Visitor Agreement.
We all learn in a car with a clutch and gears; because if you pass your test in an automatic, that's all you're allowed to drive.
You know when you have reached the biting point, because the bonnet rises slightly.
There is a GOOD reason to PROPERLY and GENTLY downshift while slowing: in the event you need to accelerate quickly - to avoid an accident like a rear ender - you are in the best gear to do so; unlike an automatic that will, after a pause, select the correct gear for you. Downshifting as you deccelerate is an absolute must when riding a motorcycle.
My LIFE is more valuable than a clutch repair. And for midsouthmitch, I mean shifting AS my speed drops via braking, not down-shifting to CAUSE my speed to drop.
I am surprised that this article didn't cover a REAL myth: manufacturers are claiming that automatics get better fuel economy than manuals - perhaps so if the driver doesn't know how to drive a manual - I always BEAT the EPA figures for both auto and manual when driving a manual, and the automatics don't come close to the claims.
It is a shame that for some classes of cars and truck, only a foreign make still comes with a manual. What a lazy society when people can't/won't learn to drive a manual.
Looking at this the biggest thing missed is shifting without the clutch. The only time the clutch is used is for stopping and starting.
If you are burning out a clutch a lot, there is a problem with your clutch (unless you ride the clutch a lot). I had a 1975 Toyota Corrola that went through clutches like water. It had a silly 5 bladed fan type clutch. I changed it with a pickup truck clutch and never a problem after that. For 25 years it took everything I could throw at it. Then the body rotted out. Lucky I live Hawaii.
RPM matching is for shifting without the clutch. If you are jerking when you shift then your rpm wasn't matched, with or without the clutch.
This article proves that your job title does not make you an expert.
(Actually, it's getting harder to find any compact station wagons any more that are truly station wagons and not those accursed 'crossover' things. There was the Ford Focus wagon; and the HHR, which I wanted to buy but it was discontinued. Compact station wagons are the perfect combination of small on the outside and big on the inside, for carrying moderately large cargo.)
_ That's the real problem with why so many drivers of manual transmissions wear out the clutch trying not to roll backwards on an incline while they engage the clutch. It would not be such a big problem except for the ignorant drivers who pull up way too close to a car that is both ahead of them and ABOVE them. It's almost like they're unaware of how gravity works.
I got 198,000 out of a Toyota and clutch and trans were still good. Scrapped because needed total brake system @ $1500+.
Here's probably the best race car driver ever, showing how to heel and toe in a NSX..
How does this relate to myth #3?
Rev-matching isn't rocket science - it was the only way to downshift properly into first gear before transmissions were full synchromesh.
I understand they may stop making them soon, so I need to buy a quality car with MT soon and hope I can keep getting it rebuilt until I am too old to drive. However I expect BMW and others will be making them for a long time, so I may end up a elderly lady driving a high performance car!!
Yes it's very easy once you learn your car the shift pretty much undetectably. I've had passengers in the back that didn't even realize my car was a manual until they finally noticed my arm moving or got on it with a few quick shifts getting onto the highway. Even then a few didn't notice, quick doesn't have to be jerky either. Once you learn your car you don't even really have to put any thought into being smooth, it just kind of happens with muscle memory.
One flawed criticism of downshifting is that it is detrimental to your drivetrain. This is entirely false (when executed properly). Downshifting to use your engine's retarding forces is actually LESS strenuous on your vehicle than simply accelerating from a dead stop. You see, when accelerating, your engine is overcoming the forces of gravity, rolling resistance, etc. entirely on its own. When downshifting, your engine is working WITH those forces. Note that I don't mean to shift to 6,000 RPM every time you select a lower gear; I like to stay between 2,500 and 3,300 RPM. Another benefit of keeping your car in gear is quite simple: it keeps your engine spinning fast enough to more comfortably perform all of the tasks it needs to perform (running a/c condensers, maintaining pressure in all hydraulic systems, running the alternator to charge the battery and keep your electrical systems electrified), and on top of that it keeps the oil moving freely about your engine.
In fact, most automatic transmissions of our current lineups are programmed to downshift during deceleration or hill descent. One of my cars is an Accord Crosstour with a V6 and the 5 spd AT will downshift to third gear at 65 mph on a steep hill if I apply the brakes (that's around 4k on the tach).
Wrong, a clutch by far is cheaper to replace than a automatic transmissions torque converter ( for most cars anyway. )
It cost estimated 100-200 dollars for a OEM clutch ( not aftermarket. ) And another 20 dollars or more for a axle nut so the axles can be removed from the transmission, this is EVEN easier if you own a rear wheel drive, since most worries is just the trans-axle from the front to rear. Learn to do it yourself, dealerships / mechanics will stick it to you if you allow them to do it, most cars at max, a 18 hour job. Even at 20 dollars an hour of labor ( which is way up there. ) It cost 360 in labor, and maybe at max 300 in parts. Stop getting [non-permissible content removed], do it yourself, you went as far as buying a manual rather than a automatic, learn your vehicle.
Lol stupid article
