list...IF they were THAT good a LOT more people would be buying them.
  • nikiblue1nikiblue1 Member Posts: 44
    tloke1/ bigorange30.
    Hey guys, you don't quit do you.. Take a deeeeep breath...exhale and rrreeeellllaaaxxx.
    To: timkansas. Go back about 50 posts. You will find a very entertaining comparison of JGC(tloke1) vs QX4(bigorange30) . If you want unbiased opinion go read consumer report for yourself as well as edmunds long history report on JGC problems that are common with JGC and QX4/pathfinders.
    Tloke1: What was that website that gives you list of problems with JGC or QX4/Pathfinder? Let this guy read for himself.
    You should do the research yourself. Here are the TSBs for both.
    http://www.alldata.com/TSB/04/020438EQ.html for the JGC
    and
    http://www.alldata.com/TSB/76/02760111.html for the QX4.
    I would give you the link to the Consumer Reports data but you have to pay the online subscription fee to get into it.
    I did my own research when I made my decision to buy the QX4 in January. Everyone has their own opinions and they are clouded by their past experiences. I would be interested to know what decision you make. I try to be objective and I will concede that the JGC is a very good offroad vehicle. If that's what is most important to you, research will probably tell you to buy the JGC. If reliability is what's most important, research will likely tell you, like it did me, that the QX4 is the way to go. Appearance and styling is enormously subjective but that was the second criteria for me and the QX4 appears about 2 notches more classy than the JGC.
  • sqibsqib Member Posts: 4
    Hi - What an experience - 10 days ago my 1999 Jeep Grand Cherokee Limited with 75,000 miles on it caught on fire while driving on the Highway. Yep - thats right - just cruising down the NJ Turnpike at 60 odd mph the car that I loved so much just caught on FIRE and was completely destroyed.
    It started in the engine compartment and by the time the Fire Department arrived it was too late. It was a charred shell. A truly traumatic experience!!!
    If ANYONE has heard of any such incidents please RESPOND. It is not abnormal for a 3 year old car of this type to do this and other drivers lives should not be at risk like this. My car was not recently touched by any mechanics so there was no malpractice on the part of any other mechanics.
    I intend on getting some answers from Chrysler and will take the time and effort - and $$ - to ensure that other lives are not at risk.
    In the meantime for all the rest of you - - - Go and BUY a Fire Extinguisher and put it in your car - its a small price to pay. Also there is a recall out on over 1 million Jeeps for a potential engine compartment fire in certain models - Recall # B-06. If you have not heard from Chrysler regarding this [just as I had not heard from them] call them with your VIN number and check if your car is part of the recall. Their tel. # is 800 853 1403.
    I look forward to hearing form anyone who can HELP. BE SAFE.
    Thanks - -
    ex-owner of a Grand Cherokee LTD.
    I am sorry to hear about your ordeal and am glad no one was hurt.
    Excellent advice!
    tidester
    SUVs; Aftermarket & Accessories
  • k2rmk2rm Member Posts: 205
    That is quite a story.
    Here is just a shot in the dark. Do you have any aftermarket electrical accessories that might be hooked to your battery? A very common cause of fire in vehicles is improper installation of aftermarket accessories that are hooked directly to your batter. This is especially true with custom car audio components. The problem occurs if the fuse isn't close enough to the battery terminal. If there is a short between the fuse and battery, the wire will overheat and the insulation will ignite, spreading to the battery, and you can probably guess the rest. Anyway, it may be something you want to check into. Usually firefighters can recognize these problems right away.
    How quickly did it happen? I guess you pulled off of the road quickly and got out.
    k2rm: sqib mentioned that there was a recall and he seemed to imply that his problem was covered by it. I would assume that they would not recall and fix something that you added on to it "aftermarket". Investigators are usually very good at determining the cause of a fire too.
    I am glad that DC recognizes the problem and is recalling it. This sounds terrible.
    That recall had nothing to do with fires caused by an electrical short or failure.
    Here's the recall...
    MANIFOLD DEBRIS ACCUMULATION
    Recall Date: 04/15/2002
    NHTSA Campaign ID number: 02V104000
    Potential number of units affected: 1,115,322
    Manufactured: 06/1998 - 03/2002
    Owner notification start date: May, 2002
    Defect: Sport utility vehicles equipped with a 4.0L engine only. The design of the intake and exhaust manifolds could allow debris to accumulate at the #3 cylinder location.
    Consequence: This could result in a vehicle fire.
    Solution: Dealers will install a manifold shield to modify the air flow characteristics and to prevent the accumulation of debris in the area of the #3 cylinder.
    Seems that I and one other person are the only ones having any problems with the transmission noise. Good to know. Please post if you are experiencing problems like those described in message #1377. Thanks
  • leo948leo948 Member Posts: 38
    i've got a '01 ltd, v8, 28k pkg, class IV tow pkg, silver/taupe(?) that i picked up in jan 2001. so far i've logged almost 36k miles and i don't regret the decision at all. of course i had to deal w/the dreaded brake rotor warping @12k miles, and i had to replace the radio under warranty too. my jeep is great in the city (i believe its still got the smallest turn radius of all suv's) and awesome on hwy. all the controls are perfectly placed and handy, the seats are comfy and infinitely adjustable (passengers have said the back is nice as well), fit and finish are very good, and the best feature is that 4.7L v8. 0-60 in <8secs! i'm sure the HO is faster still!
    just my .02
    happy shopping!
    Hi - k2rm good thought on the after market accessories - - well there were no added gadgets in the car - it was a standard Gr. Cherokee Ltd. It appears that it may have been an electrical fire but that is still undetermined - -
    I am still waiting to hear from anyone who may have had a similar problem.
    Thanks for your help - and buy those fire extinguishers!!
    SQIB.
  • deloiddeloid Member Posts: 18
    My JGC 2001 8 cyl vehicle has the usual quirky jeep flaws but this model (my 3rd) does something new that the techs can't solve.
    # 1 cold starting with foot on the brake and with AC off I switch to Reverse to back up. For about 10 seconds there is no engagement of the gear then the force gradually builds.
    #2 Scary problem. Same scenario as above but only three times in 19,000 miles of use. Put vehicle into reverse and immediately there is a rapid acceleration that requires forceful application of the brakes...it literally jumps backward out of the garage.
    Anyone else have this problem or heard of this? Appreciate any help.
    deloid
    My daughter attended a Teen Driving School session at Willow Springs Raceway this weekend.
    Each student drove their own car (one student was the son of a Motor Trend writer and was doing an article). My daughter drove our 2000 JGC Limited. In the emergency evasion stuff, I was really nervous about her rolling it, but the Jeep really controlled quite well. She had the only SUV there, others were Saturn wagon, Acura CL Type S, and a Toyota Camry.
    It was really something to watch her do rapid lane changes and evasions at close to 50 with very little lean.
    -Paul
  • jeepenvyjeepenvy Member Posts: 4
    Hello everyone,
    I'm looking to upgrade from a 96 GC to a 2002 GCL. I've noticed the price on the Chrysler service contract has sky-rocketed over the past couple years (I'm sure to compensate for the problems with the 99s).
    Anyway, I was wondering if anyone has extended their contract once it hit the expiration. I'm considering going with the 5yr/75,000 because it saves me about $1000. I'm curious what Chrysler will want to extend at the end of the 5/75.
    Any info would be appreciated.
  • gonzoe119gonzoe119 Member Posts: 2
    I just traded my 99 Laredo for a 2002 Limited V8. WOW, what a difference! My 99 came standard with the cargo net and cross bars on my roof rack, my 2002 did not. Is this true, or is the dealer holding back on me?
    I just purchased an '02 Overland 6 weeks ago and had to buy the cross rails and cargo net separately.
    It's a new trend called "decontenting." Helps then keep their MSRP in line with the competition by eliminating some of the lesser features.
    You've probably already noticed they eliminated the pinstripes, woodgrain trim piece on the ashtray, etc. Several small items like that.
    I ordered my 02 Ltd with more equipment than my 99 Ltd had. The 02's MSRP was a little over $2K less than the 99's. For that kind of savings, they can go ahead and trim a little fat.
    I knew this ahead of time so I took the cargo net out of my 99 before I traded it in... hehehe.
