Oh well i will be very happy to get my little Rav back. We'll see how she performs then.
The Rav4 transmissions are a piece of garbage... We had a 2002 for about three (3) months. I was driving on the Interstate in the fast lane coming up a hill when the entire tranny went. Thank goodness a truck wasn't behind me or I may have been killed.... After extensive research, found out these vehicle have serious problems. Not only do the trannys go bad due to faulty ECU's/TCM's, however the differentials shred. Cost to fix..... seven grand (7K). The vehicle sits dead in my driveway. There is an Class Action Lawsuit to fix these issues on any Rav4 under 150k miles/10Yrs. Google it. You can also contact the attorney and they will tell you how to proceed. In our case, we were "TOAST".... The warranty ran out two months after the incident. Called Toyota Corporate in California and got no satisfaction. Toyota makes EXCELLENT products like the Camary (saved my daughter and grandson's lives). The Rav4 SUCKS.... DON'T BUY!!!!! You're just asking for problems they won't acknowledge. Call Toyota Corporate. The more calls they get, the more they will pay attention to this severe issue. Someone is going to get seriously injured or killed.
Just recently purchased 2001 RAV4 (low miles/VG condition thru-out) subsequently learn of tranny/ecm probs. No occurrence as yet. 62000kms. What do I have 2 look 4ward to. Jim, in Philippines.
Probably nothing to worry about. What we hear on the Internet may or may not even be accurate, and if it is true, it might have affected a very small percentage of cars. Also, most "defects" occur early in a car's life, and be confined only to certain years of the model, or even only certain VIN #s within a given year.
My feeling is that you should be more worried about what happens to a 13 year old car in general (corrosion, leaking seals, worn out brakes and suspension parts) rather than a few complaints you read about.
I checked on RepairPal, which catalogs the most frequent complaints about a car by year and make, and there's nothing there about ECM problems. Most complaints were about failures in the EVAP system (leaks) and no-starts due to corroded contacts in the starter motor.
Well good for you. That means the car has had excellent care its whole life. A very good sign.
