2005 Mercedes-Benz CL65 AMG Long-Term Road Test
edited September 2014 in Mercedes-Benz
image2005 Mercedes-Benz CL65 AMG Long-Term Road Test
Our twin-turbo V12-powered long-term 2005 Mercedes CL65 AMG is using oil. About a quart every 1,000 miles.
  • throwbackthrowback Member Posts: 445
    is the V12 knonw for using oil? This seems excessive even for a rotary! Former Rx-7 owner here.
  • gtulleygtulley Member Posts: 5
    There has to be something wrong with the sensor. My oil level hasnt budged in 4000 miles.
  • greenponygreenpony Member Posts: 531
    "Remember, this Mercedes does not have a dipstick." . . . . Except the driver! ;)
  • miata52miata52 Member Posts: 114
    Definitely a lot of oil for a 4 or 6 banger, but maybe the 12 burns a lot more. Anybody know?
    Did they check the level, which has to be done with the engine off, instead of taking a pic while doing 60mph somewhere potentially getting a bogus message?? This engine does not burn that amount of oil. Something is amiss.
  • mercedesfanmercedesfan Member Posts: 365
    I wrote this in the last oil post, but these early M275-equipped AMGs burn a LOT of oil. Owner forums report standard consumption of about 1 quart every 1500 miles.
  • diigiidiigii Member Posts: 156
    Not only is it a gaz guzzler, but an oil guzzler too.
  • miedenmieden Member Posts: 75
    This thing is drinking a LOT of oil. Ive seen M275s consume a qt every 2-3K, but this does seem excessive. Ive heard of them drinking this much, just never seen it. A 16-year-old must have broken this motor in...
  • ayaoayao Member Posts: 27
    FYI you can get a 5 quart jug of the M1 0W-40 at Wal-Mart for < $30, the same cost as all the other M1 grades.
  • iloveyogapantsiloveyogapants Member Posts: 20
    Correction: "Remember, this Mercedes does not have a dipstick." . . . . Except the OWNER!" :)
    Surprised they haven't drained it and measured the amount...sounds like a fun project for the crew.
  • gslippygslippy Member Posts: 514
    The dealer will inevitably tell you this sort of oil consumption is normal. The VW dealer told me the same thing when my 02 30V V6 Passat was burning oil every 1000 miles, and it only had 30k on it. You're out of luck. Who builds an engine without a dipstick? If you blow it up due to overfilling, M-B won't help you.
  • barich1barich1 Member Posts: 143
    At this rate, why even bother changing the oil, just change the filter occasionally.
  • expensivehobbyexpensivehobby Member Posts: 91
    Upon reading this, I just thought to myself how a private purchaser would deal with this? "Car drinks oil at a near-incredible rate, but maybe some expensive sensor is the problem and I'm drowning my crankcase in oil. And I already have spent a bunch of money on the hydraulic and other symptoms, and I've put 6,000 miles on it. Oh, and this one came from the Mercedes dealer, not some fly-by-night or a private seller trying to unload it." I don't know if it would be yet, but at some point not far off I'd envision a private owner dumping the car.
