2013 Volkswagen Passat TDI Long-Term Road Test
edited September 2014 in Volkswagen
  • fordson1fordson1 Unconfirmed Posts: 1,512
    Did your Google searches lead you to the fact that the RNS510 is a lot older than the RNS315?
  • expensivehobbyexpensivehobby Member Posts: 91
    My salesperson quietly suggested that I avoid either nav system, as their operation was a bit "clunky".
  • quadricyclequadricycle Member Posts: 827
    fordson1, two months ago: "The Passat uses the RNS-510; the others use the RNS-310. The 310 lacks some of the features of the older 510 but it's much faster and the BT integration is way better."
  • jwp55jwp55 Member Posts: 1
    I have a 2013 tdi sel and the nav/radio is by far my biggest complaint. The processing time is way too slow.
  • alohajohnnyalohajohnny Member Posts: 1
    Do after-market double-DIN options exist to replace the factory nav/radio/rear-view with something else?
