2010 Toyota Corolla S, check engine light on and VSC off light flashing
phillykorean
Member Posts: 2
Hello, I own a 2010 Toyota Corolla S the 1.8L 2ZR-FE engine. Today after work I started the car in a sheltered car garage and as soon as I started the car the after the initial start up sequence the check engine light stayed on and the traction control light stayed on and right next to it on the left side the "VSC Off" light kept blinking and flashing. I turned off the car and started it several times to see if that did anything and to no avail nothing happened.
While I was driving those lights stayed on and the VSC off light kept on blinking.
I also checked the brakes and the brake fluid and they all seem to be fine, I even checked the fuel door as well.
I am not sure what is wrong. I was looking at some of the complaint sites and most people say it happens when you drive through a deep puddle or if it is cold and wet outside. But that didn't make sense because I drove in the snow and those lights never turned on. The only time I used the ETS button is during the snow storms and I drive at low speeds.
I need to know why this VSC off light is blinking? Is it a bad sensor or is the ABS/ETS brake system broken or is it an ECU issue or is it because of an alignment. Since I was told to get an alignment soon.
See also: 2010 Toyota Corolla Question: Check engine light on and "VSC off" light blinking with the ETS light on.
The code is read from a connector on the underside of the dash with a scanner.
Until the codes are read everyone is just guessing at what's wrong.
Get the dealer (or some auto parts places do it for free) to read the codes and post them here.
They look like "P0123".
A common misconception is that an error code will point to a specific part that's bad.
The code only tells what area of the system is having a problem.
So it could be a bad part or just a poor electrical connection to that part, or a leaky hose etc.
I'm waiting for the dealership to call me back, I've put a complaint into Toyota. I have also had an adaptor plug fail on me two times now. I'm feeling like I have a lemon.
I have a 2010 Corolla LE which showed the same problem. One day, the VSC off light and check engine started blinking but went off after some time.. I didn't give it much thought till the car got stalled while traveling on interstate. When i started the car, check engine light and VSC off started flashing. The accelerator pedal was not at all working and the car was moving at a very slow speed...But it was ok after some time .. I went to the Toyota dealership next day and found that there is a problem with the ECM module. They changed the ECM module free of cost and both light went off...Also i find that there is substantial improvement in the acceleration of the vehicle after replacing the ECM module...
But the VSC off and Engine light can blink for many other reasons also ..So better take it to a dealership ...Also check Toyota technical service bulletins (TSB) for more details about defects (http://www.toyotaproblems.com/tsbs/).
I disconnected the negative post of the battery for 30 seconds, reconnected it, and it fixed the problem. Lights are off! :-) I suggest you try disconnecting the battery for 30 seconds before you go to the dealer... You may get lucky like I did.
Corolla 2010 le
What is the main problem and how can be solved totally ??
