Three Cylinder Engine - 2014 Mini Cooper Hardtop Long-Term Road Test
 Edmunds.com
Edmunds.com
Edmunds conducts a long-term test of a 2014 Mini Cooper and we share our impressions of its three-cylinder turbocharged engine.
As for the A.S.S. system, mine's deactivated. It's too rough, but worse still, it's flawed. I may try it again once there's a software patch available in December, but it's cause stalling too many times, in scary ways (I have a manual). Since turning it off, I have had zero stalling issues, and life with this car has been easy-breezy.
As for "twin power"---clever marketing. Actually real twin-turbos are best suited to V engines, and IMO, to engines with higher displacement.
"Both engines share technology with the rest of the BMW turbocharged engine family. TwinPower turbo technology is BMW-speak for a single, twin-scroll turbocharger.
Read more: http://www.motortrend.com/future/future_vehicles/1309_2015_mini_cooper_s_motors_see_upgrades/#ixzz3Fg1bJaBP
Which, if you think about it, makes sense -- twin-scroll turbos and three-cyl engines are essentially incompatible.
Upon further research, I think I see the answer now, so I apologize. The uneven # of cylinders results in the inability to evenly split exhaust gases into separate scrolls-is that correct?
http://en.wikipedia.org/wiki/BMW_B38
"The BMW B38 is a DOHC 1.5 litre 3 cylinder petrol engine with a mono-scroll turbocharger and an 11:1 compression ratio. It is the first use of BMW's modular engine strategy all using the same 500cc cylinders."
A comparison of the BMW turbo 3 and Ford's turbo 3 would be very interesting. Ford, surprisingly, has gotten very good at making turbocharged engines.
So this 3 cylinder technology is marching.
