"You may return Your Vehicle to us along with the title and any other required papers and pay us a disposition charge of $275 and any other charges for excess wear and tear and for excess mileage...You agree to give us 30 days written notice before the due date and to arrange a conveninet time and place for us or our agent to inspect the vehicle..."
I am still involved in the Lemon Law process, but I took this to mean that I can return the vehicle at any time with 30 days notice and a $275 fee.
2005 Grand Cherokee Limited
5.7 Hemi Engine
GPS
DVD Entertainment System
Trailer Package
Supp Side Air Bags
Sirius Sat Radio
Package 25K
What do you all think, a good deal? This does include a military rebate of $500. Car has 37 miles. Thanks.
"in some regions some manufacturers may make adjustments to their prices, for example by adding a required advertising fee, which can affect both the invoice price and the MSRP for the affected vehicles. Edmunds only publishes national prices and does not attempt to track these regional variations."
It's pretty funny that Jeeps wants to bill you for sending you mail. The ad fees, even if legit, are just sad.
As always, focus on the out the door price and you won't have to waste time negotiating the line items like these.
I did the trip once using a Toyota Camry (192 Horsepower) and found that I could not use the cruise control on I-40 because the transmission kept going out of overdrive. Thus I found myself reving to 4000 rpm and getting 12 mpg. Yes - I know it was dumb to tow with a camry.
Since the JGC with I6 is only rated at 195 HP and 230 ft lbs of torque, will I experience the same issue of not being able to use the cruise control? Does the vehicle need to be prep'ed with a larger radiator and a transmission cooler? What else would need to be done in order to tow with this vehicle?
Should I keep looking for a vehicle with more HP and torque?
http://community.webshots.com/album/548697188kmhzhY/0
Top 10 2006 4WD Vehicles for Off-Highway Use
I cannot understand why all you hear in these columns is complaints.
In fact, that is not all you hear. However, someone experiencing problems is much more likely to go out and seek help than someone who's not experiencing problems.
The owners manual on page 202 shows a passenger side kick panel for these fuses but it doesn't exist on my jeep. I found the power distribution under the hood but the manual doesn't specify anything for this power outlet fuse. ???
:confuse:
Anybody know where its at?
A picture or link would be great if you have one.
I'm an 01 Grand Cherokee owner, have been for 3 years. Huge fan of Chip Foose. Getting bored and decided to do some radial stuff, like Airaid throttle body 1" spacer, Jet proformance Chip. got a ton more HP, well not a ton, but considerable improvment. Instaleld an ACDC adapter and installed a mini PC w/ a 10" touch screen for NAV and anything you can imagine you can install on a PC. Have it hooked into my Kenwood multi in head unit. Working right now on a new design for hte dash, bought a huge piece of alumimium, doing a mock up in cardboard of course...Looking for ideas as far as boring out he pistons to get just a little more HP, or should I leave well enough alone here? Or just go get a Hemi to replace my soon to be burned out at he rate I'm going 242 in line V6?
Cheers
Which would be better?
Is there a lot of difference in the gas mileage?
Is there anything I should know about this model?
Thanks in advance for your responses.
Patty
the problem i am having with the above is that when the car is doing 50 to 60 and is in final drive with the torque converter fully locked there is a deep throbbing noise from the trans and it gets louder the more throttle you give it. any one out there know what it might be my local jeep dealer in the uk wants lots of money to rebuild the transfare box but is not 100% sure that will fix it can you help many thanks cliff.
Or do you want to look again and see if it isn't an I block 6?
Wanted to share two issues I have been having with my Jeep for the dealership cant seem to figure out the root cause.
1. At times when I go to "floor it"...the RPMS go bezerk and start revving for no reason and its almost like the engine is about to die, or the trans shifts to neutral or something. Not a mechanic to describe in tech terms. Basically...hit the gas and I dont go any faster momentarily and its scarry. Dont want to make any bold moves on road now in fear that the 2-5 sec I have no power...will end up in a major accident.
2. From a cold start, when I turn the ignition on..its almost like its going to stall. It has only actually stalled on one occasion, and I am wondering if this issue is in relation to the one described above. Just a hunch.
Feedback much appreciated thanks!
Anyway, I've basically narrowed my search to Jeep or Explorer, and currently am looking at a 1994 JGC with recently rebuilt transmission, 166K, new tires, new front brake pads, engine work done to replace valve seals (?), one owner salesman, "test driven" all last winter by a friend who recommends it but needs to sell it (already owns 7 vehicles). Only "quirk" known is back driver side window doesn't work - not the motor. Asking $3,000 more or less....Is this a good deal???
In comparison, looking at a 1997 Ford Explorer Eddie Bauer, maintenance records available, 106K, $5,500 OBO. No other details known.
Either one seems to give the flexibility for cargo room and road safety (we hope to go on road trips - no real off road but camping, parks, etc), but the cost vs the mileage and age - -
Does anyone have any opinions from owning both of these vehicles? Any years to avoid? Any specific questions to ask?
The JGC w/166k miles is a little on the high side, but I've heard and seen people crank out 200k++ out of these things. Here would be some of the things to look for on the Jeep:
If 4WD, make sure that the transfer case has been serviced and the fluid in both the transmission and rear-end have been changed. The transfer cases for these things can run into the thousands.
Some early model(93-95) models experienced electrical probs, so I'd take a well knowledgeable mechanic along for reassurance.
As for the Explorer:
I know it's an EB with all of the luxury comforts, but most '95-'97 Explorer EB's were sold with the V-8/AWD set-up and these were the most problematic models. The automatic suspension had numerous problems. And if it's a 5.0L V-8, STEER CLEAR. You may as well purchase an Expedition as the fuel mileage on this model is comparable to the bigger ute's(the 5.2L V-8 Jeep doesn't fair much better). Figure something like 12 mpg for both.
I had both of these vehicle's ('95 JGC Limited and '97 Explorer Eddie Bauer 4WD) and both served me quite well. The Explorer was a bit(not much tho) easier to maintain, but the Jeep had a better ride and an overall more luxurious feel.
In closing, as xscout said. Please get a carfax. I know your time and money means even more to you now, and there are people out there scamming left and right. And I do feel that both of those asking prices are a little on the high side, especially the Jeep. They do have good resale values, but not this good for a 13 year old SUV with close to 170k on the clock. The $25 carfax report will save you from spending mega bucks to repair these complex autos.
please help
thanx :confuse:
Good luck
Bill
I'm trying to determine whether a 2002 4.0L JGC can safely tow a 5000 lb trailer for 1800 miles (GA to AZ) with just a class III hitch (doesn't have the full towing package). Any comments/suggestions are welcome
-Frank
