Hard for us to hear the noise of course. Wheel bearings are more like a "ball-sy rumble". If the noise were higher pitched, like a siren, then more likely ring and pinion and usually make noise only on "pull".
Answers
just had fuel pump replaced not that at higher speeds can hear it less
One test---let off the gas--is the noise still there?
tires are new and not feathering must be wheel bearing.
