Engine over revs and blinkers don't work (sometimes). Help! Olds Alero.
I took my 4 cyl 2004 Alero to the GM dealer because the turn signals work less and less frequently and to top it off, the battery light comes on and the engine revs up to 4000rpm going a max of 40 mph! When the battery shuts off a minute later, the engine runs normally again. This only happens when the car is cold (after I get off work), but the lights do their own thing when they want. No blinker, no sound. The dealer wants to charge me $1000 for a new alternator and control module, but I just changed the alternator, battery, fuel pump, and had a tune-up. Can anyone help?
Best Answer
Mr_Shiftright
Member Posts: 64,481
You need a scan tool to reset it---but what does the code read, do you know?
As for the alternator and BCM,, you have to work a deal out with them that if it doesn't fix the problem, or at least SOME of the problem, then they take off the parts and put your old ones back, no charge.
An authorized dealer with trained techs should not have to guess how to fix your car.5
Answers
So back to square one here, and have someone at least put a voltmeter on the battery terminals while you rev the engine, and see what it reads.
Thanks for the response. I had the alternator and battery tested before I took the car to the dealer. They both passed.
