I just bought an $800 death trap and it's going to cost $800 to fix it. Toyota Corolla.
so, I bought THIS 1990 COROLLA and the seller lost the power steering fluid cap and stuffed a rag in it... Didn't notice anything wrong when test driving, but on the way home when I got up to 60MPH, I would turn the wheel but the car wouldn't turn... It was terrifying. I almost died twice.
Took it to a mechanic, he drove it and looked under the hood and said because of not having that cap, power steering fluid probably leaked out onto the Rack and Pinion and my bushings are bad. His estimate is $742
So now I'm in a catch 22 where I even can't drive to work to make the money I need to pay that bill. Even if I bought used parts on eBay and had an amateur mechanic install them, I still won't have wheels for 5-10 days. This is what my brain is telling me to do:
So we went from bad bushings to replace all this stuff. I don't think the mechanic is trying to hustle me, he just wants to do it correctly. But I don't have that money and I need to make this car drivable immediately. If anyone has any ideas or advise I sure would appreciate it.
- Go get a power steering fluid cap.
- Drain and replace power steering fluid.
- Hose down the rack and pinion assembly with water.
- Purchase used rack and pinion on eBay.
- Attempt to install or find amateur mechanic.
Answers
You definitely want to look at this video:
So I bought a cap and flushed the fluid twice with Dexron/Merc (using the turkey baster method, but didn't flush the hoses) and it's improved about 30%.
Is it possible the Dexron VI could have caused all this nonsense?
