MB's normal mode of operandi when you step on the gas pedal is to ask the driver - "...is this what you really want?" - and then if you do not let off, - "oh, okay, there you go..." I wish I could turn this darn "feature" off!
From what you are describing, this is exactly what is happening. Someone mentioned that first they experience hesitation, then they step on the gas and the truck takes off - more gas when MB finally decides to shove off would do that. Another guy/gal said that this only happens in the morning and then goes away. Well, tranny gets trained really fast. I bet you have different driving patterns morning to evening.
Oh, and more thing about idling at stop lights... Or, maybe not. I do not feel like getting into another protracted war'o'words with Drew. Haya doing, buddy? BTW, I'm just passing through... It must be a real pain setting the foot brake and then grasping for that damn release handle when the light turns - safety hazard if I ever heard one. Handbrake I can understand, but foot...
Has anyone else had any problems? My wife can't stand driving the truck now, it's just too hot! I'm giving them one more shot. My fear is that this is why the original owner only had the car 9 months, not just because they had 55 on order, unfortunately, I'm sure I don't have a lot of recourse now, other than to fight with MBUSA.
Thanks for any and all help.
been inadequate. I've had it checked out several times to no avail ("normal functioning"). The air coming out of the vents is fairly cool, about 45-50 degrees, but only when both selectors are on recirculate. It just doesn't cool the interior enough. One tech attributed it to an inadequate vaparator coil, fan capacity, and the colors or the interior and exterior. And yes, I've checked fuse #44. Poorest a/c I've ever had on any vehicle by far. later, ldf
Nah, not a problem. There is usually more than enough time before people start moving off. Not only this, but I don't always apply the parking brake either. I just step on the brake as normal. It's only the long traffic lights (30 seconds and more) that I shift into neutral and apply the parking brake. If I do apply the parking brake, I usually release it ahead of time, just before the light turns green. It's pretty easy since you just watch the other light going amber. Obviously I only do this in places that I am familar with and know roughly how long the lights last. On a short traffic stop, there's not much point shifting back and forth so I just idle as normal
Drew
My 98 ML320 hesistated when I tried to start it today. It would just turn and turn but not start. I tried at least 5 times, then let it sit. Ten minutes later (holding for roadside), I tried it again. The engine turned for 4 or 5 seconds until it finally turned over. It drove perfectly fine, and now it's starting normally. What could this have been? This never happened before, nor have we had any problems with it aside from minor things (trip computer, etc.). Later.
Todd
That's what I was thinking...ugh. Never had it replaced before...and never had this happen before. Like I said before, it was driving and starting perfectly fine right after.
I'm taking a trip up to school (3 1/2 hours) on Wednesday...is that advisable??? Thanks...
-Todd
Wolfgang has a section of his website devoted to this issue:
http://www.whnet.com/4x4/badgas.html
Good luck and let us know how it turns out! Meanwhile, book an appointment ASAP and tell them what's wrong. perhaps they'll be able to squeeze you in ahead of time?
Drew
Just purchased a 01 ml430 two months ago. Have been attempting to read all 4K plus post. In reading the last weeks post today, on a business trip last week, I wanted to share my experience so far.
'O1 ml430, M3 Convenience Package, Sunroof, Bose - 2K under MSRP (Bay Area pricing is high), Black/Charcoal - 1500 miles
Hesitation - I have only noticed a slight hesitation when rolling to a stop then accelerating again. I believe, and was told by my SA, this is due to the tranny having a slight delay switching from second gear back to first.
Gas mileage - 60% freeway/40% city traffic - 17.5 mpg
Sunroof cover - delivered off track. Fixed by MB
Shaking over 65 mph - Fixed by MB, wheels balance and alignment done.
Drew and Kenyee - Like reading your post, very informative.
Love my ML...later
Just a reminder that the MB chat is on tonight (6-7pm Pacific/9-10 pm Eastern). Hope to see you there!
http://www.edmunds.com/chat/mercedeschat.html
We decided not to risk it, and we brought our 98 ML320 to the dealership today. Despite a two-week wait for a service appointment, they took our ML right away (Mercedes Benz of Nanuet NY) for the fuel pump update. I assume they're putting in a 2001 model pump. Thanks for your help Drew. I'll keep you posted. Later.
Todd
Drew
also any opinios on brush guards, and side steps. any one use the cobra-sor ones.
thank u for response my fellow MLvenites.
Fuel pump and sender assembly versions
163-470-01-94 fuel pump and sender assembly factory installed from 7/97 to 9/99
163-470-10-94 second version
163-470-11-94 second version, including tank seal, starting about 1/00
Drew
There is a trick to getting out without the side step soiling your pant leg, and that is simply to step on them before you step onto the ground. Don't try to step over them, but on them first.
Just another question...when I brought my ML to my dealer to get the fuel pump replaced, the technician said it needs new brakes. It's a 1998 ML320, but it only has 24500 miles on it. Is this necessary? My parents want the replace the brakes when the brake warning light illuminates on the dash. I'm not too thrilled with that, but it's their car and their money. What's your take on this? Thanks. Later.
Todd
Are you saying that all ML should have the new fuel pump installed?
I have a '99 320 with 31k and have not experienced any of the problems noted in other posts.
I have a service appointment for an oil change next week to install the synthetic stuff.
I had the oil routinely changed at 4-5k previously and the service mgr. said if there are no wrenches depicted at the FSS no other service is needed at this time.
I will mention the fuel pump update if you think it is warranted.
thanks.
3 weeks ago, I had problem to start the car (ML320 MY2000), similar to your situation. And dealer replaced fuel pump and fuel filter. One week later, the same problem reoccured. Dealer ran the diagnostic and found no error code in computer. SA told me this could be caused by heavy key chain and stuffs, the weight put on the key could cut the signal from the chip (in the key) to computer, and computer would shut off the fuel. I've detached the key from key chain, and there is no further problem so far.
Ed
I have had a lot of problems with this vehicle, and this is like the straw that breaks the camel's back. I can't believe that MB wouldn't stand up for what is obviously a defective seat when there is still a year left in the four year warranty period, even though it is past 50K miles. I'm sure the seat was cracking before the 50K was up, I just didn't look at it.
Does anybody have any suggestions as to how to deal with this? I've been through three gas tank sensors, a major gas leak, ignition lock failure, rattles, bangs, and squeaks, etc. And through it all I still love (and hate) this car.
Jeff
Anyway, they called to tell me that the tires need replacing. The car only has 21,000 miles on it--is this normal? The tires are the Dunlops. I was bummed to find out that brake pads are not covered under the "free maintenance".
The service rep said the tech told her the wind noise was due to the tires. I told her I doubt it, since the noise was there from day one. Guess they are going to tell me I just have to live with it.
I had to laugh, the service rep. passed on that the tech said my brake pads were dangerously low (a verbal rap on the knuckles). I told her I wasn't surprised considering I had called to make the appointment for the brakes JUNE 20th and they weren't being worked on until today. She changed the topic real fast.
Sharon
Hope it helps.
Peter
I'd suggest writing a certified letter detailing all your problems to mbusa.
With luck, they'll suggest exchanging your 1999 for a MY2000 that may still be on the lot.
sharon:
It's a little abnormal to switch tires that fast. Have you verified they are down to the tread wear indicators yourself? They should wear that fast only if you do lots of off-roading or push it hard through curves or your alignment is off and you didn't rotate the tires.
Folks on the m-class list have gotten 40-50K+ on the tires.
MY2000 ML320
The car is still in the shop, so I haven't been able to verify it. I did call back and they told me that it is not unusual for SUVs to go through tires that quickly. I'll wait until I get it home and get a second opinion. I have taken a few trips to NH (from NJ) since I've had the car--but it's been all highway driving.
I certainly hope I don't have to replace both the tires and the brakes every 21k miles!!
Sharon--stir crazy with 3 young boys and no car for 2 days!!
I haven't rotated the tires since I thought the MB service plan would cover that when needed. Whether the tires were rotated or not, they still should be in decent shape at 15K miles.
I'm taking the ML in this weekend for dealer evaluation/service. My concern is that I'll have to pay for an alignment and two new tires! Has anyone else encountered a similar situation? Curt Rich stated in his newsletter that ML tires should wear like stainless steel. Does anyone else think that 15K miles is too early to be needing new tires on an ML? Does anyone have any suggestions for getting MB to cover this under the cars warranty?
I am driving Michelin Cross Terrains now. They are very quiet and I really like them. (But they are expensive.)
Jeff
To the person who was asking about snow tires, I put Michelin 4x4 alpins on last winter, excellent performance and very quiet.
To the person that was wondering about 3rd row seats, great for kids (though awkward for some car seats) and short trips for adults, and they go in/out easily. Email for more details if you want.
regards
Rob Dingwall
00 ml320 blk opal
Kimo
I'm confused as to what your service advisor said. In the FSS, it either shows one or two wrenches. One wrench = service A, and two = service B. AFAIK, it's always one or the other. These services involve more than just an oil/filter change, BTW.
Regarding the plastic panel, my ML hasn't had that problem yet, but a drastic temperature change would make any plastic crack. See my message to Glenn above.
Brake pads are wear and tear, just like tires, so it's not considered normal maintenance. Canadian MB vehicles from MY2000 onwards don't have a 4 year free maintenance plan, but we do get a two year wear and tear warranty where brake pads/rotors, wiper blades, etc. are covered. FWIW, I have only about 22K kilometres (about 14K miles) on the odometer, and my pads will require changing soon. Living on a mountain no doubt contributes to this, but since the ML's brakes are excellent, I have no complaints.
My Dunlop Grandtreks still have plenty of tread on them and I have rotated them 3 times already, at about 6000-6500 kilometre intervals.
Welcome back! It has been a while since we last heard from you. It is very odd that the insides of the tires would be worn excessively and it does indicate an alignment problem. Perhaps if you explain to them what you just did to us, they would be willing to do it as a goodwill repair?
Please keep us updated.
Drew
There is no official TSB for the MCS bright/dim DRL fix for our Canadian MLs. However, I did get mine done after some excellent advice from a couple of fellow Canadian Town Hall ML owners. The result is that even with parking lights on, the screen does not dim; it only dims when the headlamps are turned on.
