Visitor Agreement.
Jason
Robert
Is the gas tank cover on the AMG ML55 the same as all the other ML's. Coming back from church today I parked next to a ML55 and it had a chrome gas tank cover. It looks like the same one on the Mitsubishi Eclipse
It is a circle with chrome cover, and chrome screws or rivets on the outer cover edge. The guy said that that is how the ML55 came, but it doesnt seem like it does. Its not typical of MB to put something as flashy as that. Not even our CLK55 has a tank like that. Looked kind of out of place.
Robert
The chrome tip on your ML looks good. What size does one need and where did you get yours from. Tried K-mart they do not seem to carry any.
Dave gill
dt77
It's been tried. Someone on the M-Class list long ago tried to get one into his 1998 ML; he had to put one of the spare keys in the ML. I think someone on this forum long ago was successful as well. The problem is that most of today's cars come w/ a "smart" key. The key transmits a code to the ML before the ML will start. Makes it hard to steal, but almost impossible to add a remote start to.
atomic80:
What are you using to wash you ML? Sand? ;-)
I haven't had the paint chip from washing yet, but I haven't been able to give it a full hand wash since my week of Zaino. The weather here has been totally crappy and it's coated w/ salt and dirt and it's too cold to wash it off (8 degrees F this morning)-:
My ML55 doesn't have a chrome cover like that....I think that guy was pulling your leg too. I wouldn't want something like that to begin with too...too gaudy for my taste.
Ken:
Others have said how soft the clearcoat was on the ML so I was concerned about that. And it isn't that cold over here...I still don't know why you guys are getting all the cool stuff! No snow here yet to play with!
Jason
Yes I thought that this is more of a japanese type add-on. I knew he probably lied to me but I never looked at the gas cap specifically on other ML55s.
robert
dt77
I have the stongard and bug delfector on the front so I haven't gotten any chips up there but I have gotten quite a few chips (4 at last count) on the rear hatch area. I"m thinking that the rocks that get kicked up by the tires may have had something to do with those chips. What do you think? You may want to check your hatch for signs of any chips. Maybe I should get a mud flap but I've heard from others that it won't fit the ML55.
Jason
That's a weird place to get chips. I have the mud flaps, but the vacuum created by the ML's mass has been sucking up salt/dirt and dropping it on the back hatch (including under the hatch handle!!!)-: I did notice what looked like a paint chip on the roof when I waxed it.
I'll have to check when I wash it next week. Have to do it soon. Some weenie decided that it would be fun to do graffiti on the dirt on my windows and tried doing it on my painted areas (and no doubt grinding the dirt into the paint), too :-P
The mud flap won't fit the ML55 w/o serious cutting. You might want to see if you can trim a generic mud flap to fit, but it won't look as good as the MB ones. MB is supposedly redesigning a bull bar and side steps for the ML55 and ML Sport by this summer, so let's hope they redesign flaps as well (and in rubber instead of the horribly hard plastic it is now).
My theory is that the metallic clear coated paints seem to hold up much better than the solid colors. I had a black one and the paint seem to kinda flake when hit with a rock or something. I now have silver and it is holding up much better. Still get some chips in weird places.
BTW, when I see large trucks or anything that has debris that may kick out, I stay way clear, sometimes getting off the freeway to avoid the trucks load with junk.
Thanks again,
Pete
In the process of dismantling many trim pieces, we discovered the extent of the improvement in sound dampening/insulation (not to mention the huge improvement in the quality of the plastics) everywhere for MY2K MLs. Nearly every cavity that we opened was filled with a combination of sound dampening foam, thick carpetting and rubber seals. Even the rubber mouldings around the tailgate hatch were filled with (tough to cut) metal loops and fibres.The only bad thing about this was that it was considerably more difficult to push the Parkpilot wiring around.
The P.P display/beeper unit was installed in the 3rd row seatbelt cutout area primarily because it was in the same line of sight as the stick-on convex mirror, as well as the fact that it was one of the easiest spots to wire in. I could've cut into the plastic trim for a more integrated look, but this would've required removing a large plastic piece (holding the headliner) and I didn't want to mess with that. Not only this, but I was scared off by the difficult drilling in the bumper + I didn't have the right size (30mm) bit :-)
I'll be uploading a lot more pictures in a seperate album soon, but for now, here are a few more:
Enjoy!
Gary, MB also sells them for the E-class sedan/wagon, so you may want to have a look at that too. If it's not on the www.clariparts.com homepage, try contacting them by e-mail or phone. Since they are a MB dealer, they can get can any MB parts.
WRT the chrome tip, I used a 2 3/4" generic chrome tip from Canadian Tire and rotated the other way around. There's plenty of room for expansion; it's held it by a screw on the top - not obvious unless you bend down and look at the rear bumper level.
Here are a couple of pictures of the weird ART Germany triple beam headlamps. I wonder where the front turn signals are?:
What are you washing your ML with? I hope it's not a cloth or a spomge. I haven't noticed any paint chips on my rear hatch, but I did have a very small chip just below the pop-out quarter window a several months ago. The service tech. touched it up for me and it's just about invisible now.
Drew
Edmunds.com Townhall co-host
Vans and Aftermarket & Accessories conferences
What are you washing your ML with? I hope it's not a cloth or a spomge. I haven't noticed any paint chips on my rear hatch, but I did have a very small chip just below the pop-out quarter window a several months ago. The service tech. touched it up for me and it's just about invisible now. It's probably the wide tires of your ML55 that are kicking up a lot more debris.
Drew
With 4 sensors, it coves quite a wide range behind the vehicle and a certain extent to the sides. For example, like the Parktronic system, it detects the door frames of the garage door and gives me a visual warning (no audio) while backing up of the garage. Also like the Parktronic system, accuracy is decreased a little on slopes. It occasionally beeps once while backing down my sloped driveway, not a big deal. FYI, it can detect chain link fences despite there being not much surface area.
Drew
Yes I am worried about coming back to a sticky ML. At least my floor will be clean, when it explodes and melts !!! I cant ask any one to check the ML because no one can get into my garage nor into my ML because I have the place so well locked down, and hid the keys for the ML.
The weather in ORD is below freezing, here in LAS it is about 50-60.
UhhhhhhOHHHHHHHH
Robert
I forgot to mention the rear spoiler. If your paint chips are caused by the same vacuum that is depositing all sorts of dirt on my hatch, the rear spoiler may help you according to all the positive things I've read about it.
rich96:
What did you do w/ your old MB cargo tray? Want to sell it? :-)
You may want to try installing it backwards first. The high part will face the back and will offer the hatch some protection from cargo.
I guess I could have installed it backwards, but the MB cargo tray went back in the box and is now stored in the basement. Do you really want to buy it? Are you in the Boston area?
Rich
Yep, I'm in the Boston area (in the South End). If it's the all-weather tray w/ the compartments, I'd like to know what you'd like to sell it for?
Check your email.
Rich
Drew
The ML is now average or close to average in reliability.
I will be very honest, you will have far more problems with a GM or Ford then you ever will with the ML, believe me. I too was concerned after reading the CR article but in talking to current owners I realized they were start up problems. Not once did I hear of any major driveline problems, only cosmetic issues for all the years.
To help you understand a little better I normally get bored and swap every year or two and start looking usually after 4 - 6 months for something else to get and customize. I have had no such thoughts with the ML and really think I'll be keeping it 4-5 years.
I have stupid question, the Bose stereo system on 2001 ML430, says that it is Six Speakers with a Sub woofer. I know the sub woofer is under the passenger seat.
I only see 4 speakers (1 on each door), so where are the remaining 2 speakers?
My dealer claims that there are 2 speakers on each door with one opening but that would work out to 8 speaker system.
Please help.
2001, ML430 (Red with Java Interior, M6, M7, Bose, Sunroof) with 1800 miles in one month and doing well except for the left mirror shakes on highway. Very little rattle from the rear and seems to be from the panel that covers the opening (foot well) between the back and rear seat (clattering up and down when on going on rough road). Anyway to solve it?
Mileage, just averaging around 15 Highway/city. Plan to drive to Tahoe this weekend and will see what kind of mileage I get on full highway driving.
Thanks guys
I looked in the 2001 brochure, and on page 13 there is an illustration that shows two speakers coming out of each of the front doors. I'm sure that one of them is a tweeter. Also, the subwoofer is under the driver's seat.
Rich
As an aside, I am still happy for getting the ML430 over the 320..the torque is great..memories of my 540.
Cheers!
I've been to the dealership 1x for a I front turn signal bulb, now in the shop for an Oil change (I transferred to synthetic oil and pumpkins after 1K)
MPG average 20 in town/highway I usually average 21@ 73MPH in Central Florida
Mike
Are you sure you get 20mpg in town? I'm averaging 14-15 :-(
Do you have any stoplights in town? ;-)
Went to the dealer and picked up the 2001 brochure and yes, it does show that there are 2 speakers in each of the front door. Also spoke to the mechanic.
Thanks a lot.
What kind of MPG are you getting?
Does your Navigation system show wrong direction and longer routes too, is some cases?
Thanks again.
..Ramesh
As for the navigation system, don't have one.
I'm no slow poke but I do not race to the turning Red light and wait there.
I'll take better notice in a just in town situation most of my driving is on secondary roads, few stops and when I need to slow down for a light, I shift down to a stop. In town only I would estimate 17-18 MPG Never using the computer as the source of information shared!
Cruise control is used all the time.
On the mileage issue, I have 11,500 on mine and get around 14/15 around town and 19/20 on trips.
