Soggy Moto Track Day - 2014 Ram 1500 EcoDiesel Long-Term Road Test
edited November 2014 in Ram
imageSoggy Moto Track Day - 2014 Ram 1500 EcoDiesel Long-Term Road Test
Edmunds used its long-term 2014 Ram 1500 EcoDiesel pickup to haul two motorcycles to a track day at Buttonwillow. Rain slowed the bikes, but not the truck.
    Nice report Mike. My only problem with the Ram 1500 is that the payload rating is lower than most if not all the so-called full-size 1/2-tons. As I recall it's only 1400 pounds. I wish they offered a 2000 pound payload package. Other 1/2-ton competitors have payloads in that range. Heck, Ford even offers a 3000+ payload option in the F-150.
  • gslippygslippy Member Posts: 514
    @rsholland: Surprisingly, 1/2 ton is only 1000 lbs, so I'd say the Ram's 1400-lb payload is OK.
    Ram is hitting a very sweet spot in the market. If you really want more truck, get the Magnum or Cummins engines, or some other truck brand.
    If I was truck shopping, I don't think I'd look further than this.
    The EcoDiesel's max payload rating is 1,610 pounds. The down side of that smooth riding coil suspension is that it can't carry as much weight as leaf springs. For example an F 150's max payload is 3,100 pounds. Ram had to offer an air suspension because when this generation was introduced with the independent coil springs the slightest weight in the box would cause serious rear squat.
  • explorerx4explorerx4 Member Posts: 20,955
    Not sure how much those 2 motorcycles weigh, but I'm surprised to the back of the truck sagging in the back in the first picture.
    The air suspension lowers the truck when parked and ignition off.
    A 1,610 payload is not that impressive. Most other competing gas trucks have trucks have payload ratings in the 1,800-2,200 pound range.
    Not true about the coil rear springs vs. leaf rear springs. The new Ram 2500 also has rear coil springs and can be had with a 10K GVW and a max 3,970 payload.
    Okay, let's remove the ancient and out of date "1/2-ton" label. Call it entry-level weight class for full-size pickups, or whatever term you prefer.
    Sweet spot or not, it should match or exceed the other weight-class competition (F-150, etc.) in terms of payload.
    The wet weight of the two bikes is roughly 900 pounds.
    900lbs shouldn't bend the back down that much.
  • tblackerby4tblackerby4 Member Posts: 1
    This is a 1500. You want a ton of power and towing power, get a Heavy Duty with a cummins. I have not driven the Ram Ecodiesel, but do own the '14 grand Cherokee with the 3.0 and it is flat amazing. Have pulled a 16ft utility trailer and the 420 ft lbs of torque is perfect. I know that this engine will be just as great in the ram. It will handle just as well or better than other half ton trucks. If you are looking to pull a large camper or gooseneck, then this isn't for you. But if u need to pull a boat or utility trailer, then test drive this truck, it should make you smile.
